shackle lifting...leaf spring broken? - S-10 Forum
post #1 of 22 Old 06-13-2013, 08:05 PM Thread Starter
User is: chevrolet is offline
i am taking off my leaf spring from the shackle however its not a complete circle... does this indicate that my leaf is broken and needs to be welded to the bushing housing? both leaf springs are the same way... also are the bushings from the shackles available to purchase seperately? and would they need to be pressed in? or can i hammer them in...
post #2 of 22 Old 06-13-2013, 08:26 PM
Solid Axle MOD
Sonomanclature's Avatar
Re: shackle lifting...leaf spring broken?
You need to replace the leaf, its not supposed to be half should go all the way arround.
the leaf spring bushings are the same as the frame end. press out old ones press in new.
94 Sonoma Dana44/60 5.7L 5spd
06 Subaru Impreza
post #3 of 22 Old 06-13-2013, 08:26 PM
Electrical Mod
deathphoenix99's Avatar
What year is your truck? I'm surprised you aren't having issues with the leaf spring sitting on the frame the way it is. I'd get new leafs if I was you, and then go from there.
post #4 of 22 Old 06-13-2013, 09:16 PM Thread Starter
I own a 2000 zr2. Can I get any s10 leafs or are they specific to the zr2 model. No chance of welding these just to make it mobile for now?
post #5 of 22 Old 06-13-2013, 09:17 PM
3 Leaf Fab
Donahue's Avatar
User is: Donahue is offline
Send a message via AIM to Donahue Send a message via MSN to Donahue
wow, more pics please. if i am seeing what i think i am seeing, then i am surprised you did not have something more serious happen.
Just an old dad now...for now at least
Donahue is offline
post #6 of 22 Old 06-13-2013, 09:20 PM
needs a cheeseburger
tohoopty's Avatar
User is: tohoopty is offline
cant weld to spring steel
Originally Posted by The Griff View Post
I looked at my asshole in the mirror today. It blew my ****in' mind!
tohoopty is offline
post #7 of 22 Old 06-13-2013, 09:36 PM Thread Starter
Do I need specific zr2 springs seeing as how they sit higer than regular s10s?
post #8 of 22 Old 06-13-2013, 09:42 PM
3 Leaf Fab
Donahue's Avatar
Originally Posted by tohoopty View Post
cant weld to spring steel and have it stay
fixed it for you
Donahue is offline
post #9 of 22 Old 06-13-2013, 09:43 PM
3 Leaf Fab
Donahue's Avatar
as far as i know, yes
Donahue is offline
post #10 of 22 Old 06-13-2013, 10:16 PM Thread Starter
Think its possible to use a regular 4x4 s10 leaf and then add my zr2 leafs to it seeing as how I just need the main one? Ive also been reading that silverado leafs will work too? What do u guys think I should do? Heading to junkyards tomorow
post #11 of 22 Old 06-13-2013, 10:37 PM
the youngest has been
tippmann243's Avatar
User is: tippmann243 is offline
Zr2 trucks run standard s10 springs. Only blazer zr2s got actual lift springs in the rear.
-mark
89 s10 blazer 5.7 vortec/t56 0411 pcm powered
03 zr2 s10 with some mods
post #12 of 22 Old 06-13-2013, 10:44 PM
tohoopty's Avatar
Originally Posted by Donahue View Post
fixed it for you
oh thanks lol.spring steel will also crack and break if it gets heated too wont it.
tohoopty is offline
post #13 of 22 Old 06-14-2013, 01:39 AM
Electrical Mod
^^^^WTF??? Spammish much?
Any ways...as stated, pickups use the same leafs as non Z's. So look for Z85 RPO codes or even the better RPO code...forget it off hand. But if it's Z83, stay away!!! The Z85 was common in extended cabs and long bed s-10's.
post #14 of 22 Old 06-14-2013, 03:12 AM
warriorcustoms's Avatar
User is: warriorcustoms is offline
That picture isnt the greatest But some Helper Springs are shaped like that!!! The Leaf Spring that attatches to the shackle has an eye for a bushing & the bolt goes threw that... If thats the main spring in the pic Then get a ride to the junkyard & go get a set of springs Or order a set off JC Whittney or some place... KC Spring will hook ya up too!!! More pics would help LoL
post #15 of 22 Old 06-14-2013, 03:40 AM Thread Starter
It is the main leaf that connects to the shackle. Whats the reason behind staying away from z83 and what is z85? Just the grading im sure? Thanks for the help by the way
post #16 of 22 Old 06-14-2013, 07:08 AM
Electrical Mod
The RPO's in the glove box denote suspension packages.
z83-soft suspension
z85- heavy duty suspension
zq8- sporty suspension, 1.5" drop from normal springs.
post #17 of 22 Old 06-14-2013, 09:02 AM
Cwhite138's Avatar
User is: Cwhite138 is offline
no it will just loose all its toughness and then most likely brake over time/loose its shape.
spring steel is a high carbon steel that is quenched then tempered. The tempering process they use is complex and creates a very tough structure. There is name for it but I forget it right now.
now it is posible to weld it but creates a very brittle structure in the HAZ because of the high carbon base metal. now you could anneal it and create a more dutile structure in that spot which may last alittle longer.
I wouldnt weld or heat any spring on a road vehicle.
01 2dr jimmy, 4.3L, '93 NP231 w/sye, D44LP front and RS44044 springs, AMC 20 rear w/Spartan locker spring over w/2 waggy rear springs, 4.88 gears, 35x12.5-15 pitubull rockers. 10000lb x20 comp smittybilt winch, 2" BL
post #18 of 22 Old 06-14-2013, 12:06 PM
3 Leaf Fab
Donahue's Avatar
ah, then the springs i have seen used in the past must have been from a zr2 blazer. thanks for the info
says the man with 45,660 posts...
Donahue is offline
post #19 of 22 Old 06-15-2013, 02:21 PM
Electrical Mod
No, there was an actual spam post. It's been deleted now. But it was an actual member, not a new account.
post #20 of 22 Old 06-15-2013, 02:56 PM
Solid Axle MOD
There was i moved it.
06 Subaru Impreza
post #21 of 22 Old 06-15-2013, 10:20 PM Thread Starter
Ok so update post. Found z85 leafs. Pretty pricey from a junker but ****it. So I got shackles and shocks in... didnt lift as much as I thought ill post pics in a bit. So I was thinking add a leaf. Can I use another leaf from my old broken set or do the leafs u buy on ebay have diff length and stifness....
post #22 of 22 Old 06-15-2013, 11:42 PM
3 Leaf Fab
Donahue's Avatar
Ah
Donahue is offline
