Project: 1995 s10 SAS
Old 02-02-2009, 02:31 PM   #1001
wrekd's Avatar
Re: Project: 1995 s10 SAS
Fvck that. Just wheel it. Snow wheelin is fun as hell. I wish I had as much snow as you do. Id be in the woods all day
Old 02-02-2009, 02:45 PM   #1002
I Rather Be Wheelin'
ChrisInVT's Avatar
Real daylighters. IIRC they have 100w bulbs. I'm actually sending them back to KC on factory warranty because the reflectors rusted. So I'll be getting some brand new daylighters back.
Old 02-02-2009, 05:21 PM   #1003
Baggey22's Avatar
So you're sending them back and then I'm buying the new ones from you for $50?
Old 02-03-2009, 11:03 AM   #1004
96superflow's Avatar
How are those LTB's holding up on the street? I really like the tires, wish they came in a radial. thats the only thing that keeps me thinking not to buy them and just get the TSL radials.
Old 02-03-2009, 11:09 AM   #1005
ChrisInVT's Avatar
Ya. Providing shipping doesn't cost me that much
Oh, and that thread that I was talking about....
http://www.s10forum.com/forum/f222/s...-tires-307064/
Old 02-03-2009, 02:26 PM   #1006
Baggey22's Avatar
They ride decently rough on the street. This is a combination of having them inflated at like just under 40PSI (which will be going down to 20PSI soon) and cause they aren't balanced. As for off road all I can tell you so far is that they dig, REAL fast.
WOOT! Let me know as soon as you get the lights back and I'll pay ya.
Old 02-03-2009, 03:43 PM   #1007
ah, ok. is there anypoint in trying to balance them? Im considering the 31x11.50 for my blazer, but maybe down the road i can get the 34's after about another 8-10" of lift when diversified Creations comes out with their kit for then non zr2.
Old 02-03-2009, 03:47 PM   #1008
ChrisInVT's Avatar
Why wouldn't you balance them?
You can always dynamically balance them. I did this with my 33's, but above 50 I get a bad shake, I don't think I put enough BBs in
Old 02-03-2009, 04:32 PM   #1009
Baggey22's Avatar
I plan on doing dynamic balancing. I just require someone that has done it before to help me.
Old 02-03-2009, 09:25 PM   #1010
Didnt know if the truck stayed off the road more than being on it.
Old 02-03-2009, 11:56 PM   #1011
Baggey22's Avatar
It just hasn't seen much driving yet. Since the swap I've MAYBE put 50 miles on it. Now that it has shocks I'll drive it more. So I'll let you know later how the LTBs are doing.
Old 02-04-2009, 05:58 PM   #1012
i imagine that yall have covered this but i went through every single page of this thread and cant find it. does the astro van steering box mount directly up and does my steering columb fit to the astro van box? im in the proccess of gathering all my sas parts
Old 02-04-2009, 06:21 PM   #1013
Fvck New Jersey
Tim99Zr2's Avatar
yep yep. PM wrekd
Old 02-04-2009, 07:08 PM   #1014
Baggey22's Avatar
We never went through it in this thread. Because I never did/wanted to do that modification. But x2 on PMing Wrekd, he'll tell you ALL about it
Old 02-04-2009, 08:48 PM   #1015
wrekd's Avatar
It just bolts right up. Nothing to figure out. The only difference is the pitman arm faces forward instead of backwards.
Old 02-05-2009, 10:59 AM   #1016
What do you gain by switching out the steering boxes??
Old 02-05-2009, 12:48 PM   #1017
Fvck New Jersey
Tim99Zr2's Avatar
better steering angles, if you move the front axle 6" + forward
Old 02-05-2009, 05:48 PM   #1018
nice i aprriciate that. i figured it would bolt up i didnt know it i had to do any changin of belts and that stuff.
Old 02-06-2009, 01:02 AM   #1019
wrekd's Avatar
You dont have to changes belts or anything cause your just replacing the steering box. Theres not even a belt going to it.
Old 02-11-2009, 12:09 AM   #1020
Baggey22's Avatar
question: So like I said a page or two back I've been thinking about switching over to full synthetic transmission fluid. My question is how do you drain the transmission? Also should I replace the filter? If so how do I do that? I'm going to have access to a garage for another few days in like a week and a half so if I have time I'll do the transmission.
Old 02-11-2009, 12:55 AM   #1021
wrekd's Avatar
Take off the tranny pan. You might as well change the filter while you do it. It right there as soon as you drop the pan.
Old 02-11-2009, 12:59 AM   #1022
Baggey22's Avatar
I can envision this making a HUGE mess. Anything else I should look for/do while I have the pan off? Besides changing the filter.
Old 02-11-2009, 01:07 AM   #1023
local12hand's Avatar
Put a drain plug on your pan if you want... But just get a new filter and gasket...
Old 02-11-2009, 01:14 AM   #1024
Registered Abuser
Merritt's Avatar
It's not that bad changing the tranny fluid in my truck, yours should be 10x easier since it's so much higher in the air. Just remember to wipe all the metal shavings out of the pan before you put it back on.
Old 02-11-2009, 01:18 AM   #1025
Slightly Over Built
DieselS10's Avatar
Only problem is that a large amount of the old fluid is in the torque converter and you won't get that out by droping the pan.
Old 02-11-2009, 01:47 AM   #1026
wrekd's Avatar
Yeah I was thinking that. How the hell do you get all the fluid out??Get it flushed with synthetic?? That would probably be expensive as hell though. I wanna do the same thing, but im not spending a shit ton of money or dropping the trans to do it.
Old 02-11-2009, 01:51 AM   #1027
Slightly Over Built
DieselS10's Avatar
Having it flushed with synthetic is the only way I could think of getting all of it changed and he had better take some vasoline for when they ask him to bend over.
Old 02-11-2009, 01:56 AM   #1028
wrekd's Avatar
Haha....I figured that. Maybe I'll just do some fresh fluid and a shift kit so it doesnt slip as much.
Old 02-11-2009, 10:03 AM   #1029
a shift kit will not make it slip any less, unless you are just saying it has some soft shifts ? but that can be fixed with someone reworking your computer to make it shift firmer.
but is it is actually slipping, a shift kit and fluid change might make it worse.
on a good tranny , if you have not changed fluid for a while ,( daily driver every 30k , heavy wheeler every year !) you may have to change the fluid two or three times to get most of the old fluid out. make sure you take the lines loose and drain them out and clean them also. along with the radiator
about the mess, most people dont have a pan 3x3 foot to catch all the fluid,, so , take you 30 gallon plastic trash can lid, drill 10 pencil sized holes in the middle, turn it upside down, and on top of your smaller drain pan, now you have drain system that can catch all the fluid . and it dint cost you a dime.
Old 02-11-2009, 11:38 PM   #1030
Baggey22's Avatar
How much fluid will stay in the torque converter? I know the transmission takes 5 quarts total, so should I just drop the pan and get like 3 quarts? Maybe I'll just wait and have it flushed with synthetic, I'll call and get a quote tomorrow
Old 02-11-2009, 11:54 PM   #1031
Slightly Over Built
DieselS10's Avatar
A tranny that is completely empty will hold nealy a case of fluid.
Old 02-12-2009, 12:35 AM   #1032
Baggey22's Avatar
when I called an auto parts store a few days ago asking about it they said that all it would take is 5 quarts. How many do you think I should get?
Old 02-12-2009, 01:51 AM   #1033
Slightly Over Built
DieselS10's Avatar
If your going to change it yourself that will probably be plenty, since you won't be able to get alot of it out.
Old 02-12-2009, 06:06 AM   #1034
Registered Abuser
Merritt's Avatar
I wonder if it would help to put more magnets in the pan, cause when I changed my fluid the magnet was completely covered in shavings to the point where it wasn't holding more, lol. Just a thought that came to mind, maybe throw 3 or 4 more magnets in the pan and it would attract more shavings and keep them out of the clutches and bands.
Old 02-12-2009, 10:05 AM   #1035
the tranny and torque converter will hold 12-14 quarts,,, to drop the pan and drain out what you can , it will only take 4-6 quarts, so you are only replacing half the fluid when you change it,,, so that it is why you need to change it on a regular basis
Old 02-12-2009, 02:35 PM   #1036
Baggey22's Avatar
Just called the local mechanic, he told me that it would be $75 total to flush my transmission and refill it. I told him about how it's been shifting funny and hesitating to get into reverse and he said that a flush is an excellent idea to try and remedy that problem. So I think I'm gonna have it done soon. It's totally worth it.
Old 02-26-2009, 08:42 PM   #1037
Baggey22's Avatar
UPDATE: I'm heading back to Vermont on Saturday and on my way I'm meeting a guy in New Hampshire who's GIVING me a pair of bucket seats for my s10 (FOR FREE!!). Once they are in I can cut the hole in my floor and fab up my transfer case shift lever.
The seats DO come with the original seat sliders still attached. My question is what's the best way to get these seats INTO my s10? Anyone that has ever put different seats into their truck that has some insight would be EXCELLENT.
Old 02-26-2009, 11:10 PM   #1038
Registered Boozer
coloRADo_S10's Avatar
open the door, take the seats out. Set your new seats in and mock them up. Most likely you will have to drill new holes to mount the new seats. atleast i did. THen drill your holes put seat back in and bolt them down. Wala!!!! Done!
Old 02-27-2009, 12:43 AM   #1039
Slightly Over Built
DieselS10's Avatar
I always like to mount them to the factory seat studs, that way if you are ever in a wreck they will remain attached to the floor instead of chasing you through the windshield. lol
Old 02-27-2009, 01:00 AM   #1040
Registered Boozer
i didnt have a choice when i did mine but good point.
Old 03-01-2009, 03:07 PM   #1041
Baggey22's Avatar
As planned I picked up my bucket seats in New Hampshire yesterday. The guy said he had no idea what they were out of, but they have flat mounting brackets so mounting them should be easy. Plus, they were FREE!!
Here's pictures, anyone have any idea what they're out of? I'm thinking a Toyota but I really have no idea.
Old 03-01-2009, 04:50 PM   #1042
Registered Boozer
toyota sound accurate. not sure tho
Old 03-01-2009, 06:53 PM   #1043
look kinda like 88-92 mustang ???
Old 03-01-2009, 11:10 PM   #1044
Baggey22's Avatar
Eww gross, I hope they're not from a Mustang. Haha
Old 03-02-2009, 02:39 PM   #1045
ChrisInVT's Avatar
Yeah, you don't wanna jinx your truck with Ford or Chrysler parts!
....Oh, wait.
Old 03-02-2009, 03:18 PM   #1046
wrekd's Avatar
Old 03-02-2009, 10:49 PM   #1047
Slightly Over Built
DieselS10's Avatar
....Oh, wait.
Easy now.
I've finally got mine down to just GM, Ford, and Chrysler. I got rid of the International, Jeep, and Cadillac parts.
Old 03-03-2009, 10:31 PM   #1048
Baggey22's Avatar
Yea, I don't really care what they came out of. It's awesome cause they are really comfortable. In fact my buddy Justin was over my apartment tonight and he sat in the "driver's seat" the whole evening instead of the couch. He said he was more comfortable there.
Old 03-10-2009, 01:05 AM   #1049
Baggey22's Avatar
Update: So I'm bringing Sally in tomorrow to the mechanic to do some things for me. First he's gonna flush the transmission. Then I'm gonna ask him to take a look at my brakes, they've been acting funny lately and I don't know why nor to I have the time to deal with it. I'm also gonna have him flush the radiator and replace the thermostat because, once again, I don't have the time to deal with it. So hopefully in a few days she'll be back in my driveway and I can drive it around more confidently and when I do have time upgrade things like the front axle and get those bucket seats in.
Old 03-10-2009, 12:40 PM   #1050
ChrisInVT's Avatar
The brakes in my truck are ****ed, I've replaced everything in it and they still suck. It'll lock up and drag both drivers side 33's, but won't brake the passenger side. Especially makes no sense considering there's only one line going to the rear brakes.
Brakes suck when they don't work correctly.
Page generated in 1.13636 seconds with 32 queries
[Output: 213.53 Kb. compressed to 194.79 Kb. by saving 18.74 Kb. (8.78%)]
