92 S10 4x4 SFA swap
Old 10-19-2009, 02:38 AM   #1
92 S10 4x4 SFA swap
i put a dana 35 rear and dana 30 in the front and i was wondering if there is a ujoint that i can get soo i can connect my factory drive shafts to the axles
thanks Shane
Old 10-19-2009, 07:58 AM   #2
96superflow's Avatar
Re: 92 S10 4x4 SFA swap
check napa, they have conversion joints that can do it. I adapted mine from the stock driveshaft to a ford 8.8. You might have to do a lil research to get the one you want cause the ppl behind the counter often rarely know exactly what you want. Just get their book that they have and go to town.
Old 10-26-2009, 04:13 AM   #3
k got the u joint problem done and over with, and brake lines, But now what do u do with the steering?
Old 10-26-2009, 09:33 AM   #4
depends on a couple of things. is your axle moved forward any from the stock position? if it is, an astro van steering box is your best bet from the stock location, or you can try and move your steering box forward a couple of inches to get the right angles and you can use a jeep drop pitman(one from a zj grand cherokee is pretty long to begin with) and if its a saginaw steering box, the arm will go right on it and you can use the stock drag and tie rod from the wrangler.
Old 10-27-2009, 03:31 AM   #5
psst, sorry i forgot to mention that ive done SOA, sorry.
Old 10-27-2009, 06:42 AM   #6
that helps too. haha. you are probably going to have to do a high steer arm at the very least. Baggey22 did an awesome write up on it and it tells you where to buy it and how the install went. http://www.jb4x4.com/products.htm
Thats the website you can use. Alot of guys on here have had very good experiences with this, be it your rig be spring over or spring under. You still might have to do an astro van steering box, and if i were you, i would go ahead and purchase Rugged Ridge's heavy duty steering linkages. You get them as a package deal, and you wont have to extend the drag like you would have to do if you were using the stock DL. Hope this helps.
Old 10-27-2009, 06:59 AM   #7
I have a pittman arm off a bronco that fits on my steering box, tomorrow ill get some pics of it and where im at, still going to need some help on how to fix my 4x4 linkage in the truck, i put a 3inch body lift on it and now i cant get it in 4low
Old 10-27-2009, 08:41 AM   #8
Must cut bigger hole in floor board young grasshopper
Old 10-27-2009, 02:30 PM   #9
^ what he said!
Old 11-03-2009, 01:00 AM   #10
damn i was hopping that there was a way of modding the linkage to the T-case or something,
what is the difrent with the S10 steering box and the Astro van steering box???
Old 11-03-2009, 01:07 AM   #11
The astro box swings from the other way. Points the pitman arm towards the front of the truck.
Old 11-03-2009, 05:10 AM   #12
im going to get some pics up proborly tomorrow so u guys can see where im at
Old 11-04-2009, 04:37 AM   #13
is there a a kit soo i can convert from vac lock to a pto cable on my dana 30
Old 11-04-2009, 08:14 AM   #14
Nope you gotta make it. or you can just swap in axle shafts from a xj or tj jeep. You can also turn the piece around that disconnects it and have it engaged all the time.
Old 11-05-2009, 05:11 AM   #15
k, and where do u connect the vacume lines to engage the axle?, do u just run the line that gose to the original vacume pod ?
Old 11-05-2009, 06:53 AM   #16
i dont have a clue. Im pulling out all that vac lock crap asap. Im going to turn the fork around inside the axle, and eventually get tj axle with the 297xx ujoints.
Old 11-08-2009, 01:19 PM   #17
nyteRyda's Avatar
Uhh if you asking if you can make that vac disconnect a manual thing. Then yes you can they sell kits for the jeep axle. Just search for it on google
Old 11-08-2009, 01:21 PM   #18
nyteRyda's Avatar
Oh and that High steer bracket superflow was talking about is only a half highsteer set up...it doesnt convert your drag link from below the knuckle to above it only brings your steering link above the springs...just a little FYI. I have it in my truck and it is worth the money I think
Page generated in 0.57775 seconds with 31 queries
[Output: 95.09 Kb. compressed to 87.87 Kb. by saving 7.22 Kb. (7.60%)]
