ZR2 Vin# - S-10 Forum
post #1 of 24 Old 02-26-2011, 06:57 PM Thread Starter
sam336's Avatar
User is: sam336 is offline
ZR2 Vin#
Can you tell if the s10 has a ZR2 package from the vin#? I dont have the truck here but i have the vin and was just wondering.
sam336 is offline
post #2 of 24 Old 02-28-2011, 05:37 PM
98-ZR2's Avatar
User is: 98-ZR2 is offline
Re: ZR2 Vin#
nope i dont believe so
Originally Posted by NM_Wanderer
SAS = Spend And Spend some more. But worth every penny!
98 ZR2 SFA, D44/60 5.13's, locked rear, 38"? Tires, In Progress...
02 2500HD LB7 Duramax, AEM CAI, Ported Intake Horn, Straight Pipe, 33s
98-ZR2 is offline
post #3 of 24 Old 02-28-2011, 09:16 PM
User is: Hunter ZR2 is offline
Re: ZR2 Vin#
You can run the vin.
Indigo Blue 2000 S-10 ZR2, everbreaking 4WD, color matched flares, UWS tool box,
Soon to come: OHC
post #4 of 24 Old 03-09-2011, 09:56 PM Thread Starter
sam336's Avatar
Re: ZR2 Vin#
Nevermind i found out. The reason i wanted to know was because this s10 im buying has 33's on it and a 3' body lift. And i was wondering how it was fitting with only a body lift but i found out the truck is a ZR2.
Thanks guys.
sam336 is offline
post #5 of 24 Old 04-30-2011, 08:49 PM
98 S10 4x4 4.3L auto
User is: little4x4S10 is offline
Re: ZR2 Vin#
So how did you find out? I want to know if mine has the ZR2 as well.
post #6 of 24 Old 04-30-2011, 09:43 PM
24digger's Avatar
User is: 24digger is offline
Re: ZR2 Vin#
There's a tag behind the engine that has all the codes on it.
It should say zr2 on that as well as in the glove box.
24digger is offline
post #7 of 24 Old 04-30-2011, 11:50 PM
Re: ZR2 Vin#
Okay. Thanks for the info.
post #8 of 24 Old 05-01-2011, 12:29 AM
Electrical Mod
deathphoenix99's Avatar
Re: ZR2 Vin#
For Future reference.
You can find out if a truck is a ZR2 by the vin, just run the VIN and check all of the RPO codes.
http://www.compnine.com/vid.php
post #9 of 24 Old 05-02-2011, 05:22 PM Thread Starter
sam336's Avatar
Re: ZR2 Vin#
I ended up just looking in the glove box when i went and looked at the truck.
sam336 is offline
post #10 of 24 Old 05-06-2011, 06:18 AM
Professional Insultant
TokoDragon's Avatar
User is: TokoDragon is offline
Send a message via MSN to TokoDragon
Re: ZR2 Vin#
just kinda repeating.
There is nothing in the Vin # to determine if the truck is a ZR2 or not, but if you use the links above you can run the Vin # and then it looks at that Vin #'s build list/RPO codes to determine if it is a ZR2 or not,
but there isn't anything in the vin to say ZR2, ZR2usa tried to determine how many ZR2's were produced, but since it was just an RPO code they couldn't get very percise numbers.
The SS s10 got the B4U in the vin #
bummer ZR2 didn't get one
post #11 of 24 Old 05-11-2011, 03:38 PM
98-ZR2's Avatar
Re: ZR2 Vin#
anybody else get "rarity" when they did that vin encoder thing?
EDIT: this thing
98-ZR2 is offline
post #12 of 24 Old 05-19-2011, 08:06 AM
96superflow's Avatar
User is: 96superflow is offline
Re: ZR2 Vin#
Probably cause you got a ZR2. Im going to run my blazer and tahoe tonight.
1996 4dr 4wd Blazer D30/8.8 combo w/ 4.10s, sky manu kit, rancho 44044 springs. 33" tsls, Dynomax muffler...Still Dead in the water
2001 Chevy Tahoe 5.3 Corsa Sport, Ranch Hand Legend, keys and spacers, Hummer H3's, 265/75/16 Cooper ATPs, Daily/tow Rig...
post #13 of 24 Old 05-20-2011, 02:53 AM
Solid Axle MOD
Sonomanclature's Avatar
User is: Sonomanclature is online now
Re: ZR2 Vin#
for shits and giggles
Vehicle: PICKUP
Year: 1994
Build Date: 1994-04-09
Found 860,550 vehicles matching your year and model in our database.
RPO Description Matches
UA1 BATTERY,HEAVY DUTY HVY DUTY BAT(UA1)
BATTERY,HEAVY DUTY(EXPORT) HVY DUTY BAT(UA1)(EXPORT)
81,957
UP8 RADIO,PROVISIONS FOR STEREO INSTRUMENTATION STEREO RDO PROVISIONS(UP8)
773,724
UX1 RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK STEREO AM/FM W/CASS & EQLZR(UX1)
54,447
U73 ANTENNA,FIXED FIXED ANT(U73)
785,529
VF6 BUMPER,REAR STEP RR STEP BPR(VF6)
791,265
VXS VEHICLE - COMPLETE
860,550
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
854,952
XEB TIRE FRONT P235/75R15/N OWL R/PE ST TL OOR (9590910) TIRE(XEB)
88,947
YC3 COMFORT AND CONVENIENCE PACKAGE,#3(PERSONAL LUXURY) DECOR PKG LEVEL #3(YC3)
SPORT/GYPSY/SLS(PERSONAL LUXURY) SPORT/GYPSY/SLS(YC3)
409,251
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
860,550
YD5 SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
860,550
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
860,550
YEB TIRE P235/75R15 (STEEL BELTED) TBLS RADIAL OOR W/LTRS TIRE(YEB)
88,947
ZEB TIRE SPARE P235/75R15/N WOL R/PE ST TL OOR (9590910) SPARE TIRE(ZEB)
88,947
ZM5 SHIELD PACKAGE,UNDERBODY U/B SHLD PKG(ZM5)
49,062
ZM6 OFF ROAD SUSPENSION PACKAGE OFF ROAD SUSP PKG(ZM6)
27,573
ZQ3 DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION) DRVR CONVENIENCE PKG(ZQ3)
388,590
ZY3 SPECIAL TWO-TONE TWO-TONE(ZY3)
41,352
Z88 GMC TRUCK G M C(Z88)
179,943
1SD PACKAGE-OPTION 04 (1SD)
88,062
1SZ PACKAGE OPTION- (1SZ)
836,730
12H TRIM COMBINATION CLOTH, GRAPHITE (12H)
300,756
12I INTERIOR TRIM GRAPHITE (12I)
400,644
19L SECONDARY COLOR,EXTERIOR (19L)
SECONDARY COLOR,EXTERIOR,BLACK (19L)
14,421
6CB SPRING COMPTR SELECT FRT LH SUSP(6CB)
24,255
7CB SPRING COMPTR SELECT FRT RH SUSP(7CB)
21,525
72U EXTERIOR COLOR,PRIMARY (72U)
EXTERIOR COLOR,PRIMARY,MEDIUM GARNET RED METALLIC (72U)
99,171
81A ACCENT STRIPE,TWO-TONE,BLACK/BLUE (81A)
ACCENT STRIPE,TWO-TONE,DARK RED/BLACK (81A)
4,383
AV5 FRONT HIGH BACK BUCKET SEAT FRT HIGH BACK BKT ST(AV5)
206,433
A78 ADJUSTER,FRT ST BK MAN RECLINING,PASSENGER AND DRIVER MAN RECL ST BACK ADJR(A78)
642,792
B30 CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
707,622
B32 COVERING,FLOOR MATS,FRONT AUXILIARY FRT AUX FLR MATS(B32)
401,976
C6F GVW RATING(5150 LBS) 5150 LB GVWR(C6F)
112,371
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
690,942
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4)
642,783
DH6 MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM) ILLUM S/S MIR(DH6)
642,789
D44 MIRROR,OUTSIDE,BELOW EYELINE(PAINTED) O/S PAINTED MIR(D44)
553,437
D55 CONSOLE,FRONT COMPARTMENT FLOOR F/CMPT FLR CNSL(D55)
CONSOLE,FRONT COMPARTMENT FLOOR F/CMPT FLR CNSL(D55)(EXPORT)
206,433
D88 STRIPE,SPORT SPORT STRPE(D88)
100,059
D98 STRIPE,BODY SIDE ACCENT AND DECK LID ACNT STRPE(D98)
10,539
E63 BODY EQUIPMENT,FLEETSIDE PICKUP BOX FLEETSIDE PUBX(E63)
860,550
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
787,575
FK2 ARM,TORSION BAR,SPRING ADJUST,LH TORS BAR SPR ADJ ARM(FK2)
111,837
FK3 ARM,TORSION BAR,SPRING ADJUST,RH TORS BAR SPR ADJ ARM(FK3)
111,837
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
277,329
JM3 BRAKE BOOSTER,DOUBLE DIAPHRAGM HIGH FLOW(240MM) DBL DIAPH BOOS(JM3)
860,550
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
388,590
LB4 ENGINE,(4.3L),V6 90 DEG GAS TBI, DIRECT SALES ONLY 4.3 (LB4)
ENGINE,(4.3Z),V6,EFI 4.3Z(LB4)
381,120
MM5 TRANSMISSION,MANUAL 5-SPEED PROVISIONS(MERCHANDISING OPTION) 5-SPD M/TRANS PROVISIONS(MM5)
361,806
MY2 TRANSMISSION,MANUAL 5-SPEED 5-SPD M/TRANS(MY2)
98,910
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
817,569
N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33)
STEERING COLUMN,TILT TYPE(EXPORT) TILT STRG COL(N33)(EXPORT)
388,590
N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
860,550
N90 WHEEL,15X7(CAST ALUMINUM) AL WHL(N90)
94,614
QEB TIRE ALL P235/75R15/N WOL R/PE ST TL OOR TIRE(QEB)
88,947
R9Z CONTROL - SALES ITEM NO.100
105,636
SLA PLANT CODE - SHREVEPORT, LA, USA
530,667
SLM SALES PROCESSING - STOCK ORDERS
704,901
TFE SALES INCENTIVE - COMMITMENT PLUS
152,688
Rarity...
There are 3 1994 PICKUP vehicles (0.000%) matching your exact options list. There are 3 (0.000%) with at least as many options.
94 Sonoma Dana44/60 5.7L 5spd
06 Subaru Impreza
post #14 of 24 Old 05-20-2011, 07:02 AM
Electrical Mod
Re: ZR2 Vin#
Vehicle: PICKUP
Year: 1994
206,433
Sorry, I'm just curious, do you have a manual transfer case or electronic? Thanks.
post #15 of 24 Old 05-20-2011, 09:17 AM
98-ZR2's Avatar
Re: ZR2 Vin#
Rarity...
lol beat ya by 1 i got 2 matching.... so i guess i just got a little over excited when i seen rarity.... now i dont feel so bad cutting it up, i was a little heart broken at 1st when i thought my truck was actually rare and i cut it all up haha
98-ZR2 is offline
post #16 of 24 Old 05-20-2011, 03:59 PM
Solid Axle MOD
Re: ZR2 Vin#
Manual FTW, still dont know how that is going to work with a body lift, not a lot of room in there to move it ...
06 Subaru Impreza
post #17 of 24 Old 05-20-2011, 06:12 PM
Electrical Mod
Re: ZR2 Vin#
^^^Wow, can you get more pics! I've never seen a full console with manual shift, that has to be really rare. Looks sweet as hell though. And now I know that RPO code D55 might be for that console specifically.
post #18 of 24 Old 05-20-2011, 07:34 PM
Solid Axle MOD
Re: ZR2 Vin#
The only other interior pic I have, I can snap some other pics later when it stops raining.
Really it is just like the auto consoles, but a little different up towards the dash.
EDIT: I still want a damn cluster with a tach
06 Subaru Impreza
post #19 of 24 Old 05-20-2011, 09:53 PM
98-ZR2's Avatar
Re: ZR2 Vin#
here's another 1, coincidence truck is the same year with probably most of the same options
http://www.s10forum.com/forum/f221/t...estion-466180/
98-ZR2 is offline
post #20 of 24 Old 05-20-2011, 10:06 PM
Electrical Mod
Re: ZR2 Vin#
^^^Nah, that's the typical shorty center console.
The one
906sonoma has is a full console, which I didn't know even existed till now. If I could find one, that'd be heaven.
post #21 of 24 Old 05-20-2011, 10:46 PM
Solid Axle MOD
Re: ZR2 Vin#
^^ that is hideous XD, everything except the cruse in mine is manual, just the way i like it.
06 Subaru Impreza
post #22 of 24 Old 05-21-2011, 07:51 PM
Solid Axle MOD
Re: ZR2 Vin#
Transcends from heaven with pic for joo. hahaha
See just like the Auto console with a trey, except I have piece of metal sticking up from there.
06 Subaru Impreza
post #23 of 24 Old 06-01-2011, 01:56 AM
User is: Omar's10 is offline
Re: ZR2 Vin#
The previous owner of my truck cut a hole out in an auto console and made it kinda fit, but like everything else in the truck it was semi hacked. I had to trim alot more than he did because it would push the shifter out of gear,but I'm happy with it.
Omar's10 is offline
post #24 of 24 Old 06-01-2011, 11:25 AM
Solid Axle MOD
Re: ZR2 Vin#
^^ yup that's pretty much it, where the pocket extends on the DR side would be sollid and the shifter located, and in front is raised for the indicator.
06 Subaru Impreza
