Project: 1995 s10 SAS
Old 08-02-2008, 01:09 PM   #601
Fvck New Jersey
Tim99Zr2's Avatar
Re: Project: 1995 s10 SAS
hell yea! looks good. im going to work on mine soon!
Old 08-02-2008, 02:10 PM   #602
Registered Asshole
crazy91s10's Avatar
holy shit... bout damn time. how long have we waited for these pics???!!! looks great man! those 34s look small on there... wish i could see that truck in person!
Old 08-02-2008, 02:53 PM   #603
wrekd's Avatar
Looks good Baggey. Now wheres the flex pics
Old 08-02-2008, 03:13 PM   #604
I Rather Be Wheelin'
ChrisInVT's Avatar
That tire on the RH side of the first picture is the same trad of the tires I'll be getting
And why is your truck leaning? is it just the picture?
Old 08-02-2008, 03:59 PM   #605
3 Leaf Fab
Donahue's Avatar
now its time to take the BL out
Old 08-02-2008, 04:03 PM   #606
Baggey22's Avatar
That is the same tread as what you'll be getting Chris.
Flex pix will be coming soon.
I was thinking about taking the BL off, we'll see though.
The lean is half the truck and half the driveway. It leans a little but it's not terrible.
Old 08-02-2008, 04:10 PM   #607
Site Sponsor
4wdjoey's Avatar
Quote: Originally Posted by Baggey22
Here you go sluts, ENJOY!
I didn't get to drive the truck around much because the tranny is being retarded.
How much clearance do you have under the front shackles?
Old 08-02-2008, 05:02 PM   #608
Baggey22's Avatar
I haven't actually measured how much clearance I have. They do hang kinda low. I plan to move the frame mount and put a smaller shackle on it soon.
Old 08-02-2008, 05:11 PM   #609
ChrisInVT's Avatar
Sweet!
And I 2nd the body lift removal motion.
Have you thought about putting the shackles on the front like Jeeps do? Those shackles do hang down very low.
Old 08-02-2008, 05:18 PM   #610
Baggey22's Avatar
Putting the shackles on the front would require a lot of modification. Once I put the shorter shackles on it'll be better.
Old 08-02-2008, 09:33 PM   #611
got SFA?
Geoff03's Avatar
paint your frame son
Old 08-02-2008, 11:14 PM   #612
wrekd's Avatar
Baggey, whats your spring perch width? Is there any way you can inboard the shackles instead of putting them right underneath the frame?
Old 08-02-2008, 11:25 PM   #613
3 Leaf Fab
Donahue's Avatar
read this thread:
http://www.pirate4x4.com/forum/showthread.php?t=652426
Old 08-02-2008, 11:27 PM   #614
Fvck New Jersey
Tim99Zr2's Avatar
he is prob 31" CTC of the springs. mine are inboard some?
Old 08-02-2008, 11:35 PM   #615
3 Leaf Fab
Donahue's Avatar
some, but not enough to clear the drivers side frame rail, at least not on my truck. mine are at 31.5" and my pass side one could go higher, but my drivers side frame rail stick in farther about 2".
Old 08-02-2008, 11:37 PM   #616
Fvck New Jersey
Tim99Zr2's Avatar
i dont think mine is the same frame.. are they donahue?? i forget.
Old 08-02-2008, 11:41 PM   #617
wrekd's Avatar
Wow. I didnt think the Dana 30 had that wide of a perch width. Mine is at 31.5" CTC and thats fullwidth. Mine are also inboarded with the shackle about 2 inches up in the frame
Old 08-02-2008, 11:47 PM   #618
3 Leaf Fab
Donahue's Avatar
second and first gen frames are not the same, but they are similar. the z frame however may actually be symmetrical side to side unlike the regular 4x4's.
wreckd, did you have to modify the frame at all to mount them higher?
edit: also, YJ 30's have that perch width. CJ's do not, they are like 27". 70's ford, and chevy share the same width as well as scout and waggys, and dodge is just 1" wider at 32.5". 85-99 (or whenever the superduty took over) it was 36" or 36.5" and the superduties are a whopping 39" CTC.
Old 08-02-2008, 11:58 PM   #619
wrekd's Avatar
Quote: Originally Posted by Donahue
Pretty cool idea, but I wouldnt run them.
Old 08-03-2008, 12:03 AM   #620
wrekd's Avatar
[quote=Donahue;5464310]\
quote]
No. I had 1" of clearence on each side between the frame and shackle mount. I put the bolt in from the inside, toward the frame, pushed it in til i could get the nut on, and then just ground down the bolt until it cleared without hitting the frame.
Did that make sense?
Old 08-03-2008, 12:16 AM   #621
3 Leaf Fab
Donahue's Avatar
did you inboard past 31.5"? or are your frame rails symmetrical?
Old 08-03-2008, 12:23 AM   #622
wrekd's Avatar
I know I didnt have to go past 31.5". But I'm not 100% sure theyre symmetrical. I think they are but I'll have to check tomorrow.
Old 08-03-2008, 12:26 AM   #623
3 Leaf Fab
Donahue's Avatar
get pics too if you could, i would be interested.
Old 08-03-2008, 12:28 AM   #624
Fvck New Jersey
Tim99Zr2's Avatar
yea, mine are symmetrical
Old 08-03-2008, 12:29 AM   #625
wrekd's Avatar
Yeah so are mine. i just went out and checked. Curiosity got the best of me
Old 08-03-2008, 12:30 AM   #626
Slightly Over Built
DieselS10's Avatar
Looks good baggey!
Old 08-03-2008, 12:31 AM   #627
3 Leaf Fab
Donahue's Avatar
was yours a 2wd originally?
Old 08-03-2008, 12:34 AM   #628
wrekd's Avatar
No it was a 4x4. I went and took a pic of it. So it'll be up in a few mins.
Old 08-03-2008, 12:40 AM   #629
wrekd's Avatar
Ok here it is. Its not a pretty mount, but it gets the job done
Old 08-03-2008, 12:43 AM   #630
Fvck New Jersey
Tim99Zr2's Avatar
i dont see a tailgate....
Old 08-03-2008, 12:45 AM   #631
wrekd's Avatar
Tailgates are overrated
Old 08-03-2008, 01:07 AM   #632
3 Leaf Fab
Donahue's Avatar
that is not really any different than mine, how about the other side?
Old 08-03-2008, 02:24 AM   #633
wrekd's Avatar
Its exactly the same
Old 08-03-2008, 10:26 AM   #634
Baggey22's Avatar
Wrekd yours aren't much different than mine, the top of my shackle mount (on the frame) sits 1/4 below the frame because of how I mounted them. I was thinking about sliders but never really thought seriously about them.
Like I said I'm still seriously thinking about moving the mount so I can use the smaller shackles and if I get REAL adventurous I'll put on the slightly shorter s10 springs with the shorter shackle to make it just that little bit better.
And my frame is NO WHERE near symmetrical. It's completely different on both sides.
Old 08-03-2008, 05:08 PM   #635
3 Leaf Fab
Donahue's Avatar
im curious wreckd, i have examined a 97 4wd blazer, and it appeared to be asymmetrical like my 89. one of the dead give aways was the trans crossmember being asymmetrical as well. on mine and the 97' i looked at, the drivers side mounted with 2 bolts running front to back, on a ledge about 4" up from the bottom of the frame on the inside. on the passenger side, it mounted with 2 bolts that were running vertical and to the side of the frame. is this how yours was?
Old 08-03-2008, 06:03 PM   #636
wrekd's Avatar
Was the 97 a 2dr or 4dr? Cause they are probably different.
If it ever stops raining Ill have to look today when it light out. It was dark out last night, but from what I can tell it was the same. I could be wrong though and probably am
Old 08-03-2008, 06:23 PM   #637
3 Leaf Fab
Donahue's Avatar
4dr LS
Old 08-03-2008, 06:43 PM   #638
ChrisInVT's Avatar
I'm home already and you don't have the flex pictures up?
I'm disappointed in you Adam...
Edit: that 1.25 hour drive only took me about 30 minutes
Old 08-03-2008, 11:15 PM   #639
Baggey22's Avatar
You know my internet Chris. It didn't work for SHIT and then I came to the theatre for a dance party. So now I'm on the computer in the box office telling everyone that as soon as I can I'll put up the flex pictures on PhotoBucket so that EVERYONE can see them.
Yea, Chris and I found out the fun way that my truck has a crazy amount of flex. It's gonna be sweet once it's done.
We also 90% finished the transmission crossmember. All that's left to do is drill and tap some holes to make it bolt up to the frame/transmission. I'll put up pictures as soon as I can. I promise!
Old 08-03-2008, 11:18 PM   #640
Fvck New Jersey
Tim99Zr2's Avatar
howd you flex it? fork lift? drive it?
Old 08-03-2008, 11:26 PM   #641
Baggey22's Avatar
I have lots of large rocks at the end of my driveway. So I drove it up onto them. But it was wet and it was somewhat difficult.
Old 08-03-2008, 11:45 PM   #642
Slightly Over Built
DieselS10's Avatar
It waits patiently.
Old 08-04-2008, 01:40 AM   #643
wrekd's Avatar
4dr LS
Yeah its probably the same as mine then.
Baggey, cant wait to see the flex pics
Old 08-04-2008, 11:08 AM   #644
Baggey22's Avatar
I'm on dial up right now because satellite internet SUCKS!!! DON'T EVER GET IT!!! So I can't upload the pictures to photobucket because it's too slow.
But NEVER FEAR! I'm going to take the pictures to my buddy's house later this afternoon and load them onto photobucket from there. Then I'll post them up here.
But I have another question for Donahue or Wrekd. Tim was WRONG (ha ha) and my XJ drive shaft is too LONG (not short TIM) so I'm just going to make it out of square tube. My Tcase yoke and D30 yoke are 29 inches apart what length (and size) tube would I need to buy? Don't forget I'm going to use the CV joint as well. If I get the info by the time I go to my buddy's house I may be able to get the DS bought and made tonight or tomorrow. Let me know!
Old 08-04-2008, 01:01 PM   #645
Baggey22's Avatar
Well you guys are LUCKY my satellite internet came back. I got the flex pictures uploaded. So here they are!
So there they are. I still need that square driveshaft info!!!!
Old 08-04-2008, 03:11 PM   #646
Fvck New Jersey
Tim99Zr2's Avatar
i can go measure my DS for ya. i went a PTO route. it was nice to use.
i thought my xj shaft was too short. it could of been to long also, i dont remember
Old 08-04-2008, 03:12 PM   #647
Fvck New Jersey
Tim99Zr2's Avatar
btw, pics look good man!!
Old 08-04-2008, 03:22 PM   #648
Fvck New Jersey
Tim99Zr2's Avatar
ok, triple post buddy!!!
this is how mine is, for now.
25.75" CTC on the universals on the DS
19.25" Outside shaft length
3" Inside shaft showing (slipped out)
28.25" Outside universal to outside universal (Yokes on the tcase to axle)
when i measured off a universal they were CTC.
do you understand those lengths? if not, i can MS paint it up for ya!
Old 08-04-2008, 03:24 PM   #649
Baggey22's Avatar
I don't think measurements from your driveshaft will do me any good Tim. I just need to know what size (OD and wall) tube and what lengths the two pieces need to be so I can get them today or tomorrow. Also some info on how to make it would be excellent too. I know I've seen Wrekd and Donahue with square front driveshafts so I know SOMEONE knows what I need.
Old 08-04-2008, 03:32 PM   #650
Fvck New Jersey
Tim99Zr2's Avatar
here you can see the 3" of the inside shaft hanging out.
here is how i bought it at tractor supply for around 100$ (its on the bottom)
Page generated in 0.69760 seconds with 32 queries
[Output: 214.80 Kb. compressed to 195.93 Kb. by saving 18.87 Kb. (8.78%)]
