Project: 1995 s10 SAS
Old 09-17-2008, 06:53 PM   #801
Slightly Over Built
DieselS10's Avatar
Re: Project: 1995 s10 SAS
Looks good Baggey, but I think Chris is right, your drivers side front tire doesn't seem to have any up travel and if the driveshaft is hitting the exhaust it can't go up. Sawzall Time!
Old 09-17-2008, 08:00 PM   #802
sapperb's Avatar
Why are the front shocks mounted upsidedown
Old 09-17-2008, 08:24 PM   #803
Fvck New Jersey
Tim99Zr2's Avatar
yea, might wanna switch them around, mine leaked all the oil out in 2 days..
Old 09-17-2008, 10:41 PM   #804
3 Leaf Fab
Donahue's Avatar
Quote: Originally Posted by Baggey22
Here's where my drive shaft hits my exhaust
this is what prompted this:
From s10 buildup
Old 09-17-2008, 11:46 PM   #805
Baggey22's Avatar
Yea, the drive shaft hits the exhaust at ride height, like flat ground just sitting still. I barely rests on it. From what I'm told by locals there's a guy that is magical with exhaust work. So I'm gonna call him and see what he can do about moving it for me.
Old 09-17-2008, 11:51 PM   #806
Slightly Over Built
DieselS10's Avatar
It shouldn't be any big deal for anyone that does exhaust work.
Old 09-17-2008, 11:54 PM   #807
Baggey22's Avatar
it's just finding someone with a pipe bender that's hard around here. There's a bunch of shops that CLAIM they do exhaust work, but don't have a bender. I mean really, who does that?
Old 09-18-2008, 12:01 AM   #808
Slightly Over Built
DieselS10's Avatar
Well, I have one, but your probably not gonna want to drive it down here.
Old 09-18-2008, 12:13 AM   #809
Baggey22's Avatar
isn't there a way to make your own out of random stuff lying around? Cause I'd make one and fix it myself if I could.
Old 09-18-2008, 12:16 AM   #810
wrekd's Avatar
Lookin good!!!
Old 09-18-2008, 12:46 AM   #811
wrekd's Avatar
You should be able to find exhaust pieces at the local auto parts store. Maybe get some of that flexy pipe and some elbows. It shouldnt be that hard.
Old 09-18-2008, 01:10 AM   #812
Slightly Over Built
DieselS10's Avatar
I make all my exhaust systems from mandrel bent U's and sections of straight pipe that I get from Summit. Just cut out how much bend you need and weld them together.
Old 09-18-2008, 01:14 AM   #813
Baggey22's Avatar
I need like a TIGHT 90* turn, and most stores don't have tight ones
Old 09-18-2008, 09:36 AM   #814
I Rather Be Wheelin'
ChrisInVT's Avatar
Flex pipe
Old 09-18-2008, 03:48 PM   #815
sapperb's Avatar
I have heard of people filling the pipe with sand, heat it up and bend it, though i have never seen the end result. Don't they have a Harbor Freight anywhere near you? Semi good tools and equipment for a good price.
Old 09-18-2008, 04:33 PM   #816
Fvck New Jersey
Tim99Zr2's Avatar
grinder man, pie cuts!
Old 09-18-2008, 04:58 PM   #817
Baggey22's Avatar
I think I'm just gonna go with flex pipe. It's simple, inexpensive, and if it doesn't work then most of the work is done if I go to an exhaust shop. Plus I can do it in a day by myself and be on the trails by afternoon.
Old 09-18-2008, 08:39 PM   #818
Fvck New Jersey
Tim99Zr2's Avatar
meh, from my experience flex pipe doesnt bend that tight of radius'
Old 09-18-2008, 10:15 PM   #819
wrekd's Avatar
No it doesnt. But if he cuts it back far enough he should be able to route it up far enough.
Old 09-19-2008, 01:39 AM   #820
Baggey22's Avatar
when you say cut it back do you mean cutting it back under the motor or cutting it back closer to the header?
Old 09-19-2008, 02:09 AM   #821
wrekd's Avatar
Cut it back farther under the motor. Between the flexy tube and a 45 elbow you should be able to pull it off.
Old 09-19-2008, 10:24 AM   #822
Baggey22's Avatar
45 elbow? Where is that going?
I was planning on just getting flex pipe and making it work. Do you think you can get a picture and draw what you're talking about in paint?
Old 09-19-2008, 03:10 PM   #823
Fvck New Jersey
Tim99Zr2's Avatar
i tihnk im just going to do true duals. since i at least will have a standard.
v-6s and autos sound like poo poo
Old 09-19-2008, 03:23 PM   #824
ChrisInVT's Avatar
< V8s sound like poo poo
Fixed.
Old 09-19-2008, 05:51 PM   #825
Fvck New Jersey
Tim99Zr2's Avatar
true that. but sticks at least change tone
Old 09-20-2008, 03:22 AM   #826
wrekd's Avatar
I dont think flex pipe is gonna have enough flex in it to make the turn up to the collector(or whatever it is called). I'll get a pic of my exhaust and fix it up in paint tomorrow if I have the time.
Old 09-21-2008, 02:14 PM   #827
Baggey22's Avatar
That would be awesome if you could do that Wrekd. I'm hoping to do this Wednesday.
Old 09-21-2008, 02:30 PM   #828
ChrisInVT's Avatar
You're back early
Old 09-21-2008, 02:33 PM   #829
Baggey22's Avatar
Just got back. The group wanted to push more mileage yesterday to make today a shorter day because some of them had homework.
So that's what we did. I just got back like an hour ago.
Old 09-22-2008, 02:11 PM   #830
Baggey22's Avatar
Update: I went to the auto parts store today and got the pieces needed to fix my exhaust. I also won a sweet Trail Defence D30 cover for $80. As soon as that comes in the Detroit is gonna in.
So hopefully I can get the exhaust done on Wednesday and the diff cover won't be far behind it.
Old 09-24-2008, 02:47 PM   #831
Baggey22's Avatar
Update: Things didn't go as planned today. The exhaust needs to be done by a shop because of all the goofy bends and things in it. So instead of giving up I went for a short trail run and banged up the exhaust more and got some more flex shots.
Old 09-24-2008, 11:01 PM   #832
Slightly Over Built
DieselS10's Avatar
Sweet man! Those belong in the Articulation thread.
Old 09-25-2008, 02:34 AM   #833
wrekd's Avatar
You can never have too many pics of your truck flexing. Especially when you first get done. I would flex my truck out and then just stand there staring at it for like 10 mins thinking this is fvcking awesome, Fvck IFS.
Im sure everyone thats done the swap does the same exact thing
Old 10-26-2008, 11:06 AM   #834
Baggey22's Avatar
Update: My s10 is going in tomorrow to a local guy to get my exhaust done. As soon as that's done the truck should be all set to go.
Old 10-26-2008, 11:34 AM   #835
Fvck New Jersey
Tim99Zr2's Avatar
cancel it baggey, i got a easy fix.
i used flex pipe to come down off the manifold, up over the frame, ran the exhaust pipe between the rocker and frame, and put the exhaust on under the bed.
total cost was like 80$ for true duals
Old 10-26-2008, 04:47 PM   #836
Baggey22's Avatar
I'd rather just get it done by him. Problem in Vermont is it gets cold out quickly and my time is starting to slip away from me. I don't have a garage to work in and I don't have time time to get it done. So I'll just let this guy do it and not have true duals.
Old 10-26-2008, 06:47 PM   #837
Slightly Over Built
DieselS10's Avatar
Dual exhaust really isn't going to make a difference power wise anyway. Mine has single exhaust, it just happens to be VERY big.
Old 10-26-2008, 07:18 PM   #838
ChrisInVT's Avatar
You ever get your slip yoke problem figured out?
Old 10-26-2008, 07:35 PM   #839
Baggey22's Avatar
There was no problem. We fully compressed/extended the rear suspension and the amount of travel was a lot less than the slip yoke can move. So we just cut the drive shaft and extended it with a piece of exhaust pipe (like Wrekd did) It's been fine ever since.
You knew that too btw Chris, remember "LOL Shaft"?
Old 10-26-2008, 07:40 PM   #840
ChrisInVT's Avatar
HAHAHAHA that's right!!! How could I possibly forget that thing!!
So LMK when it's wheelin' time. I went wheelin' two weeks ago, and with my tires aired down to 15PSI and my truck in 4WD I get a full 120 miles to my 20 gallon tank
Old 10-26-2008, 07:44 PM   #841
Baggey22's Avatar
I'll need to recalibrate my speedometer for my gears/tires to see what kinda mileage I'm getting
And so I can tell how fast I'm going on the road.
Old 10-26-2008, 07:46 PM   #842
ChrisInVT's Avatar
I still need to do that in my truck. I know it's 5% off so I just try to keep it at a reasonable speed.
Old 10-26-2008, 07:52 PM   #843
Baggey22's Avatar
I'm gonna follow someone to the mechanic place tomorrow so that I don't go fast. When that's over I'm gonna borrow my room mate's TomTom and figure out what speed I'm going
Old 10-26-2008, 08:52 PM   #844
Fvck New Jersey
Tim99Zr2's Avatar
never said it did, just the easiest way to fix the DS hitting the exhaust problem
Old 10-26-2008, 09:09 PM   #845
Baggey22's Avatar
Eh, this is easier for me. For times sake mostly
Old 10-26-2008, 11:12 PM   #846
Slightly Over Built
DieselS10's Avatar
I modified my VSSB with dip switches and you can set it to correct nearly any gear/tire combo.
Here is a link for instructions, http://www.tbichips.com/drac.
Old 10-26-2008, 11:32 PM   #847
Baggey22's Avatar
Look Chris! Computer geek stuff! ha ha
That's a cool article, I'll read the whole thing later and if it's not too involved I may try that.
Old 10-26-2008, 11:38 PM   #848
wrekd's Avatar
What was your gearing when you had IFS??
Old 10-26-2008, 11:58 PM   #849
Baggey22's Avatar
I don't know what it was. Is there a way I can find out?
Old 10-27-2008, 12:09 AM   #850
wrekd's Avatar
There should be a bunch of 3 letter/number codes in your glovebox. I'll get the gearing codes and post em up and you'll be able to tell what gearing you had. They were probably 3.42's though.
Edit: GU6 is 3.42's. Theres just too many other codes to look through for the other ratios. But copy down all the 3 digit codes in your glovebox and it will tell you all the options your truck has.
Once you get the codes you can use this to find out what which one means:
http://73-87.com/chevy_ids/rpomenu2.htm
Page generated in 0.69838 seconds with 32 queries
[Output: 212.18 Kb. compressed to 193.34 Kb. by saving 18.84 Kb. (8.88%)]
