Brakes lost pressure
Old 11-02-2009, 12:46 AM   #1
So I was driving down the road today, and my truck made a weird noise an the steering wheel swerved like one brake grabbed. Then all of a sudden I had no brake pressure. So I tried to get it home from the parking lot that it was in, sometimes it has alittle pressure, and others it has none at all. And on occation the right from brake grabs almost like abs is kicking in. I still have the abs box but no lines running to the front wheels.
Has anyone had this problem? Or any suggestions.
Old 11-02-2009, 02:03 AM   #2
chattinfarms's Avatar
Re: Brakes lost pressure
sounds like a master cylinder leaking to me
Old 11-02-2009, 03:00 AM   #3
first inspect all the lines for leaks and if none then loosen the steel lines after each unit, master cylinder and ABS unit, to check for presure loss when the pedel is pushed. fluid should squirt from the fittingswhen their loose and pedel is pushedd. just an idea???
Old 11-02-2009, 08:00 AM   #4
96superflow's Avatar
^^ do what they said. There are only a few parts to a brake system, especially if you cut out the abs.
Old 11-02-2009, 07:37 PM   #5
it was a bad wheel bering
Old 11-03-2009, 04:56 PM   #6
A wheel bearing can make the rotor rub on the brake pads as is moves during a turn or something. From how you described it I houldn't have thought is a bearing.
When I lift a vehicle with the jack on the control arm I first check tie-rod by grabbing front and back of tire and try to wobble it. Then ball joint by grabbing top and bottom and checking for wabble, but remember the weight of the car has to be on the control arm, with the jack under the arm. Its a good practice to get into, a general wheel instection. Being in the habit of toing that first when I work on a truck has saved me alot of time and also diagnosed problems in half the time. Most time the upper ball joint is bad on the stock suspension. Oddly enough I have not had to change a Wheel bearing on a S10, But have on 96 Olds Cutlass. I don't know just a little something to add!!
Old 11-05-2009, 01:17 AM   #7
yeah, I changed them on the stock suspension. Then when i solid axled i didnt change them and they finally went out.
Page generated in 0.55606 seconds with 31 queries
[Output: 59.05 Kb. compressed to 55.70 Kb. by saving 3.35 Kb. (5.67%)]
