Project: Fix to busted CV shafts & wheel bearings! 56k no no
LinkBack (2) Thread Tools
Old 05-11-2008, 12:10 AM   #601
wrekd's Avatar
Re: Project: Fix to busted CV shafts & wheel bearings! 56k no no
Quote: Originally Posted by Tim99Zr2
and will the np231 output shaft accept the jeeps yoke?
It should. Mine did.
Old 05-11-2008, 12:14 AM   #602
wrekd's Avatar
kk.. uhh do jeep np231s have a different teeth count than the gm np233?
I dont think so. They both have the same 2.72:1 gear ratio. I could be wrong though.
Did you swap the output shafts already?
Old 05-11-2008, 02:50 AM   #603
Fvck New Jersey
Tim99Zr2's Avatar
yea man, they are good. i got to looking and the front seal was messed up. one of the springs in it was rubbing on the bearing in there, causing the "clicking" sound.. (i think)
Old 05-11-2008, 01:28 PM   #604
Fvck New Jersey
Tim99Zr2's Avatar
what seal did you use wrekd? on the front output shaft
Old 05-11-2008, 06:04 PM   #605
wrekd's Avatar
I got one for a 89 XJ with the np231 t-case. If i was able to find all my receipts i could of given you a part number, but I cant find the damn things no where
Old 05-11-2008, 06:07 PM   #606
Fvck New Jersey
Tim99Zr2's Avatar
i got it man, napa hooked me up with one.
but there is an internal problem, its not engaging in 4wd the whole way. im going to have to take it somewhere to get checked out.
BUT i did get to run it a little bit in 4LO and holy hell its a tank
Old 05-11-2008, 06:20 PM   #607
wrekd's Avatar
That sucks. Do you have any idea what you might have messed up?
Old 05-12-2008, 12:34 AM   #608
Fvck New Jersey
Tim99Zr2's Avatar
i got thinking.. there isnt much inside the tcase to mess up.
what about the 3 vacuum lines on it? would they affect it?
its almost like it wont fully go into 4wd. and when it does, it pops out.
what gives?
Old 05-12-2008, 11:05 AM   #609
wrekd's Avatar
Vacuum lines shouldnt have nothing to do with it. Maybe the shifter motor is going bad or something.
Old 05-12-2008, 02:05 PM   #610
Fvck New Jersey
Tim99Zr2's Avatar
yea, thats another thing i thought of
Old 05-12-2008, 07:04 PM   #611
wrekd's Avatar
I would just tear it down again and see if you can find anything wrong in there. Other than that I dont know what to tell ya.
Old 05-12-2008, 08:48 PM   #612
3 Leaf Fab
Donahue's Avatar
just to catch myself up, tim, are you using a 231 now or just parts from a 231 on your 233? if its a 231, sounds like the linkage could be out of adjustment. the vaccum lines just control the stock actuator, they do nothing to effect the way the t-case works other than seal a hole.
Old 05-13-2008, 01:05 AM   #613
Baggey22's Avatar
Tim you can have my old NP233 for parts if you want, just pay for me to ship it to you.
Old 05-13-2008, 03:08 AM   #614
Fvck New Jersey
Tim99Zr2's Avatar
no, im using the 233C with the 231J front output shaft on it.
so it may be my electric motor bad then, since it shouldnt be the vacuum?
Old 05-13-2008, 03:06 PM   #615
Fvck New Jersey
Tim99Zr2's Avatar
ok, i simply think my electric motor is "out of time" not letting it engage in 4LO the whole way, i tested out just 4HI today, and its holding up fine! and climbing hills with ease
Old 05-13-2008, 03:38 PM   #616
98-LS-lifted's Avatar
are you done yet....geez
Old 05-13-2008, 03:40 PM   #617
Fvck New Jersey
Tim99Zr2's Avatar
working some bugs out man.. almost. not working on it as hard, since i have nother SAS dime going on. and starting a SAS on a dakota soon (ford 9" d44 out of a bronco) using the bronco suspension on it
Old 05-13-2008, 03:44 PM   #618
Fvck New Jersey
Tim99Zr2's Avatar
just some little hills i was climbing, stopping on, then finishing the climb..
testing it out, so far so good.. and i DO need to rework my exhaust, just might go with duals with some quiet mufflers. any suggestions?
Old 05-13-2008, 06:08 PM   #619
wrekd's Avatar
so do you have 4 Lo now or just 4hi
Old 05-13-2008, 06:54 PM   #620
3 Leaf Fab
Donahue's Avatar
is it just me, or does it look like you are a little saggy in the rear. need some shackles?
Old 05-13-2008, 07:43 PM   #621
Not my Blazer
mullet9675's Avatar
your a born salesman
but you do have a saggy ass
Old 05-13-2008, 07:58 PM   #622
Registered Asshole
crazy91s10's Avatar
when did you see donahue's ass
Old 05-13-2008, 08:25 PM   #623
3 Leaf Fab
Donahue's Avatar
Old 05-13-2008, 11:11 PM   #624
Fvck New Jersey
Tim99Zr2's Avatar
WTF!!!!! get that pic outta here.. jesus!!
wrekd, i didnt try 4LO today, only 4HI. 4HI works fine.
donahue, i do need some 2" ones. ill PM you my addy for my free set, since we talked so much about your kit! bahaha! (they will be strictly for advertisiment purposes!
Old 05-13-2008, 11:42 PM   #625
wrekd's Avatar
thats freakin hilarious
Old 05-14-2008, 12:57 PM   #626
Registered Asshole
crazy91s10's Avatar
thats freakin
Old 05-15-2008, 12:44 AM   #627
Slightly Over Built
DieselS10's Avatar
Tim your truck looks awesome....way better than Donahue's ass.
Old 05-15-2008, 01:28 AM   #628
i love my chevy
19914x4blazer's Avatar
wow were did that come from?
Old 05-15-2008, 03:14 AM   #629
Fvck New Jersey
Tim99Zr2's Avatar
haha, thanks although thats prob not saying alot... its quite the comparison
Old 05-15-2008, 10:34 AM   #630
Slightly Over Built
DieselS10's Avatar
Scroll up and you'll figure it out!
Old 05-15-2008, 01:47 PM   #631
wow, not what i wanted to see....
Old 05-15-2008, 01:51 PM   #632
I Rather Be Wheelin'
ChrisInVT's Avatar
Nsfw?
Old 05-15-2008, 03:37 PM   #633
Fvck New Jersey
Tim99Zr2's Avatar
thats just wrong.. this kid has a refrence pic for EVERYTHING! jeeze.. ewww!!
anyway, baggey, i did something with my vac lock that you might be interested in. ill have to get some pics of it.. its pretty much a manual hub.. haha
Old 05-15-2008, 06:38 PM   #634
3 Leaf Fab
Donahue's Avatar
kid? what are you trying to say son?
i like to take a lot of pictures
Old 05-15-2008, 11:10 PM   #635
Fvck New Jersey
Tim99Zr2's Avatar
ive noticed.. and i dont think i care to see some of them.!!
P.S. where are my free shackles?
Old 05-15-2008, 11:45 PM   #636
i love my chevy
why do you have a pic of your own ass?
Old 05-16-2008, 12:35 AM   #637
2UP1DOWN
tfpets's Avatar
I would bet/hope that alcohol was involved!!
Old 05-16-2008, 01:57 AM   #638
3 Leaf Fab
Donahue's Avatar
would you be disappointed to learn i dont drink?
actually, it was a joke, i was emulating my 4 year old nephew that pulls his pants down all the way to pee. somebody just happened to snap a picture real quick.
Old 05-16-2008, 03:06 AM   #639
Fvck New Jersey
Tim99Zr2's Avatar
jeeze donahue, your tuff!! picking on a 4 yr old..
Old 05-16-2008, 11:47 AM   #640
Baggey22's Avatar
Alright, well where are the pix?
Old 05-16-2008, 12:53 PM   #641
Fvck New Jersey
Tim99Zr2's Avatar
ill get some when its not raining
they will be phone pics thou..
Old 05-16-2008, 12:58 PM   #642
Baggey22's Avatar
that's okay.
Why don't you just EXPLAIN what you did while you wait for the rain to stop.
Old 05-16-2008, 01:05 PM   #643
Fvck New Jersey
Tim99Zr2's Avatar
ok, that works.
first, i took the plastic cover off on the vac acuator. then you will see a rubber boot in there, you have to pull the boot up and out of the way, then you will be able to see under the washer in there. the washer is hooked to a shaft, take a cut off wheel and cut the boot&washer off the shaft. this will leave you with just the bottom (metal) pat of the vacuum housing. next i took my grinder and cut that off (down as close to the cast part as i could.
) pulled it off. so now all that you have where the vacumm actuator used to be is a metal shaft. i then welded a washer on the end of it, just to make it easier to pull out & push in.
Pulled out is in 2wd, pushed in is 4wd. i use a RC car body clip to hold it out, in 2wd. and am going to rig up a spring of some sort to hold it in 4wd.
ill have to get pics when its done raining. sounds pretty confusing
Old 05-16-2008, 01:17 PM   #644
Baggey22's Avatar
Should have taken pix of the during process.
Old 05-16-2008, 01:23 PM   #645
Fvck New Jersey
Tim99Zr2's Avatar
yea.. i dont think of it until its too late..
Old 05-16-2008, 07:12 PM   #646
3 Leaf Fab
Donahue's Avatar
thats exactly why i take so many pictures.
Old 05-17-2008, 03:57 AM   #647
Fvck New Jersey
Tim99Zr2's Avatar
of your ass...
Old 05-21-2008, 10:56 PM   #648
3 Leaf Fab
Donahue's Avatar
of your ass...
i didnt take that obviously, because it was my ass. and that is the only one
Old 05-21-2008, 11:45 PM   #649
i love my chevy
you could have. they have timers on them, so you can be in the pic
Old 07-04-2008, 05:03 PM   #650
Fvck New Jersey
Tim99Zr2's Avatar
ok, well i got an update.
the truck is pretty much done, finally got my springs figured out. i just need rear shocks, and shorten the rear drive shaft.
pissed with the springs today, up front i got a XJ main, Fullsize chevy main below that, and 2 zr2 springs on the bottom.
as for flex, ill let the pics show you!
so i think its getting there, i went for a little trail ride to test it out, since i havent driven it since i bought my rocket.
whatta ya think?
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f221/project-fix-to-busted-cv-shafts-and-wheel-bearings-56k-no-no-329989/
Posted By For Type Date
ZR2 USA -> coupld pics This thread Refback 01-14-2008 11:59 PM
Xmas vacation plans? This thread Pingback 01-03-2008 05:37 AM
Page generated in 0.65819 seconds with 31 queries
[Output: 225.95 Kb. compressed to 206.98 Kb. by saving 18.97 Kb. (8.40%)]
