the 4x4 vacuum thread. - Page 4 - S-10 Forum
post #151 of 522 Old 12-08-2009, 09:44 PM
carolinatruckscene.com
leprechaun1874's Avatar
User is: leprechaun1874 is offline
Re: the 4x4 vacuum thread.
Yhea, from the front diff. my bad. I don't think its very far. maybe an inch or less. I think you would need to pull the cable and engage the 4wd at the t-case also.
Live in the Carolina's? Click here CarolinaTruckscene
Engine swap thread PICS WANNA SEARCH?
post #152 of 522 Old 12-09-2009, 01:13 PM
tonkaman's Avatar
User is: tonkaman is offline
hmm ok i think im just gonna replace all the vac lines as they are dry rotted pretty bad, how much does the switch in the t case and the diaphram run usually, and is there anything in the front diff that could be bad and need replacing?
tonkaman is offline
post #153 of 522 Old 12-09-2009, 02:55 PM
User is: blazer9698 is offline
Is it hard to replace the vaccum actuator on a 96' chevy blazer? I know its under the battery tray, but is there anything that i have to take caution of before replacing it?
post #154 of 522 Old 12-13-2009, 10:43 PM
User is: cyclonewoody is offline
First of all great thread explaining the vacuum system on the S10! I am still a little confused, I've replaced the actuator under the battery tray, replaced the switch on the t-case that has 3 hoses coming out of it, and tried the vice grip trick locking the cable in permanently. Still no 4WD in hi or lo. The front shaft under the drivers seat locks in when 4HI button is pushed and tranny in N, it spins freely when 2HI button is pushed and tranny in N. Does this means it's an electrical issue? I have had some ABS issues recently, think it's a sensor as the ABS goes off when I get below 5MPH, every single time I stop. Not sure if that's related or not. Any help would be much appreciated.
2002 S10, 200k miles, 233 transfer case.
post #155 of 522 Old 12-17-2009, 05:52 PM
Wilson4x4's Avatar
User is: Wilson4x4 is offline
This thread helped me so much today! Thank you. I had no idea why my 4x4 wasn't engaging so a quick read of this thread then I had my truck on the hoist, checked all my lines... Then sure enough I pull out the switch on the tcase and its stuck in. Anyways few bucks and a few minutes later I had 4x4 working like a champ. Thanks!
Black 06 Sierra z71 crew cab, 5.3, 33" mickeys, 4:10s, g80 locker, pro comp wheels, tool box, 3/4 ton leafs with aal... Wayyy too much.
Black 96 S10 ZR2' new winter beater/ mud monster. 2" body lift, 2" suspension lift, 33" duratracs, tool box, camaro wheels..
$400 first truck now beater.. 97 regular cab, auto, 4x4, 4.3, Flow 40, 98+ front end, HIDs, 2'' body lift, 2" shackles, zr2 tbars, z28 camaro wheels, John Deere green, 31'' MTRs.
post #156 of 522 Old 12-30-2009, 11:41 PM
94RedSonoma's Avatar
User is: 94RedSonoma is offline
Send a message via AIM to 94RedSonoma
I've been messing around with my intake lately and my question is. if that vacuum line that goes to my intake is loose...or not hooked up. will that cause the 4x4 to not engage?
post #157 of 522 Old 01-01-2010, 03:05 AM
Wilson4x4's Avatar
that may be...
post #158 of 522 Old 01-03-2010, 08:23 PM
tonkaman's Avatar
hey so i took a vacuum cleaner to the diaphragm and it pulls the cable but not far enough. the 4x4 still doesnt engage. so i removed the cable from the truck and its not broken but there was about a cup or so of milky oil in the plastic deal that bolts to the front diff. then i pulled the shift fork out by hand and the 4x4 engaged yay! my question is, should there be oil in the plastic deal? and why didnt the diaphragm pull the cable far enough to engage it? is it time for a new diaphragm?
tonkaman is offline
post #159 of 522 Old 01-05-2010, 05:02 PM
Grounded 4 Life
NJ4X4BLAZE's Avatar
User is: NJ4X4BLAZE is offline
Here are some pics of the vacuum switch location I found online.
_________________________________________
Dave
01 Blazer 4x4,6" Superlift Kit,2" Body Lift, 33" MT's(AKA Blazin4x4)
post #160 of 522 Old 01-07-2010, 04:35 PM
ZQ8 Blazer's Avatar
User is: ZQ8 Blazer is offline
Great thread, wish I had found it earlier. I have a 98 push button and here's my problem, the transfer case is working as it should but whether it's in 2wd or 4wd when I turn the front wheels by hand the front driveshaft turns, I know it isn't suppose to do this. So is it a cable, actuator, or vacuum problem? How do I know which one it is forsure? What do I do to engage and disengage the 4wd?
ℐustin
post #161 of 522 Old 01-08-2010, 09:09 AM
Grounded 4 Life
NJ4X4BLAZE's Avatar
look at the acuator and see if its still under vacuum when in 2wd. That's how I knew the vacuum switch was bad. I know my drive shaft used to move as well, but I just replaced my vacuum switch the other day so I need to see if that solved that issue as well.
Dave
post #162 of 522 Old 01-08-2010, 01:52 PM
ZQ8 Blazer's Avatar
Ok I'll do that. Is that the switch at the end of the cable by the differential on ours? So you don't think it would be the actuator itself?
ℐustin
post #163 of 522 Old 01-08-2010, 01:54 PM
Grounded 4 Life
NJ4X4BLAZE's Avatar
It's #3 in the diagram above. It's located above the transfer case.
Dave
post #164 of 522 Old 01-09-2010, 06:53 PM
ZQ8 Blazer's Avatar
Ok it was always getting a vacuum so i replaced the switch (thanks, NJ4X4BLAZE) and that fixed that problem. But it's still staying in 4wd all the time. The actuator works fine. I took the cable off the actuator and it moves freely like it should. Then put it back on and it put itself into 2wd. When I got in the Blazer and put it in 4wd it worked but when I put it in 2wd it was still in 4wd. What else could it be?
ℐustin
post #165 of 522 Old 01-09-2010, 11:05 PM
2000 noma highrider
Toyota h8r's Avatar
User is: Toyota h8r is offline
Send a message via AIM to Toyota h8r Send a message via MSN to Toyota h8r Send a message via Yahoo to Toyota h8r
i have to convert to a posi-lock due to ALMOST exploded my front diff thanks to my vacuum actuator losing "vacuum signal" at wide open throttle in the snow. The truck shook hard and banged loudly twice before i could get out of the gas.
You might ask why was i at WOT in snow/ice? I was trying to pull a fullsized f350 out of a ditch
i hate my s10 and its cute IFS
my rides...
--2000 Sonoma highrider Zr2 4.3L/a4 3.73 gears(stock) AWAITING SFA
--1992 s10 x-cab 2wd 2.8L/m5BLOWN UP.....RIP
--1988 s10 blazer 4wd(sold)GONE BUT NOT FORGOTTEN
post #166 of 522 Old 01-10-2010, 05:23 PM
ZQ8 Blazer's Avatar
NM. I was reading on here and I have to put it in reverse and then back into drive in it shifts into 2hi
ℐustin
post #167 of 522 Old 01-11-2010, 08:03 AM
Grounded 4 Life
NJ4X4BLAZE's Avatar
Good to see your problem has been solved.
Dave
post #168 of 522 Old 01-12-2010, 07:09 AM
that guy
LBD44's Avatar
User is: LBD44 is offline
so im wantin to elimenate vacuum system kinda im gona explain i kno my transfercase is workin and i kno my front axle is lockin in cuz i can pull the cable by hand and lock the front axle but it wont lock in on its own so i was just gona run a vacuum line from the t on the drivers side down to the acuator with a valve on it but where would i cap off my vacuum line runnin to my tranny do i need the line that runs to the tranny?
2001 s-10 pickup zr2 with 6 inch superlift on 33 mud brutes on 15 rock crawlers halo/projector head lights flowmaster exhaust custom intake and a hypertech programmer
LBD44 is offline
post #169 of 522 Old 01-12-2010, 11:24 PM
that guy
LBD44's Avatar
ok well i rigged up a system for my 4wd acuator i just rerouted the line that goes to the transfercase and ran a brand new vacuum line from that to a switch and then to the acuator i have pics if i can figure out how to post them
LBD44 is offline
post #170 of 522 Old 01-12-2010, 11:55 PM
that guy
LBD44's Avatar
ok i think i have the pictures on this msg i outlined the vacuum hose i used and how i ran it and u can see where i put the shut off valve and how its hooked up and it works perfect and only cost me 20 bucks at discount
ID:	108480   Click image for larger version
ID:	108481   Click image for larger version
Name:	HPIM0993 edited.jpg
ID:	108482   Click image for larger version
ID:	108483   Click image for larger version
Name:	HPIM0991 edited.jpg
LBD44 is offline
post #171 of 522 Old 02-11-2010, 11:29 AM
mrriverajr's Avatar
User is: mrriverajr is offline
This is a great thread, I have to start troubleshooting my lack of 4wd and this thread just might help.
I got stuck in 2ft of snow thanks to the NJ Storm last night and it was quite embarrassing watching people look at me saying man that ZR-2 sucks!!!! LOL
I put the switch to 4wd Hi and I hear a click outside but no front wheel engagement I also tried in 4wd Lo and still no front wheel engagement. The lights do Light up and stay lit saying I am in 4wd mode but Nothin.
Any other tips?????
post #172 of 522 Old 02-11-2010, 12:01 PM
hey mrriverajr i had that same problem, still do actually.. for me it was a little plastic clip inside the actuator on the front end. the clip had broke so it wasnt' holding the cable tight to engage into and out of 4 wheel. I'd lift the truck up and put it into 4wheel and see if the front shaft spins, if it does than its your actuator...hope this helped a little.
post #173 of 522 Old 02-11-2010, 06:20 PM
mrriverajr's Avatar
I am gonna check it out tomorrow. I think I am leaning towards a Posi Lok system.
post #174 of 522 Old 02-11-2010, 07:58 PM
yeah i'de like to invest in one of those too, unless i could make one cheaper
post #175 of 522 Old 02-12-2010, 09:40 AM
mrriverajr's Avatar
Wink Re: the 4x4 vacuum thread.
Ok so I removed that vacuum actuator today and plugged the vacuum line. I tried pulling the actuator cable leading to the front axle and the wire would not even move. The vacuum actuator seemed to work every time i put the vacuum line to it. I am assuming the actuator cable is frozen not allowing the shift fork to move.
I gotta keep trouble shooting it but its freezing out an i am numb...LOL I will keep you all posted!!!!
[/quote]
post #176 of 522 Old 02-12-2010, 09:50 AM
I Rather Be Wheelin'
ChrisInVT's Avatar
User is: ChrisInVT is offline
Try having someone drive the truck forward slightly, it seems to tale a little bit of movement to engage sometimes.
Originally Posted by 96superflow View Post
Who needs independent suspensions when you have independent engines?
1987 4.3L 2D GMC S-15 4WD X-Cab Anti-Bro Truck (4.3 & 700R4 Swap, Custom bumpers, too many other mods. )
post #177 of 522 Old 02-12-2010, 09:42 PM
User is: knightcrusader is offline
This may be a stupid question, but is there a trick to installing a new vacuum switch into the transfer case? I just bought an '02 ZR2 Ext Cab 4.3L 5spd and the 4x4 didn't work at first, come to find out through research on this site that the plastic part of vacuum switch broke off.... my uncle got the old one out but can't get the new one in. He said something about it being spring loaded.
Any help is appreciated. Thanks!
post #178 of 522 Old 02-14-2010, 04:23 PM
The ball in the bottom is spring loaded. It might be a tight fit to get the switch in.
post #179 of 522 Old 03-05-2010, 01:45 PM
Drjeffro's Avatar
User is: Drjeffro is offline
Originally Posted by boardsilly View Post
this seems like the place to ask this. if i have a vacuum leak on my hvac switch would that vacuum leak in the system cause my 4 wheel to try to engage while i am driving at 70mph? so far it has happened 3 times. i plugged off the vacuum line while i wait for the hvac control panel and haven't had the problem happen since. so what do you guys think?
Mine is doing something similar, and noone can seem to figure it out. I just got the new engine in my truck from the spun crank bearing. But when I run it WOT and let off to slow down, the front axle is trying to engage and makes a horrible clicking sound. If I hit the 4HI button, it stops immeadiately. Under regular acceleration, there is no problem, just when I go WOT, then the noise starts when I slow down.
2001 Sonoma Highrider, Black, Intake, Cat-back, Rhino liner, Alpine head unit, Rockford Fosgate Punch amp, 2-Rockford Fosgate Punch 12's in custom box
Drjeffro is offline
post #180 of 522 Old 03-05-2010, 02:22 PM
2000 noma highrider
Toyota h8r's Avatar
Any other tips?????
welcome to owning a gm failure.......
im switching to the bravada axle and tube to get rid of the vacuum failure system. No more waiting for the axle to engage or disengage ...or not engage at all. No more replacing vacuum lines, actuators and transfercase switches
my rides...
post #181 of 522 Old 03-12-2010, 12:22 PM
User is: joenbarb0 is offline
Hello,
I realize this is and old thread but I'm hoping somebody is still out there. Am I correct that if I have transmission fluid in my vacuum lines and actuator that my switch is bad at the transfer case?
post #182 of 522 Old 03-22-2010, 10:59 AM
relic's Avatar
User is: relic is offline
G'day.
Just joined,just got my first S10 with the push button 4x,I've had four other S10 4x's but they were manual shift.
My front axel won't engage and have narrowed it down to the vacume switch,the switch on mine looks like it's on top of the TC,not screwed into the side. Am I looking at the right thing?
relic is offline
post #183 of 522 Old 03-22-2010, 01:49 PM
Drjeffro's Avatar
Mine is fixed now. It was a vacuum leak, I still don't understand why a vacuum leak would have the front diff partially engaging.
Drjeffro is offline
post #184 of 522 Old 03-22-2010, 01:50 PM
Drjeffro's Avatar
Originally Posted by relic View Post
G'day.
The part on the side of the TC is a switch, when the TC is shifted, it transfers vacuum to the diaphram that is usually mounted up near the battery, the diaphram then pulls a cable that engages the front diff.
Drjeffro is offline
post #185 of 522 Old 03-22-2010, 11:03 PM
69xx69
User is: burnett_4x4 is offline
hey, so if i were to put a cherokee dana 30 under my truck would the vacum lines work for that axle?? would they just hook right up do you know??
thanx
post #186 of 522 Old 03-25-2010, 12:08 PM
relic~ the vacum switch is on top of the TC. It has 3 lines going to it if the lines are gone you should be able to feel the 3 prongs. The switch looks like this
burnett ~ If you do a SFA you don't need the vacum system
post #187 of 522 Old 03-25-2010, 02:05 PM
2000 noma highrider
Toyota h8r's Avatar
IIRC 87-95 dana30 from yj/xj had a vacuum locking right axle.....fails
http://cgi.ebay.com/ebaymotors/ws/eB...d=290325372631
lolololololol
could make it work like a stock s10 if done right i bet
my rides...
post #188 of 522 Old 03-25-2010, 03:35 PM
Well then don't use that axle.
post #189 of 522 Old 03-29-2010, 12:05 AM
69xx69
alrite hey thanx guys...but i decided not to use that axle anymore lol im using 1/2 ton running gear and droping a 350 in my truck or a 454 i can make it work and i have the 454 just has a loud knock in it but its getting a rebuild.... lol im gunna try for the 454 though
post #190 of 522 Old 05-26-2010, 08:46 AM
User is: skybolt58 is offline
OK, I see this a old thread. but does anybody know where one can get that rubber plug. I need to run new vacuum lines, my vacuum one is plugged and I cant get the plug off the hose.. my switch is fine.
post #191 of 522 Old 06-28-2010, 09:18 PM
User is: psiscorpian is offline
i tried putting my 84 s15 into 4x4 and ran into the same problem. afte putting in back into the 2 wheel drive it wouldnt move. is it possible that without the vac lines it would get locked in neutral? i found where the lines r suppost to go, along with the vac lines missing the other end of the 3 prong connecter is also gone.
also the previous owner connected the actuator vac line to the back of the manifold. when i removed it , my truck ran horrible and was misfiring.
i connected vac lines into the correct holes, without the connecter but it wouldnt work.
post #192 of 522 Old 06-29-2010, 02:19 AM
the vac lines are just for the front axle to engage and disengage, now if you put in 4x4 and back into 2x4 and it don't move it is either your linkage or transfer case is shot?
if yours dont work with vac lines connected direct to carb to actuator, then your actuator or cable is shot?
post #193 of 522 Old 07-02-2010, 08:38 AM
What 'rubber plug' are you talking about? If you are talking about one on the end of a vacume line try autoparts store. any kind of plug should work.
post #194 of 522 Old 07-02-2010, 08:46 AM
even if your vacum lines are not hooked up the tranfer case will still shift. you can feel the difference in 'power' it just wont send power to the front axle. when you put it back in 2wd it should go back to normal.
post #195 of 522 Old 08-15-2010, 03:27 PM
User is: tahi is offline
Send a message via AIM to tahi Send a message via Skype™ to tahi
I just changed all the vac lines on my 98 Blazer but it looks that front axle is not engaging. Should I check first the switch or the Actuator?
98' Blazer LT - 4.3 l K & N Airfilter
87 Blazer Tahoe - 2.8l injection 4WD - 190000 Miles - stock rims
85' Jimmy - 2.8 l - Bodylift 2" - stock rims - 235 tires - Trush Muffler - 150000 Miles
62' Oldsmobile F85 4 door Sedan 3,5l Stock
tahi is offline
post #196 of 522 Old 08-15-2010, 10:26 PM
jman85's Avatar
User is: jman85 is offline
Originally Posted by Donahue View Post
a lot of people have problems with their 4x4 not working, for various reasons. one of the common reasons is the vacuum actuator going bad, or the vacuum lines going to it. i have gotten a PM from somebody, and i figured i could share some of the info with everyone.
in s10's, when you put it in 4wd (4hi or 4low) with either the 233 (push button) or 231 (manual shift(also 207)), the transfer case has a switch of sorts that tells the front axle to engage. this switch routes vacuum to one of two places. if you are in 4wd (hi or low), the vacuum goes to the actuator. if you are in 2hi then the vacuum gets routed to an orb where it is just stored. this line also supplies the vacuum.
now, the switch it self is on the drivers side, almost at the front of the t-case. it has three vacuum lines going to it. the switch works similar to a ball point pen, meaning there is a round ball that is either pushed or not. the ball gets pushed by the shift fork inside the t-case, when the case is shifted into 4wd. now, there are three vacuum lines going to the switch. one line supplies the vacuum, and stores it in the orb when not in 4wd. one line vents to the open air, and the t-case vent piggy backs onto it. the other line goes to the actuator. all three lines run together up to the passenger side of the bell housing. then two go one way, and one goes the other. the vacuum supply/orb is the line that breaks from the pack and follows over to the drivers side. the other two lines, the vent and the actuator line, continue to run along the passenger side frame rail where they end near the vacuum actuator. one line plugs into the actuator and the other is just a vent that clips onto the inside of the outer fender well.
the actuator takes the vacuum, when supplied, and has a diaphragm that pulls on a cable. this cable runs down to the passenger side of the front differential, and moves a collar back and forth. this collar either connects the passenger side cv shaft to the carrier, or it disconnects it. this is how the 4wd system works on an s10, and all IFS 4x4 gm products (with a few variants).
now the pictures:
this is the switch installed on a 231. note the vent line coming off the t-case
here is where the t-case vent line meets up with the open air circuit.
you can see the lines running along the trans and bell housing
this line goes off to the orb, and supplies the vacuum from the engine
this line will follow the wiring harness and go the orb, located behind the drivers side headlight
this is the orb, aka the vacuum canister
this is where the switch gets vacuum, off the intake
this is the other two lines that go off to the passenger side
they end behind the passenger side headlight
this is the line going into the actuator
the actuator is under the battery tray
now onto the switch. the switch looks like this
if you look at the top, where the lines go in you will notice a little "key"
this lines up with a similar spot on the female end
the three vacuum lines must be in the right spot in order to function properly. take the female end of the vacuum lines, looking at the open end towards you like in the above pic. if you orientate it to where the key is on top, the lines are as followed.
if anyone has any questions, or wants any more pics, just ask.
glad i got a body lift in mine
1985 gmc s15 4x4 high sierra 5 speed 2.8l reg cab short box 3 inch body lift SOLD
1991 gmc jimmy 2 door 4.3l auto 4x4 lifted 2 inches on air SOLD
highly modded 97 dodge diesel 4wd 5 speed fully loaded making 450hp and 28mpg.
93 sle 4wd 4 door jimmy
jman85 is offline
post #197 of 522 Old 08-22-2010, 01:58 PM
In fact I double checked and the front axle is engaging. The only probleme is that disengagment is pretty slow is that normal? It takes cometime100 feet driving to quit.
I got a question also : what is the third vac line at the transfer case switch for?
I assume that the first one goes to the vacuum source, the second to the actuator…but what is the third for? On mine it goes to a t junction and one of the branc is going to a final plug under the hood.
tahi is offline
post #198 of 522 Old 08-22-2010, 09:13 PM
one line should be vacum source, one is open air vent, the other is the vacum ball. From my understanding.
post #199 of 522 Old 08-23-2010, 03:00 PM
what does the open air vent do? I don't understand the function of this line? Why do teh TC need this vent? Does the switch connect vacuum source to open airvent?
tahi is offline
post #200 of 522 Old 08-24-2010, 10:09 PM
To quote jman85~ now, the switch it self is on the drivers side, almost at the front of the t-case. it has three vacuum lines going to it. the switch works similar to a ball point pen, meaning there is a round ball that is either pushed or not. the ball gets pushed by the shift fork inside the t-case, when the case is shifted into 4wd. now, there are three vacuum lines going to the switch. one line supplies the vacuum, and stores it in the orb when not in 4wd. one line vents to the open air, and the t-case vent piggy backs onto it. the other line goes to the actuator. all three lines run together up to the passenger side of the bell housing. then two go one way, and one goes the other. the vacuum supply/orb is the line that breaks from the pack and follows over to the drivers side. the other two lines, the vent and the actuator line, continue to run along the passenger side frame rail where they end near the vacuum actuator. one line plugs into the actuator and the other is just a vent that clips onto the inside of the outer fender well.
