Project: 1995 s10 SAS
This is my build thread. I decided to start the thread today even though my swap starts tomorrow just so I could get the "before" stuff done with.
So this is my 1995 s10, her name is Sally. I bought her for $600 from this redneck. Heres what she looked like the day I bought her: http://i121.photobucket.com/albums/o...g?t=1203640954 http://i121.photobucket.com/albums/o...g?t=1203640959 She came with 31" BFG A/Ts that were nearly bald with NO LIFT. So I knew I had to do a BL at least very soon. So a few months later after I got some mechanical things fixed I did the BL. After the body lift was done I drove it around for a few months just to make sure the motor was good and everything was working out good. Then once my tax refund came in I bought new tires. I got 31" Retreads from High-Tech retreading. They SAY BFG A/T on them but they were a M/T. http://i121.photobucket.com/albums/o...g?t=1203641163 After the tires I noticed that because my truck was a long bed s10 I kept dragging the rear end a lot when going up/down hills. So I "bobbed" the bed. http://i121.photobucket.com/albums/o...g?t=1203641238 http://i121.photobucket.com/albums/o...g?t=1203641251 I cut approximately a foot off the bed of Sally and I am very happy with the way it came out. After it was bobbed I went off-roading every chance I got. Then one day I got stuck for the FIRST time. http://i121.photobucket.com/albums/o...g?t=1203641349 It was at this moment that I decided that 31" tires weren't enough for the trails here in Vermont. This brings me to today. I have slowly been buying ALL the things required for doing a SAS on an s10. I've done about 4 months of research looking at lots of different swaps and asking lots of questions getting everything figured out. I'm going with a HPD30 and 8.8 combo, both geared to 4.10. The 8.8 is also a LS axle. I got both axles more than a month ago and have been cleaning them and preparing them for the swap in the basement of the theatre I work at. I don't have many pictures of the axles because I've been scrambling to get them done and mostly just forgot to take progress pictures. Tomorrow around 1:00pm Sally will be driven onto a trailer and driven down to NY. For a week I'll be working NON STOP to get the swap done and will be taking progress pictures as I go. I hope you all enjoy my swap, that is all for now. |
Registered Asshole
Location: Moscow, PA / Mansfield, PA User is: OffLine |
Re: Project: 1995 s10 SAS
im excited... i can't wait to see how this goes for you. maybe you could even put it up for sale after its almost done!
Fvck New Jersey
sweet man! 14 hour long days will be your friend!!
Looking forward to seeing how it goes
Who needs 4x4
man i wish i could find a long box for that cheap.
Fvck New Jersey
Shit, almost forgot.!!
My only concern is that I only have a week in a garage. So I'm gonna concentrate on getting the front done and if I have to do the rear back at college.
Mcfly Minis inc
where in NY are you doing it?
WTF?
Fvck New Jersey
werd,doing my rear only took me MAYBE 5 hours. from taking the tires off to putting them on. id get the front rollin first.. or just do it on the trailer? so if you fail you can haul it to me to finish it ![]() |
I Rather Be Wheelin'
I'd concentrate on just getting the front end put together so it's drivable, and then work on the details later in case you run outta time.
Just put Sally on the trailer. I'm now leaving to drive to NY to put her in the garage and tear it down. Wish me luck!
Good luck!
Fvck New Jersey
awesome man, its a fun time!! post pics of progress fool!
Update: Day one is over. I got ALL the front suspension and front differential out. All that's left of the original equipment is the pitman arm and drag link and the drive shaft.
Tomorrow I'll get the front cross member bolted on and and all the old brackets I don't need cut off. Today was a good day, worked a lot and didn't run into any major problems. I'll get some pictures either tonight or tomorrow. |
Scoop
Keep on going, no problems is always a plus and helps to make you work more the next day. Just don't get in to big a rush as that's when the problems crop up.
Fvck New Jersey
fun fun, get some pics up man!! cant wait to see it
Fvck New Jersey
baggey, show this site to your old lady and make her update us!!
P.S. i made my tranny cross member today, lemme know if you want pics |
nice ride, i have similar roll bars on my truck, i welded 2 extra light brackets on it
Update: Today I got the front cross member bolted on and hung the front of the leaf springs. After that I got the stock pitman arm off. Finally today I got the D30 bolted into place to make measurements and such so I can fabricate the rear shackle mounts tomorrow.
I think I may also swap the 8.8 in tomorrow because everything is going so well. I still have some brake issues to deal with on the D30 before I'm done but those won't take but an hour to figure out and finish. I'll get some pictures up when I can. I don't have my camera with me, but I'll see what I can do. |
sounds good lets see these pictures
#24 |
Fvck New Jersey
put yours further back than i did. about 4-5 inches i am redoing mine. that should work out to be right after the charocol canister |
#25 |
S-series Member
Remember Baggey, that those springs I built for you will be just over 54" long when fully compressed with the front end weight sitting on there. Build accordingly so that your shackle angle is between 15-25 degrees back.
Front first. Weld everything on the front except for the perches and shock tabs. Once the tires are on the front axle, then move to the rear. Weld the perches on both axles 2nd to last, finishing with the shock tabs. Call me if you need to. Last edited by lilsonoma : 02-25-2008 at 11:17 PM. |
#26 |
Fvck New Jersey
yep yep! i made my shackle hanggers too close to the front of the truck i got a horrible shackle angle |
#27 |
couldn't you just lengthen them to correct or would you need them shorter to help
#28 |
3 Leaf Fab
tim, your shackle angle is great if you were going to lots of droop, and only droop. for my brothers sami, we set the angle pretty far back, more than you would probably want to for a street vehicle, its about 45-60* with the weight of the body on it. its nice and flexy, but would have pretty good body roll at any speed above 25 mph or so. we also lengthened it to give it a better (more vertical) angle while still keeping it ahead of that stock crossmember (isuzu frame). iirc, the shacles are like 7 or 7.5" long bolt to bolt. on a side note, they were also made from 3/16" with no side brace and now have a nice jog in them about 1"-2" over (they will be replaced before he goes out again). ![]() |
#29 |
IIRC the easiest way to get a good shackle angle is to have the shackles be vertical when the axle is at "full droop"
Like with the front of the leafs bolted on wherever the rear eye sits is where the shackle mount should go directly above it. Is that correct? |
#30 |
S-series Member
If you must use the springs as a measuring device, measure their static spring eye measurement. This means without any weight on them, probably as they sit now. Keep 54" long in mind when positioning the shackle hanger, and you'll most likely have the shackle facing forward quite a bit until weight is pressed down onto the springs, where the shackles swing back to the correct angle facing towards the rear of Sally. Don't forget to take the bushings out of the Sky shackle mounts, otherwise you'll burn up the bushings when welding. Last edited by lilsonoma : 02-26-2008 at 11:41 AM. |
#31 |
3 Leaf Fab
#32 |
Fvck New Jersey
this thread sucks.. baggey has not posted pics of progress!!! FAIL!
#33 |
WTF?
#34 |
I'm sorry about the lack of pictures. I have to use my g/f's father's laptop to even update you with words and I don't know about uploading pictures yet. I have pictures, you'll just have to wait.
#35 |
Fvck New Jersey
close thread....
#36 |
Fvck New Jersey
how is it coming? any problems yet?
#37 |
So far every "problem" has been solved. Like the pitman arm was a problem but it was solved a few hours later. Now I need to find the correct Ujoint to go from the S10 drive shaft to the 8.8 rear axle. Tomorrow everything gets welded up. On Thursday I'll be doing all the brake plumbing. The project is really coming together
#38 |
Fvck New Jersey
Sweet. go take some cell pics and email them to me, so i can post um up!glad its coming along well man, (i think i get my new tranny tomorrow or by this weekend at least) P.S. i got my tranny cross member made if you want pics of it |
#39 |
Just put the pics of your crossmember in your thread and I can check them out later. I won't be doing that until after the swap anyways
#40 |
Fvck New Jersey
kk. ill get them when i go back to the garageee, i was going to go pull my tranny tonight.. didnt make it too far |
#41 |
S-series Member
Sorry Baggey, I looked all night for the correct conversion joint and fell asleep at the keyboard. Woke up with wertyuiosdfghjkxcvbnm in my cheek.
Good luck at the parts store.For the time being, weld everything up except for the perches and give me a call tonight around the same time we spoke yesterday. |
#42 |
I got the correct conversion joint at an auto parts store. It took all of like 4 minutes for the guy to find it.
#43 |
S-series Member
What's next on the list? |
#44 |
Registered Asshole
i'm gettin even more anxious! i want pics asap!!!!! glad everythings going so smooth for ya!
#45 |
Fvck New Jersey
just like my pitman arm ![]() |
#46 |
Registered Asshole
#47 |
got SFA?
you can just buy an s10 rear joint and an explorer rear joint and such the two caps from s10 to explorer and it will work. they have the same size joint shafts if you will.,
#48 |
I got the Ujoint at a Bond Auto Parts. The brand is Precision and the number on it is 355.
I could have just bought two, but that would have cost me like thirty or more dollars. This conversion Ujoint was eighteen ![]() The next thing is to get the brakes situated. Unknown to me until recently the guy (A$$HOLE) that sold me the D30 put CJ7 caliper mounts on it. So when I tried to get calipers and pads for it they wouldn't fit. Well I finally figured it out last night because the mount had an AMC stamped on it and I remembered that in the 70's CJ7s were made by AMC before Chrysler bought them out. So I went to a junkyard at 8:00 this morning and now I'm just waiting for them to pull the correct bracket off another YJ to put on mine. They are like $35 a piece but I only got the axle for $50. The lesson here is don't get a cheap axle, you get what you pay for. I'm guessing the guy that sold me the axle just wanted a quick $50 and was REALLY skeptical when I told him what I was doing with the axle. Beyond the brake situation thats being resolved all I need to do is run some brake lines and bleed them, have the drag link welded up (being done at 4:00 TODAY), and do one last check of EVERYTHING to make sure it all works out. Just so you all know I've been taking process pictures, well my g/f has. So on Sunday when I get back to my apartment I'll upload them so you can see the process. |
#49 |
give me your old cv axles
#50 |
They are both toast, I cranked the Tbars before I decided to go SFA and then went offroading and tore the boots on something.
BUT I do have a 10 bolt with a mini spool. I know you were talking a while ago about getting a posi or something. |
