2001 Blazer ZR2 Brake Problems
Old 11-07-2009, 02:27 AM   #1
Hi, I'm new on this site but I read before registration of a lot of people with to much experience on swaping diferentials, OK, this is my problem, I star a swap on my ZR2, in the front I have a Dana 30 from a Jeep Cherokee 91, stock disk brakes and on back a Ford 9" with a Explorer disk brakes, but my brakes doesn't work, when I press the brake pedal goes all the way and no oil on the brake lines???? what can bee, all ides I will apreciate, thanks
Old 11-07-2009, 02:55 AM   #2
chattinfarms's Avatar
Re: 2001 Blazer ZR2 Brake Problems
did you bypass your abs most people do try unhooking it at the master cylinder and see what you have.
Old 11-07-2009, 03:54 AM   #3
to start with make sure all your bleeders are pointed up so all the air will come out , if that doesn't help you probably have air in you abs box. i found a cool trick to get air out of the abs box, brake the lines lose and install some roofing nails in the lines tighten then down some, then pump your breaks tell there firm, then remove the nails, and bleed the breaks at the bleeders and you should have breaks, hope that help , might sound crazy buy air in the abs box is a bear to get out.
Old 11-07-2009, 01:59 PM   #4
Fvck New Jersey
Tim99Zr2's Avatar
yea, im voting air in the abs box.
rip that shit out
Old 11-10-2009, 03:49 AM   #5
Thanks guys for all the good coments, the mechanic how intall my master cylinder was a new on this, he suppoust to charge it before traing to intall on the car, secund I intall the calllipers with the bleeder on bottom, my mistake, third, air on the abs, but is done, thanks a lot
Old 11-10-2009, 06:52 AM   #6
96superflow's Avatar
Post up some pics of your truck!
Page generated in 0.55705 seconds with 31 queries
[Output: 56.24 Kb. compressed to 53.22 Kb. by saving 3.02 Kb. (5.37%)]
