Project: 1995 s10 SAS
Old 08-10-2009, 06:47 PM   #1351
GAVE his truck to 96super
bubbagt57's Avatar
Re: Project: 1995 s10 SAS
drain coolant and remove hoses
remove transcooler/oil cooler lines
remove radiator
replace with new
install oil/trans cooler lines
fill with coolant check oil tans fluid and collant after install
Old 08-10-2009, 07:14 PM   #1352
Baggey22's Avatar
Approximately how much transmission fluid is IN the cooler when it's cold? Any idea?
Old 08-10-2009, 08:05 PM   #1353
bubbagt57's Avatar
iono get 3 quarts 2b safe
Old 08-15-2009, 07:06 PM   #1354
pjg1173's Avatar
Last time I changed my radiator i didn't even have to add any trany fluid. It only holds a pint or two. It is only a small coil in the passenger side radiator tank. You should barely be able to see a drop on the dipstick. Unless you have an external cooler then it could be 1-3 Qts.
Old 08-15-2009, 09:45 PM   #1355
Baggey22's Avatar
I have a small external cooler that is about 3/4 of a quart. But the tranny has been leaking since I got it replaced, but now I know where it's leaking and the mechanic says he'll cover it once I get the radiator done. I'm like halfway done with doing the radiator and water pump, I just gotta relocate the oil filter and then reinstall all the new stuff.
Old 08-16-2009, 01:56 PM   #1356
pjg1173's Avatar
Are you moving the oil filter back to block removing all the remote crap? if so see if it makes a difference in your oil pressure. I've been wanting to relocate mine for a while since it leaks every where, but I'm hoping to pick up a little more pressure at idle with it gone.
Page generated in 0.57487 seconds with 32 queries
[Output: 61.70 Kb. compressed to 58.61 Kb. by saving 3.09 Kb. (5.01%)]
