Lets See Your SFA S-10
Figured this would be a good way to get this going, so heres a few of mine:
Fvck New Jersey
Re: Lets See Your SFA S-10
ill get some up tomorrow. just found a big rock to flex on!
im tuckin 33s on it! |
3 Leaf Fab
Slightly Over Built
Gotta love those action shots guys, keep 'em comin.
Thanks. Its a one off custom high clearance one. I made it myself That will be fixed by next week |
Fvck New Jersey
here is one for now. i had to cheat to get on the rock. my 4LO is messed up yet.
i got more on my camera, but im not home. this will do for now. ![]() |
Fvck New Jersey
ok, for some reason it wasnt tuckin as hard today. but they are still cool pics. time to whore. ill bump my members rides thread with a few more pics. not posting all ten here.
Slightly Over Built
Since I don't have any current "action" pics, since mine is still an open diff'd poser, I post up some pics of it from it's previous life before this last build.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And a few in it's current state. ![]() ![]() ![]() |
Banned
you SFA guys need to upgrade to IFS!
Slightly Over Built
Yeah, not replacing parts all the time and having a dependable front end sucks. ![]() |
Banned
LOL
Yeah doesnt that suck ![]() |
PANFACE
wrekd, what is your frame ground clearance?
I think its around 23-24" |
Registered Abuser
Nice rides everyone!
Ok, figured I would post up a few of my blazer. Still tryin to finish the front bumper alittle. Nice pics though from everyone so far.
That front bumper is looking good. Got any more close up pics of it?? What did you use to make it??
I used 2x2 square tube. All the pics I have are on my photobucket account. Here is the link http://s473.photobucket.com/albums/rr92/rattles69/
Fvck New Jersey
very nice body dropped.
yea wrekd mine is around that height too. |
Yeah thats a sweet bumper. Are you gonna add pieces coming from the sides down near the crossmember too?? i hope you dont mind cause Im probably gonna copy your design Last edited by wrekd : 11-05-2008 at 07:39 PM. Reason: edit |
Yeah man the front bumper isnt finished yet. I still have some things to finish up on it and make a few more things to weld on. You can copy if you like I guess. Thanks for all the compliments.
Part of a minority
You guys have some seriously sweet rigs. I really like SFA's on the S series.
The first gen (at least) should have had them factory. Another mistake by GM. |
#24 |
Registered Abuser
That is a very sweet blazer bodydroppeds10!
#25 |
Thanks Merritj. Wrekd the 2x2 is 1/4inch. Its a little over kill but oh well.
#26 |
Still 2 High
I want a SFA soooo bad
I think I wrecked another half shaft last night ![]() |
#27 |
Fvck New Jersey
find some axles ![]() |
#28 |
3 Leaf Fab
mine is 27.5" under the frame rail. i was shooting for 24" but the springs didnt settle as much as i expected. Last edited by Donahue : 11-06-2008 at 10:41 PM. |
#29 |
white wall member
#30 |
3 Leaf Fab
#31 |
white wall member
i dident factor in stability, so i guess it could become a problem at times but i will say of all the lifted and sfa trucks on this forum i like yours the most. i like the fact that you have a chop top and no doors but i have to ask is you truck in any way shape or form steet leagal
#32 |
Still 2 High
Could I get away with keeping the stock rear axle and the stock transfer case/tranny? |
#33 |
Mine measures 28" from floor to bottom of frame rail under drivers door
#34 |
with 3-4 pounds of air in the tires mine is 26 '' to the bottom of the frame rail. could be 27 or 28 inches if I had 18 pounds of air
#35 |
I just posted in the newbies thread but i thought i would add mine also It isnt done yet but hopefully soon I will be able to go tear it up
#36 |
Fvck New Jersey
yea you could chris.
and that red 1st gen is tits |
#37 |
3 Leaf Fab
#38 |
Slightly Over Built
Nice build Archie. Can we get some specs on that thing?
I measured mine to the bottom of the frame right under the back of the door today and it varies from 17" to 32", but I drive it around at about 25-26ish, it seems to ride the best at that hieght. |
#39 |
Ya i need to start a build thread. It is a 84 that started life as a 2wd and now has a stout 327 that im building not done yet. with a th350 and np 205, dana 44 and corprate 14 both locked want 60 front, 52 inch leaf packs up front with a 4 link rear and mid 60s stretched impala rear springs. cut it down to a 125 in wheelbase, will have a full exo tied into a tube bed. 39.5 iroks would like boggers.
thanks for the replys the diesiel s10 that is sick seen your for ok when this is done planing on going to disney |
#40 |
Slightly Over Built
That thing will be a blast at Disney. With that wheelbase and tire size it should go where ever you want it to there.
#41 |
Registered Abuser
Nice truck Archie.
#42 |
#43 |
Stock NP233 with a fixed yoke front output shaft |
#44 |
how do you change the yoke on it? mines got some stupid looking joint on the drive shaft and its a 96 also.. Ray |
#45 |
You have to swap in a front output shaft from a manually shifted 88-97 s-10 NP231C t-case. You have to tear down the t-case to do it. |
#46 |
Or do what I did and just swap in a NP231C which can be found in a lot of first generation s10s. Try to find one with the long rear output slip yoke. then if you go with a Jeep front drive shaft (like I did) you can easily change the front output yoke by just spinning a nut off then putting the new one on.
#47 |
well i converted a k1500 1997 to sfa.. but what i did was use a th400 np205, is there a reason you dont use a np205 for a th350? is it just so you can keep the stock cable shifter or somthing?
#48 |
Slightly Over Built
Not to speak out of turn, but weight, 2:1 low range vs 2.72:1 and they are already in the S10's.
#49 |
#50 |
Slightly Over Built
And welcome to the forum. Last edited by DieselS10 : 11-12-2008 at 10:32 PM. |
