Lets See Your SFA S-10
Old 11-12-2008, 10:40 PM   #51
white wall member
tolowinorlando's Avatar
Re: Lets See Your SFA S-10
Quote: Originally Posted by Donahue
all mine is lacking in oregon to be street legal is fender flairs and mud flaps, and maybe a second mirror on the side of the truck. it is licensed and registered.
haha nice so corect me if im wrong but you can drive with no doors. i figure yes like a jeep but i thought you could only do that on a truck, suv, ect. that was made like that from the factory.
Old 11-13-2008, 01:39 PM   #52
greythorn3's Avatar
thank you! and i like putting them old 6.9 international diesels in my old fords! love the non turbo mechanical diesels..
Old 11-13-2008, 08:56 PM   #53
Slightly Over Built
DieselS10's Avatar
I wish mine was mechanical injected! All the computer controlled crap on mine is annoying. I might give in and build a new 6.5 with the new AMG block & heads, Scat crank & rods, marine pistons, an A-team turbo, and a mechanical Peninsular marine pump. That combo ought to get me around 400-425hp and around 700-750 lb/ft of torque, it will be enough to make me smile anyway.
Old 11-17-2008, 10:22 PM   #54
gump...
gumpsblacks10's Avatar
here are some pics of mine...
Old 11-17-2008, 10:35 PM   #55
bodydroppeds10's Avatar
Nice start gump, hope to see more pics as you go
Old 11-18-2008, 01:02 AM   #56
cool to the tool
shiftit's Avatar
Old 11-18-2008, 04:05 AM   #57
Registered Abuser
Merritt's Avatar
Nice truck shiftit!
Old 11-18-2008, 10:33 PM   #58
Slightly Over Built
DieselS10's Avatar
ASK HIM IF HE CAN DRIVE IT YET??????
Old 11-19-2008, 05:43 AM   #59
greythorn3's Avatar
looks like that s10 pickup was jus tplaced on a bronco frame or f150 from the 70's
Old 11-19-2008, 06:12 AM   #60
whore turned lurker
dimerunner88's Avatar
i only see s-10's on s-10 frames, which one are you talking about?
Old 11-19-2008, 07:15 AM   #61
greythorn3's Avatar
black on with the blue hood? could be a body lift though.. looks further away from teh frame then normal.. i think im going to use full width axles on my 96 blazer and then run offset like on hummer rims.
Ray
Old 11-19-2008, 07:50 AM   #62
whore turned lurker
its an s-10 frame i recognize the rear section,along with the front bumper mounts and it appears to have aluminum spacers for the body lift.
Old 11-19-2008, 08:10 AM   #63
Fvck New Jersey
Tim99Zr2's Avatar
right on skippy
Old 11-19-2008, 03:15 PM   #64
Hey greythorn check out my blazer on here. Its the red 95 4 door. I have full width axles under it, sittin on 38.5's
Old 11-19-2008, 07:39 PM   #65
Slightly Over Built
DieselS10's Avatar
Mine, Gump's, and Donahue's are all full width also.
Old 11-19-2008, 10:47 PM   #66
wrekd's Avatar
You forgot me
Old 11-19-2008, 10:51 PM   #67
Slightly Over Built
DieselS10's Avatar
Quote: Originally Posted by wrekd
You forgot me
Woops! I was having a brain fart.
Old 11-19-2008, 10:55 PM   #68
wrekd's Avatar
Old 11-20-2008, 06:18 AM   #69
Fvck New Jersey
Tim99Zr2's Avatar
Old 11-20-2008, 10:21 PM   #70
Slightly Over Built
DieselS10's Avatar
Quote: Originally Posted by Tim99Zr2
Yours isn't fullsize full width is it?
Old 11-20-2008, 10:41 PM   #71
greythorn3's Avatar
well i think i will run a d44hd 8 lug up front with radius arms from a bronco and run a dana 70u in the back 8 lug.. both with 355 gearing since thats what i got laying around.. so it will be leafs in the rear and coils in the front.. should ride nice... who knows it could change by springs though. the part i dont like is tryin to figure out what i need to do to that crap transfercase thats in it.. it has a weird connection and no yoke for the front shaft.
Ray
Old 11-21-2008, 06:14 AM   #72
Fvck New Jersey
Tim99Zr2's Avatar
no, i wish.. that would mean bigger axles. haha
Old 11-22-2008, 03:05 PM   #73
83 s15 496 stroker th400/205 14bolt D60 sitting on 38.5's motors been taken out rebuild and cleaned up since pics
Old 11-22-2008, 10:26 PM   #74
Slightly Over Built
DieselS10's Avatar
That's a wild ride, what do you do with it, crawl, mud racer?
Welcome to the forum.
Old 11-23-2008, 03:05 AM   #75
greythorn3's Avatar
very nice.. i like leaf springs they are simple!! maybe i should just go leaves with my extra dana 60 hp ford front axle i got here!!
Old 11-23-2008, 03:16 AM   #76
i kinda use it for little of every thing. but mostly mud.
i plan to 4-link it just didn't have time when i built it.
Old 11-23-2008, 10:46 PM   #77
93Vortecon30s's Avatar
heres mine not done yet but getting there...
Old 11-24-2008, 02:14 AM   #78
greythorn3's Avatar
nice, is all it got is a body lift? looks pretty tall! i want to fit up to 31's some day...
Old 11-24-2008, 10:01 AM   #79
Slightly Over Built
DieselS10's Avatar
^^^There are leaf spring hangers under the front of the frame, so more than a body lift.
Old 11-24-2008, 08:07 PM   #80
jphayes921's Avatar
nice for $500
just got it out of the garage yesterday still doing some work.
Old 11-24-2008, 10:29 PM   #81
Post up some info on it
Old 11-25-2008, 11:35 AM   #82
jphayes921's Avatar
its a 92 extended cab. 4.3 vortec. dana 30 front and dana 35 rear, open diffs 3.73 gears. doesnt need gears but lockers and some bigger gearing sounds good. 32" goodyear wranglers, by the way are custom grooved by the person who owned it before me, also they are brandnew(worth more than the truck in rims and tires,lol). ill try to get some better pictures up tonight or tomarrow. its got axel over and custom but kinda shi**y high steer. needs shocks in front. and the front sfa brackets need some rewelding or just new parts. the sfa job on this truck is half a**ed and I think they just tried to get it done and didnt care how it look. some of the ifs bracketry is still on and need to be cut off. but overall it runs like a champ and has no problem going through a couple feet of snow.
Old 12-01-2008, 08:30 PM   #83
Missourileo's Avatar
Just signed up on here. Saw this thread and thought "Hey, let's put my unfinished Zr2 on here." It should be done soon....lol.
Old 12-01-2008, 08:48 PM   #84
Pics would be nic wouldn't they.....I got timed out.
Old 12-01-2008, 10:18 PM   #85
greythorn3's Avatar
very nice! what front springs are you using?
Old 12-01-2008, 11:34 PM   #86
Slightly Over Built
DieselS10's Avatar
Welcome to the forum and nice work, keep us posted as it progresses.
Old 12-02-2008, 08:44 AM   #87
Welcome to the forum. Nice start. Post up some info on it or what your plans are for it
Old 12-04-2008, 12:51 AM   #88
Rustbucket Club
LikeaRock's Avatar
Quote: Originally Posted by shiftit
Are your upper arms coming off the lowers, or is that just the way the pic shows it? If they are connected to the lowers, how does that work out for you? The more I think about it the more I want to SAS 1st generation, might as well do a 4-link if I'm going through the effort
Old 12-04-2008, 03:23 AM   #89
GAVE his truck to 96super
bubbagt57's Avatar
cant wait till i can post in here
Old 12-06-2008, 12:41 PM   #90
cool to the tool
shiftit's Avatar
The upper arms are all attached to the frame, not the lowers. A leaf setup definitely would be easier, especially if you dont want to do the math to figure out angles and mounting points. My main complaint right now is I still have some bump steer thats pretty annoying.
PS good luck, start a thread of your progress when you do your SFA conversion.
Old 12-06-2008, 09:14 PM   #91
Slightly Over Built
DieselS10's Avatar
Are you running a pan-hard bar on the front?
Old 12-09-2008, 09:06 PM   #92
3 Leaf Fab
Donahue's Avatar
its legal in oregon to drive with no doors, as long as there are two rearward facing mirrors.
Old 12-10-2008, 12:12 AM   #93
cool to the tool
shiftit's Avatar
yes
Old 12-10-2008, 01:32 AM   #94
Slightly Over Built
DieselS10's Avatar
yes
Is it at the same angle and the same length as your drag-link?
Old 12-11-2008, 07:11 PM   #95
BigBoy70's Avatar
Still in the works , first run is gonna be New Years
Old 12-11-2008, 07:14 PM   #96
wrekd's Avatar
Specs??
Old 12-11-2008, 08:22 PM   #97
Yeah post up some specs on it. Good start
Old 12-11-2008, 08:25 PM   #98
cool to the tool
shiftit's Avatar
yes, well as close as I could get it. But apparently I didnt get it close enough. I might have to figure out a more accurate solution.
Old 12-11-2008, 09:33 PM   #99
greythorn3's Avatar
looks good, same green as mine! pbblaster is the liquid of gods.
Old 12-11-2008, 09:37 PM   #100
Fvck New Jersey
Tim99Zr2's Avatar
your shackles look fvcked. why they "bent"?
Page generated in 0.65984 seconds with 32 queries
[Output: 216.30 Kb. compressed to 197.35 Kb. by saving 18.95 Kb. (8.76%)]
