87 s15 sfa swap HELP
Old 08-06-2009, 03:20 AM   #1
alright im puttin a 14 bolt ff in the rear and a 10 bolt in the front both 8 lug i need some help on steering and the hole front end mountin can anybody hook me up with some good picks to see how to weld this stuff in any help will be greatful
thanks chaz
Old 08-06-2009, 03:36 AM   #2
Re: 87 s15 sfa swap HELP
heres what i got
im running all 70s 80s chevy
axels are 70s
front leafs are out of a 83 burbon
and i dont have rear leafs yet
i need some help on how to mount the front leafs and mane it safe for the road
o and im ganna put 44s on the truck
thanks for the help
Old 08-06-2009, 09:26 AM   #3
96superflow's Avatar
read through the threads and see how others have mounted them on their projects. THis question has been answered numorous times, so search for it and you will find.
Old 08-06-2009, 10:29 AM   #4
Slightly Over Built
DieselS10's Avatar
That 10 bolt should do well with 44" tires.
Old 08-06-2009, 12:09 PM   #5
MTchevyS10's Avatar
Old 08-06-2009, 05:11 PM   #6
everything im running came off my roommates 83 burbon he upgreaded cuz he found a set of matching 513 gears in a ff and a 44 so i got the 410s in the ff and the 10 bolt i mean if he had a 83 burbon 13 inch lift 44s 350/350/208 combo i think my s10 will do fine in my 87
Old 08-06-2009, 06:09 PM   #7
GAVE his truck to 96super
bubbagt57's Avatar
once again that 10bolt will do wonders
Old 08-06-2009, 07:33 PM   #8
i think they are the merical axles! im going to get some for mine, and put some 54" boggers on um. Guys they are the toughest axles out there. No Joke!!!! lol
Old 08-07-2009, 06:27 PM   #9
i got 410s in both axels should i go to like a 456s or will the 410s do well im in south florida so all the mud is like swampy sandy mud not like the mud up north
Old 08-08-2009, 12:17 AM   #10
Stop posting this dumb shit. Do the research on the 10 bolt axles and you will find out about them.
Old 08-11-2009, 02:54 AM   #11
BigBoy70's Avatar
... this coming from someone running a dana 30
Old 08-11-2009, 09:12 AM   #12
im not running 44s. If i were, i would have planned on having something tough enough to handle it. I know how much the axle i have can handle. If i out grow them, which i dont think i will, i will put in something tough enough to handle it.
Old 08-11-2009, 12:12 PM   #13
MTchevyS10's Avatar
Good point. You'll be just fine.
Old 11-01-2009, 02:18 PM   #14
its been a while had some trouble with the welder gotta fix the welder but the axels are in just gatta git patched up i got a 4x4 1/4 inch thick tubing up front 4 inch 1980s lifted leafs a 3 inch block and the stock rear shackles up front in the rear i have 1980 1 ton leafs 3 inch blocks and shackles on 38 inch tires on 16.5 rims 10 bolt front 14bff rear when i git the welder fixed im ganna set the rear pinion angle and finish the front
Old 11-01-2009, 02:31 PM   #15
heres a pic not good but a pic ill post more as soon as i git the camera back
Old 11-01-2009, 07:17 PM   #16
seriously blocks up front. i think you need to research before your build anything.
Old 11-02-2009, 02:08 AM   #17
chattinfarms's Avatar
blocks arent bad on the front if done right i had a 72 chevy with 4 inch blocks and the guy is still driving it like that today im just saying though
Old 11-02-2009, 03:24 AM   #18
theres not a thing wrong with blocks we have a buggy at the house that has 5 inches of blocks all the way around and that thing jumps mounds lounches out of ditches running a bb with nos and a blower smokes all four tires been built for years my dad built it like 30 years ago and its still runnigON BLOCKS
Old 11-02-2009, 09:16 AM   #19
Slightly Over Built
DieselS10's Avatar
There's nothing wrong with blocks on the front of something that does not ever get driven on the road. Other than that it is a very bad idea.
Old 11-02-2009, 10:54 AM   #20
yea try replacing a block that was spit on the trail with rusty u bolts. Not my idea of a fun to say the least.
Old 11-02-2009, 12:35 PM   #21
http://www.4wheeloffroad.com/techart...cks/index.html
This explains why.
Old 11-02-2009, 08:11 PM   #22
Slightly Over Built
DieselS10's Avatar
I was speaking from a safety stand point only, I wouldn't put them on the front of anything at all. They aren't designed to handle the side load that it put on them in turns IMO.
Old 11-03-2009, 10:45 AM   #23
diesel i know your smarter then that. lol I just hate blocks in general. last weekend we hard to try and fix a fullsize that spit a block in the mud. About 6 hours and climbing a tree to set up a clevis to lift the guys truck with my winch and sitting in waist deep mud. I was not a happy camper. Just do it right the first time. esp if it sees the road at all
Old 11-03-2009, 07:33 PM   #24
^^ agreed.
Page generated in 0.60255 seconds with 32 queries
[Output: 116.15 Kb. compressed to 106.60 Kb. by saving 9.55 Kb. (8.22%)]
