How do I get rid of the ABS light?
I have a 1998 s-10 blazer with a Dana 30 axle under the front. I took the ABS box out and run new lines from the brake master cylander to the brakes, but the ABS light still stays on. Is there a way to make this light turn off? I haven't unplugged any ABS fuses yet, Would that help? (is there any fuses other than the fuse box under the hood and on the side of the dash when you open the drivers door?) Or could i cut one of the plugs that go to the ABS box and wire them together?
4blow
Re: How do I get rid of the ABS light?
take out your gauges and take it apart. the light is atached to the boad. brake it off. or have some burn it out of the computer.
Dirty Sanchez
it should turn off when you completely disconnect the ebcm. if not, try the fuses, it think that would be easier than messing with your gauges.
4blow
Dirty Sanchez
turned mine off by disconnecting the ebcm
slap a sticker over it....lol
Dirty Sanchez
Slightly Over Built
A hammer and punch will get every time.
Well I pulled the fuse and nothing, so I took the dash apart and seperated the insrument cluster and pulled the light out. It solved the problem.
^^ nice. i gotta do the same thing. I completely disconnected mine and it didn't work. Oh well.
Dirty Sanchez
maybe mine is special
6" from hell
isnt it just a lite bulb that you just twist out or is that a first gen thing
I think I lucked up and my ABS light began to "dim out" and now is almost completely out. I love it.
