Dana 30 non disconnect front axle.. issues with transfer case - S-10 Forum
post #1 of 4 Old 04-12-2012, 06:41 PM Thread Starter
User is: cruzn56 is offline
question: Is there a problem with putting in a Dana 30 non disconnect axle in for a SAS swap 92 S10. Have access to this unit for a swap. Does not having the disconnect effect the driveablity of the truck when the transfer case is in 2wd. Or is there just extra wear and drag on the components if the front axle does not disconnect?
Opinions? answers?
Thanks
cruzn56 is offline
post #2 of 4 Old 04-12-2012, 07:37 PM
Cwhite138's Avatar
User is: Cwhite138 is offline
Re: Dana 30 non disconnect front axle.. issues with transfer case
read some threads, NM super flow are good starts for the 30. this is info is every where. options are 404s.
post #3 of 4 Old 04-12-2012, 10:17 PM
Life's too short for IFS
KM346's Avatar
User is: KM346 is offline
With a non disco housing the front drive shaft will spin all the time, just like it does in the jeep it came out of... make sure your front drive shaft is balanced and its a non issue. Only negative may be a little less fuel mileage vs a truck with a disco housing or lockouts.
Cwhite did you even read the question? LOL
-2001 Blazer 4x4 SAS'd: Ford and Jeep junkyard parts mixed w/ random overpriced custom stuff
KM346's Build: The Refrigerator
-1999 GMC Sonoma 2wd LS swap in progress: 6.0L LQ9/ 4l60E with 3K stall and 4.10 gears.
KM346's Build: The 6.0ma
Waggy/Rodeo D44 waiting for the Fridge V2.0 or another SAS...
KM346 is offline
post #4 of 4 Old 04-12-2012, 11:25 PM
NM_Wanderer's Avatar
User is: NM_Wanderer is offline
/\ /\ Well said. I have a D30 out of a 95 YJ and a locker so even with the disco my D shaft spins all the time. If you use a non disco just be sure not to lock the front if you are going to drive it on the street. I have heard of people having issues with it in 2wd and the locker locking at speed because of slick roads and causing steering issues.
2004 4dr Blazer 4.3 V6. HPD30/Ford 8.8 with 4.10's locked front and rear. Hitch cross-member, Rancho 44044 springs, 33s.
Build Thread http://www.s10forum.com/forum/f221/4...roject-436226/
PhotoBucket http://s934.photobucket.com/albums/a...zer%20Project/
