Posts: n/a
01 zr2 SFA conversion Q's
if i got a jeep dana 30 front with stock jeep leafs how much lift would it give me?
Or what size lift leafs would i need to clear 33's? I plan an a rear axle flip with a 35 or 44 rear form a jeep. i want like 5-6 inch lift overall will i clear 33's? Thanks, xtreme |
ZR2 member
Re: 01 zr2 SFA conversion Q's
Posts: n/a
thanks for the help i apprectate it... i decided to go with full size axles a 12 bolt rear,but does ford make a 6 lug dana 44 front axle??? Also if i used s10 rear leafs up front will that give me enough lift to clear 36's i know what about 10 inches of total lift ...... any info would be apprecated
xtreme |
Thye Ford d44s came in 5 lug or 8 lug, depending on what truck it came out of. i think the S-10 rear leaves would be way to stiff for the front...alot of guys use the BDS YJ (Wrangler) 3.5" or 4" leafs for the front and clear 35s/36s (I'm assuming you'd be SOA?) They ride nice and flex well. I'd skip the 12 bolt, if you're going through the hassle, use a 14 bolt or the D60 out of the donor Ford. Look for a '77-'79 Ford F250, and you'll get the HP d44 with the rear d60 and won't have to mix 'n' match lug patterns.
Posts: n/a
wouldnt you lose some HP with the extra weight of the D44 and 14 bolt, would that but more stress on the engine or more importantly the tranny i have a 5-sp... or will the V6 have enough power?
Whats SOA??? Last edited by xtreme-10 : 11-26-2004 at 01:07 PM. |
It's all in the gearing...you'd be fine w/ the 5spd./V6 with 4.56-4.88 gears...just keep in mind the NVG 5 spds. aren't the strongest, but it would suffice. SOA=spring over axle...you get more height this way, but more axlewrap/wheelhop.
You can go with S-10 rear leafs for the front. That is what I used to run. I perfer rear leafs from a K5 Blazer up front. If you want to go with a 12 like I have in the back, then just go with a Jeep Wagoner d44 front, like I have. You will have enough room to fit 35's with a little fender trimming. My 4.3 has no problem handling my 35x12.5's but I don't thrash it because I only have the older 4 speed and it isn't rated for the 4.3. But I have taken it on quite a few trails without a problem. If you have any more questions post them in the SFA post at the top of the Thread page. Those guys know a lot and they will help you out.
Posts: n/a
thanks everyone for the help if i had the right gears in a dana 30 would it survive 35's, i dont do aot of serious offroading????
