any one running dodge Dakota springs
Old 11-19-2009, 06:48 PM   #1
crewcab rabbit's Avatar
i wanted to see if any one had any insight about running dodge Dakota spring in the front sfa. right now iam running 3/4 ton chevy 56s with the over load removed ,flex great , but i need to move my axle forward and the chevy springs are a little soft. found out the dodge spring will move it forward close to 3" but iam not sure if i would need to add leafs to them or not? i picked up a set of 94 Dakota spring form a v8 an found that there rated either 1850 or 2650, so dose any one have any info or are running them now?? thanks
Old 11-19-2009, 07:49 PM   #2
6" from hell
chattinfarms's Avatar
Re: any one running dodge Dakota springs
if i remember right donahue runs either dakota or f150 springs cant remember which. why wouldnt you just add a leaf and redrill yourself a new whole seems to work good from what ive read. but correct me if im wrong somebody
Old 11-19-2009, 08:34 PM   #3
BillaksBlazer's Avatar
redrilling a spring pack shortend the life of the spring tremendously. one overflex and you can break the spring and then your stuck.
Old 11-19-2009, 09:51 PM   #4
6" from hell
didnt the guy that has the s-ton redrill his springs and it seems to be doing ok just a thought
Old 11-19-2009, 09:52 PM   #5
6" from hell
by the way it was chevtech who did that
Old 11-19-2009, 11:50 PM   #6
Slightly Over Built
DieselS10's Avatar
Would the Durango springs offer another spring rate option also?
Old 11-20-2009, 12:06 AM   #7
2UP1DOWN
tfpets's Avatar
My brother is running dakota leafs('94 v6 2wd i think)...of the 3 that we have built, I like them the best...I tried the f150s on my wifes rig and they work well but they just dont feel as nice as the dakotas...Not sure of the different spring rates and such but the ones that he has work well...
Old 11-20-2009, 12:53 AM   #8
thanks for the info i did your brother have to add any leafs, ya i really don't like the idea of re-drilling the center pins.
Old 11-20-2009, 12:56 AM   #9
michevyfreak's Avatar
not trying to get off-topic but what is the purpose of moving the front axle forward besides a better approach angle?
Old 11-20-2009, 12:59 AM   #10
get out of the firewall/ easier to fit larger tires and approach angle
Old 11-20-2009, 01:17 AM   #11
ok thanks
how much forward do the Dakota spring move the axle from stock?
Old 11-20-2009, 02:48 AM   #12
well the pins are off set 24 /32 some were around 3-4 inch all kinda depends on where you have your hanger mounted, should move my axle forward 3" from my current set up. http://www.s10extremist.org/forums/v...01a3e&start=60
Old 11-20-2009, 09:40 AM   #13
i also remember that the dakotas were recomended when the stage west kit was out.
Old 11-20-2009, 02:17 PM   #14
2UP1DOWN
tfpets's Avatar
His springs are 100% stock...they are straight off of the dakota and onto his rig...
Old 11-20-2009, 02:25 PM   #15
have you drove his truck at any speed in to a corner my truck right now divers hard but then gets firm, iam hoping the dodge spring will firm my truck up. also do they have any arch to them on the truck are they flat? thanks again.
Old 11-20-2009, 07:11 PM   #16
2UP1DOWN
tfpets's Avatar
His actually drives like a dream...he has a yj sway bar on it with disconnects and the adjustable rancho shocks...he lives in sacramento and needs it to be more stable when running with traffic at 80+ mph...when it is on the road he runs it with the shocks all of the way up...I live in the mountains and it is a very windy road and I can run it at 65+ in the corners no problem...in my truck and my wifes blazer we have to be a little more careful because of standard rancho shocks and no sway bar...ours will dive and lean alot more than his...the springs do hold a good arch with full weight on them...I will try to find a pic of it on flat ground.
Old 11-20-2009, 07:20 PM   #17
2UP1DOWN
tfpets's Avatar
This is the best I have with full weight on the springs...This blazer was destroyed 3 days after this picture by a drunk driver but it is the same front axle and springs that are under the blue/white one...
Old 11-20-2009, 11:16 PM   #18
well i stated to swap over to the dodge springs today i removed the over load and added the 4th leaf from a chevy 63 leaf pack , and trimmed off 4 3/4 off one side of the leaf i added to keep it in proportion. haven't got to drive it yet but it looks like it move the axle right where i wanted it to and the front end of my truck fills firmer, should no more tomorrow, i looks like it lower my truck 2" form where it was before which is fine with me , now i can pull my 2" blocks out of the rear and be good to go hopefully.
Old 02-09-2010, 02:33 PM   #19
hears a video for any one wondering how well the dodge dakota springs work
http://www.youtube.com/watch?v=xnI6TSTDOpE
Old 02-09-2010, 04:07 PM   #20
crewcab, your truck is amazing hahaha. i just watched that video.
Old 02-09-2010, 05:52 PM   #21
hey and now when some one gives you crap about the thornbirds you will know diffrent.
Old 02-11-2010, 03:28 PM   #22
http://www.generalspringkc.com/index...arent=117&pg=1 24x32
Old 02-11-2010, 08:37 PM   #23
runn1up2001's Avatar
nice vid... what r u running for exhaust? i like it
Old 02-11-2010, 08:58 PM   #24
sounds like a flowmaster
Old 02-11-2010, 09:32 PM   #25
yep its a flowmaster 3" dual 2.5 out cant wate for the l31 swap then its going to sound really good
Old 02-12-2010, 07:38 PM   #26
sounds good... may do that to mine.
Old 02-12-2010, 07:58 PM   #27
if i where to do it agian with the 4.3 i would do it the same but run the dual pipes in 2" not the 2.5, help keep the low TQ oh and it the orginal 40 seires flowmaster
Old 02-14-2010, 08:59 PM   #28
ok thanks. hey did u ever get the info about your rear spring pack. just checking didnt know if you may of posted it somewhere else and i over looked it.
Old 02-14-2010, 09:40 PM   #29
oh ya forgot i took the main leaf and cut it 4" shorter then the stock 3rd leaf then added a s10 2nd leaf cut it 4" shorter then the previouse, and removed the over load.
Old 02-15-2010, 08:59 PM   #30
ok thanks... im gonna have to stiffen mine up some. its i lil soft in the corners at highway speeds. as for the dakota springs they are longer than the 44044s im runnin right? so if i wanted to run them i would have to move my crossmember?
Old 02-15-2010, 09:39 PM   #31
ya there a lot longer then your so you would have to move you rear shackles back in the frame a lot just stay with what you have in the front you payed good money for them
Old 02-16-2010, 09:01 PM   #32
ok will do... il just try what u did in the rear... thanks. nice vids on youtube by the way
Old 02-17-2010, 04:23 PM   #33
and this is where the shackles mount with the dakota springs its not done but pics give you a good idea what you working with
Old 02-18-2010, 06:53 AM   #34
96superflow's Avatar
Nice setup rabbit.
Old 02-19-2010, 09:26 PM   #35
so if i looked at the pics right you left the top 3 springs alone correct? took the overload out and added 2 more 4" shorter than the previous?
Old 02-19-2010, 11:09 PM   #36
yep thats what i did
Old 03-01-2010, 09:06 PM   #37
hey rabbit which lockers are u runnin? iv read some reviews and some of them say that certain ones will click going around turns or lock/engage when makin a turn on pavement. i was reading up on the eaton lsd since i dont do much offroading. anybody have any suggestions? im still runnin the s10 rearend.
