#201 |
Re: Lets See Your SFA S-10
Is that a LP44 up front??? |
#202 |
its a highpinion dana 44 out of a 79 f250
#203 |
#204 |
3 Leaf Fab
#205 |
#206 |
![]() This is what i started with. :P ![]() My progress so far ![]() Tried to resize pics but couldnt get it to, sorry that they're a bit oversized. Last edited by Helton_S15 : 04-19-2009 at 08:18 PM. |
#207 |
GAVE his truck to 96super
you only have a SRA it clearly states SFA lol jk are those fullsize springs?
#208 |
i'm gettin there
just been waitin on the rain to stop. fullsize axles and springs. i got 'em all of a guy for $250. that was for both axles, which included springs, complete steering, and other stuff, even all the bolts. its a dana 44 front and a 12 bolt rear off a '77 GMC 4x4. |
#209 |
good set up but is the front axle passenger drop? and you wont see much flex out of those springs unless you pull a leaf or 2 or soften them up
#210 |
3 Leaf Fab
the springs should flex well enough. the steering however, unless the previous setup was crossover, you are still going to need to do some work to get it to work.
#211 |
it is a passenger side drop, and i'm also getting the rough country 4in lift kit to go with this as well for $309.
#212 |
3 Leaf Fab
just to let you know, a rough country lift kit is going to be fairly stiff. those kits ride like tanks on a full size, they are going to be worse on an s10.
#213 |
the ride doesn't matter too much to me i have another truck to use as a daily driver. this is just gonna be a truck to play in the mud and take down to the rod runs
#214 |
local engineer
what is the purpose of having the winch hooked up to the front axle?
#215 |
local engineer
refering to post 180
#216 |
Huge Ideas, Tiny Wallet
#217 |
![]() Still tryin to find time to cut away the front with all this rain, but i was able to put in my 4in lift kit in the rear with my 35x12.50s. Got the lift kit and 4 wheels/tires all for $200. |
#218 |
3 Leaf Fab
#219 |
Looks like a flip with blocks too.
#220 |
the rear is a 78 12 bolt with a 4in rough country blocks under it for now and its 4 in lift springs in the front.
#221 |
#222 |
Helton it looks like your truck means business...now for some springs and steering linkage.
Just a recommendation...find a different way to lift the rear. The comb. of spring over and lift blocks plus your V8 is gonna make for some mean axle wrap.. Good luck...at least you're making some progress...unlike me, I'm too broke to do anything right now....dangit ![]() |
#223 |
Yeah it does. Waiting on some parts to come in from sky manufacturing then i'll get to finish the front.
I do plan on gettin' rid of the blocks in the back, i got the 4 in lift kit and all the whells/tires from a guy for only $200 so for right now as i do the swap they will just do fine. I couldnt beat the price. thanks! I'm doin all this one pay check at a time. I'm just a server in a little pizza shop, and i'm havin to do all this with just the basic hand tools and a grinder with a cut off wheel. People said i couldn't go thru and finish this project in the beginning, now they are sayin' otherwise. haha |
#224 |
Fvck New Jersey
man, make your own thread, quit using this one.. its supposed to be of your already SFAd truck. and technically yours isnt even SFAd yet.
#225 |
oops
#226 |
Plus if you make your own thread you can do like Tim and talk about useless nonsense for like six pages without even mentioning the truck.
#227 |
Slightly Over Built
#228 |
Fvck New Jersey
thats my point. |
#229 |
Its still a nice looking truck though Helton
#230 |
WAIT tim has a truck? from looking at his thread all i found out was he just got a job and doesn't like PURPLE diff covers
#231 |
yea, he doesn't like them . . . he loves them
#232 |
lol
#233 |
Fvck New Jersey
![]() the new look99 sonoma highrider: 128k, 4.3vortec, 5spd swap, 4wd, np231c tcase, dana 44 full spool, ford 9" lincoln locked , 5.13s front and rear, true duals, 2" body lift, ~8" suspension lift, 37" boggers, custom bumpers, 14" travel bilstein 5125s, PIAAs, custom trail damage to the body, cross over steering, heavy duty tie rod, 36" spare, lexan rear window, new warn hubs prob missing things. ![]() Sorry you cant post pics here Bubba ![]() |
#234 |
Slightly Over Built
HAHA, that was cold!
Truck looks good though. |
#235 |
Registered Abuser
Werd, I like the new setup!
#236 |
tim99zr2 do you have a thread or any info on how you did the 5spd swap? truck looks kickass by the way
#237 |
tim99zr2 do you have a thread or any info on how you did the 5spd swap? by the way your rig is looking kickass
#238 |
that was REALLY MEAN but i have good news and bad news,
Bad: S10 wont see the road for a bit BECAUSE Good:amazing deal on a bagged and bodydropped ranger aka I finish putting the motor in my napa truck Daily Driver then finish up the bagged truck then I finish the SAS on the s10 i feel bad but i cant pass up this deal its TITS |
#239 |
btw i DO have a SolidFrontAxle but its not "connected to the s10"
#240 |
hay I was looking threw the post and I got to say very nice rides. thought id post some of mine see what you think.
http://i623.photobucket.com/albums/tt316/808mills/OffRoad155.jpg |
#241 |
#242 |
Nice truck. I like this pic better. BTW what are the specs on your truck?
#243 |
My specs
91 ext cab 4.3 700r trans, was 2wd converted dana 44 frnt & rear 5.13 gears detroit locker/rear detroit truetrac/frnt alloy usa axles custom divorce 300 transfer case one piece drive shafts/ same length frnt/rear custom high steer knuckle/ crossover steering 15-10 aluminum rims/ 35inch por comp MT frnt springs 6inch chevys full size with custom shackles rear spings custom leafs added to stock pack/ 6inch block custom frnt/rear pipe bumpers/work lights 16inch electric fan/ urethane mounts/ on board air compressor interior custom sounds dvd player neoprene seat cover rhino line bed |
#244 |
So my job has changed owners and i'm in the process of possible unemployment becuz he sold the business, so i cannot finish this... would anyone be interested in buying any parts?
~Brand new, never been opened sky-manufacturing sas kit~ ~Front Dana 44 w/ 3.73 Gears (Passenger Side Drop)~ ~Rear GM 12 Bolt w/ 3.73 Gears w/ New leaf perches to fit the s10 frame (not welded yet)~ ~4 inch lift kit (Springs in front and blocks in back)~ ~Th350 transmission with transfer case~ ~35x12.50 tires w/ 6 lug chrome wheels~ Could sell individually or as a whole. Everything to convert a 2wd to a monster 4x4.. My loss is your gain... |
#245 |
where are you located?
#246 |
i am interested in the 35's(maybe without rims if possible) and the sky kit
#247 |
just east of knoxville, tn
865-654-5898 text if anyones interested |
#248 |
Fvck New Jersey
shit, now its your classifieds section. not only your project thread.
#249 |
No shit isnt that why we have a classifieds section?? |
#250 |
x3...Why the fvck do you keep cloggin up this thread with your useless BS. You wanna sell shit, there's a classified section. You wanna give us updates on your POS, make a fvckin build thread.
Lets See Your SFA S-10= Lets see your completed SFA S-10, not Lets See Your In Progress S-10. Is that so hard to understand??? ![]() |
