Dana 30 axle
Old 06-10-2009, 09:55 PM   #101
in garage we trust
oldskools10's Avatar
Re: Dana 30 axle
sorry nyteryda, just noticed you mentioned about the rear axle at the top of the last page . any idea on year span for the exploder axle ??
Old 06-10-2009, 10:05 PM   #102
MTchevyS10's Avatar
Re: Dana 30 axle
I think 97 & up Mountaineer and 95 & up Explorer disc brake rearends are what you would want to look for, if I am not mistaken.
Old 06-10-2009, 10:35 PM   #103
nyteRyda's Avatar
Re: Dana 30 axle
Yeah I am getting a 96 explorer axle with 4.10's some of them even had the shitty traction loc...(posi??) not bad for a start
but you need to get the yoke too and then get the adapter to link it to the s10 shaft
Old 06-10-2009, 10:52 PM   #104
MTchevyS10's Avatar
Re: Dana 30 axle
You can just run a bastard joint.
Old 06-10-2009, 11:27 PM   #105
nyteRyda's Avatar
Re: Dana 30 axle
Heh you could...but I'd rather do it my way
Old 06-10-2009, 11:32 PM   #106
MTchevyS10's Avatar
Re: Dana 30 axle
Sure.
I think I run 1 bastard joint, but the rest of the yokes I had put on the driveshafts when I had them made. I can't remember it has been so long.
Old 06-10-2009, 11:50 PM   #107
Re: Dana 30 axle
the joint really isnt a bastard joint. its readily avaible at the parts stores and was used on some older chevy cars. your local auto zone will hav ethen instock.
Old 06-11-2009, 12:23 AM   #108
Slightly Over Built
DieselS10's Avatar
Re: Dana 30 axle
I ran one for years that went from an S10 driveshaft to the 9" yoke.
Old 06-11-2009, 10:38 AM   #109
MTchevyS10's Avatar
Re: Dana 30 axle
I'm not certain, but I think that still wouldn't de-classify it as a bastard joint.
Last thing I knew, it was simply a joint that accommodated 2 different size yokes.
Old 06-11-2009, 10:39 AM   #110
MTchevyS10's Avatar
Re: Dana 30 axle
And I'm sure it ran just fine, huh?
Old 06-11-2009, 10:54 AM   #111
2UP1DOWN
tfpets's Avatar
Re: Dana 30 axle
I have an older aerostar (I think) yoke on my 8.8 that uses a stock s10 u-joint and cap straps...it doesnt have the big round flange that came with the explorer rear end...
Old 06-11-2009, 09:20 PM   #112
in garage we trust
Re: Dana 30 axle
great info ! thanks guys .
Old 06-13-2009, 02:29 AM   #113
Fvck New Jersey
Tim99Zr2's Avatar
Re: Dana 30 axle
is mine maybe a 3550? from napa... i forget the name.
Old 06-14-2009, 11:08 PM   #114
nyteRyda's Avatar
Re: Dana 30 axle
Well time for another update...I dont have pics because we finished up about an hour ago in the dark...lol, But I have the front crossmember welded in as of 9pm tonight...so now tomorrow MIGHT be the rear shackle mounts if not then tuesday...Then its all little shit after that, Just an update tho
Old 06-14-2009, 11:15 PM   #115
Baggey22's Avatar
Re: Dana 30 axle
This update is USELESS without pictures
Old 06-15-2009, 01:05 AM   #116
GAVE his truck to 96super
bubbagt57's Avatar
Re: Dana 30 axle
really
Old 06-15-2009, 01:25 AM   #117
Slightly Over Built
DieselS10's Avatar
Re: Dana 30 axle
Yep and it didn't have to change the rear driveshaft and Napa stocked the U-joint.
Old 06-15-2009, 03:34 PM   #118
MTchevyS10's Avatar
Re: Dana 30 axle
Exactly as I suspected. Very nice.
Old 06-15-2009, 05:19 PM   #119
nyteRyda's Avatar
Re: Dana 30 axle
Here you go for those whining about useless posts with no pics
Old 06-15-2009, 05:56 PM   #120
MTchevyS10's Avatar
Re: Dana 30 axle
Looks like you need to jerk out that remote filter and buy the adapter to mount the filter on the block.
Old 06-15-2009, 06:04 PM   #121
nyteRyda's Avatar
Re: Dana 30 axle
Actually I went and picked up that adapter today to be honest, Just going to wait until I can move the truck to change the oil and relocate the oil filter
but good looking out though
Old 06-15-2009, 07:09 PM   #122
dball's Avatar
Re: Dana 30 axle
looks good.
Old 06-15-2009, 07:48 PM   #123
nyteRyda's Avatar
Re: Dana 30 axle
Should have it moving by friday
Old 06-15-2009, 09:27 PM   #124
MTchevyS10's Avatar
Re: Dana 30 axle
Make sure to fill it up with some good oil.
Old 06-17-2009, 10:12 PM   #125
nyteRyda's Avatar
Re: Dana 30 axle
Well I know pictures do you people justice, but whatever.
update, Got the rear shackle hangars in with mounts, but still have to brace them and weld them good, pretty much just tacked in right now. Started to piss cats and dogs so we stopped for the night, now my issue is finding f*n u-bolts, What sizes are they, I ask a place for ubolts for a jeep axle and the look at me like im ****ing retarded...any input will do
Old 06-17-2009, 10:20 PM   #126
Fvck New Jersey
Tim99Zr2's Avatar
Re: Dana 30 axle
i went to a local semi truck repair shop and they custom bend the right size for you.
you coming friday?
Old 06-17-2009, 10:22 PM   #127
Re: Dana 30 axle
they are two different sizes so take you spring plates with you. Did you ever get a set? I have an extra pair if you want them.
Old 06-17-2009, 10:25 PM   #128
Fvck New Jersey
Tim99Zr2's Avatar
Re: Dana 30 axle
also, i wouldnt buy junk ones from parts stores. i run 5/8s ubolts.
Old 06-17-2009, 10:31 PM   #129
nyteRyda's Avatar
Re: Dana 30 axle
Yeah I have a set, and to Tim, where should I go for good ones then?
Old 06-17-2009, 10:32 PM   #130
nyteRyda's Avatar
Re: Dana 30 axle
you coming friday?
didnt even see this reply, but I am still not sure where to go for them, but yes we will be out friday to get those parts
Old 06-17-2009, 10:34 PM   #131
96superflow's Avatar
Re: Dana 30 axle
I just bought ones from quadratec. Replace heavy duty ones for a yj with stock or upgraded springs.... hopefully they will fit. i think they are rancho ubolts with a RS720 Part number. When i placed them around the d30 there looks like there will be plenty of treads there....
Old 06-17-2009, 10:36 PM   #132
Fvck New Jersey
Tim99Zr2's Avatar
Re: Dana 30 axle
hmm. what time you coming friday? if you come before 5 we can ride up to dubois and you can get some where i get mine. bout 10$ a piece. they are nice and beefy, like i said, they are for semi trucks
Old 06-17-2009, 10:39 PM   #133
nyteRyda's Avatar
Re: Dana 30 axle
It depends, my buddy kinda wants to finish my truck before we come out there, and as it stands right now, RAIN, so we will more than likely be working on it friday during the day...who knows I will be able to let you know either tomorrow or friday what time...if thats ok that is
Old 06-17-2009, 10:44 PM   #134
Fvck New Jersey
Tim99Zr2's Avatar
Re: Dana 30 axle
yea, thats fine. whenever will work. im about 10 minutes off I80. the new dubois intl airport exit.
if you come early we could get you u-bolts and go for a little wheelin ride in my truck.?
Old 06-18-2009, 05:12 AM   #135
wrekd's Avatar
Re: Dana 30 axle
Go down to Wilkes-Barre Spring. Right next to Norm's Pizza. I forget the name of the street though. But its right next to Norms. You'll probably need 2.75" axle tube(measure the tubes just to make sure) 9/16's u-bolts, around 8" long. Should be about $10 a piece.
Old 06-18-2009, 11:39 AM   #136
nyteRyda's Avatar
Re: Dana 30 axle
Sweet thanks, I know right where that is. I drove past there the other day. Yeah I just have to measure the tube the bolts are 2 different sizes
Old 06-20-2009, 04:44 PM   #137
nyteRyda's Avatar
Re: Dana 30 axle
Alright so after making a 7 hour round trip to reynoldsville to pick up my new front end, I ended up gettin back home around midnight. Didnt want to piss anyone off with an impact gun. I figured I would wait till today to finish what needs to be done.
Well I woke up early and needed to finish my steering...now my issue is I cant get the nut off from under the pitman arm. I dont know what size socket it is. Anyone with any input would be awesome!
Second for now, until I get my 8.8, I am running 3 inch lift shackles in the rear. Well I went to get them out today and ran into 2 problems.
A.) The gas tank
B.) The stupid charcoal canister
So now my issue and question is here do I cut the bolt off and just get new ones or what else could I really do?? haha
But for now I have the Noma Highrider fenders on the truck, still need to get a new core support and a passenger headlight then the rest of the front end will go on. Looking good and coming together just want to get this F*er finished.
Old 06-20-2009, 05:20 PM   #138
Fvck New Jersey
Tim99Zr2's Avatar
Re: Dana 30 axle
cool deal man, are you going to get to take the gay lawn edging off and still be legal?
i wanna see pics of this thing!
and for the pitman arm nut, i just use a big ass cresent wrench.
Old 06-20-2009, 08:10 PM   #139
Re: Dana 30 axle
I took the nut off of my pitman arm today. I used a 1 1/4" socket. I cleaned all the s$!t off of it and tapped it on with a hammer. Didn't tear up a thing. just had to put it back on the shaft to get it out of the socket. Now i just have to get a puller to get the pitman arm off....
Old 06-21-2009, 01:10 AM   #140
Fvck New Jersey
Tim99Zr2's Avatar
Re: Dana 30 axle
just smack it with a hammer. itll fall right off eventually
Old 06-21-2009, 03:37 PM   #141
bubbagt57's Avatar
Re: Dana 30 axle
im telling you for the rest of your build get a blue wrench
Old 06-21-2009, 07:48 PM   #142
runn1up2001's Avatar
Re: Dana 30 axle
i second the blue wrench, im a big fan of it.
Old 06-22-2009, 04:47 AM   #143
sewerrat's Avatar
Re: Dana 30 axle
...wats a "blue wrench"?
Old 06-22-2009, 06:23 AM   #144
Fvck New Jersey
Tim99Zr2's Avatar
Re: Dana 30 axle
torches.
Old 06-22-2009, 05:26 PM   #145
nyteRyda's Avatar
Re: Dana 30 axle
Ok got that nut off I smashed a 32mm socket onto the nut, works good enough for me. Now I need to wait till my off days to get a pitman arm puller because smashing with a hammer didnt work too well...lol...but I am getting there...slowly
Old 06-22-2009, 06:38 PM   #146
wrekd's Avatar
Re: Dana 30 axle
Yeah, i wouldn't reccommend smashing on the sector shaft with a hammer. You're just begging to break something doing that
Old 06-23-2009, 01:37 AM   #147
bubbagt57's Avatar
Re: Dana 30 axle
BLUE WRENCH heat the pitman arm and SMASH
Old 06-24-2009, 03:38 AM   #148
sewerrat's Avatar
Re: Dana 30 axle
Doesn't this destroy the sector shaft seal? Is it common practice to just replace it anyway?
Old 06-24-2009, 06:12 PM   #149
Fvck New Jersey
Tim99Zr2's Avatar
Re: Dana 30 axle
personally i wouldnt take a torch to the pitman arm while its on the truck... i could see heating the nut up with torches to break it loose
Old 06-24-2009, 06:35 PM   #150
nyteRyda's Avatar
Re: Dana 30 axle
Well thats not my problem anymore...
I had rear lift shackles to put on the truck for now, and the bottom bolts were seized up. so moral I cut apart old stock shackle and heated up the leaf spring to get the bushing out...well there is a little metal sleeves that runs outside the bushing...yeah that is seized up inside the end of the leaf spring...anyone have any suggestions??
Page generated in 0.64637 seconds with 31 queries
[Output: 208.33 Kb. compressed to 189.48 Kb. by saving 18.85 Kb. (9.05%)]
