#251 |
local engineer
Re: 91 s10 4wd sas conversion
its standard u joints front and rear and its all new parts
#252 |
Slightly Over Built
That ain't bad, I used to bend my rear shaft occasionally when I had the low slung 9" rearend and it would cost about $100 just to have it re-tubed.
#253 |
local engineer
how much does a spring actually twist under compression?
#254 |
Slightly Over Built
#255 |
local engineer
i meant articulation, but ok, jw because i notice a small design flaw that might come back to bite me in the ass
#256 |
local engineer
how much dammage can i cause if i dont have a bushing between where the front shackles connect to the frame?, i noticed yesterday that i have just bolted the shackles to the tabs i had made with grade 8 bolts
#257 |
i know it might be noisy.
#258 |
local engineer
i was more or less concerned with the issues of not being to twist at all, and might possible snap something??
#259 |
Fvck New Jersey
id get bushings in it.
#260 |
local engineer
will it last a week worth of daily driving, since i just got my tires on and my drive shaft comes in tomorrow, i want to do some road testing, just getting it up to speed and seeing how it handels, but if its at risk to snap something ill hold off on testing untill i get the bushings
#261 |
Slightly Over Built
#262 |
local engineer
what year / model jeep should i look for to find a flange output for the front of my transfere case?
#263 |
local engineer
or is it possible to install a cv joint to a regular output yolk
#264 |
what year is your t case.
#265 |
local engineer
its a 91 np231
#266 |
then you shouldnt need need to change the output shaft.
#267 |
local engineer
what do you guys do for you e-brake cable, i know its been discussed on here somewhere but with out digging up something dead i figured id post again. i went to install my cable today and ran into a snag, my trans cross member is in the way and so will my front driveshaft when it gets installed. anyone have any suggestiong on how to move it out of the way but still have it functional? i would say screw it and toss it out but here in mass there picky about there "safety" equipment.
#268 |
Truck #121616
![]() ![]() ![]() ![]() mind the welds, i ran out of gas when i was welding. i got some more and went over them. |
#269 |
local engineer
thanks for the info
