manual transfer case swap
Go Back   S-10 Forum > Suspension Tech > Liftin' It > 4wd IFS
Old 10-07-2009, 09:12 PM   #1
JimmyKnux's Avatar
I will be doing this swap within the next couple weeks I will take no end of pictures and do a detailed write up. I have a pretty good idea on how to go about it but as the truck is my daily driver I dont want to be guessing at it and be without my wheels . The truck is a 95 s10 ls 5speed , the plan swap a manual tcase as well as a posi lok cable in the process I will be removing the A/C as well. The ac will later be used for on board air, all in due time. Can any one point me in the direction to start? confirm which year the tcase will work thanks .
Old 10-07-2009, 09:25 PM   #2
96superflow's Avatar
Re: manual transfer case swap
you will deff have to have one out of a manual tranny i believe. Then ones behind the automatics have a different mounting pattern at least to the best of my knowledge anyways.
Old 10-07-2009, 09:39 PM   #3
Fvck New Jersey
Tim99Zr2's Avatar
meh, mine were all 5 or 6 bolt (dont remember chevy or jeep, which one had 5 and which had 6)...i had both auto and manual tcases.. my np231 i got out of a 94' automatic, had it behind my 94' 5 spd.
id try to get one with the cable vs. the linkage. get the shifter too.. for the tcase
Old 10-09-2009, 07:16 PM   #4
JimmyKnux's Avatar
any info on changing the front output shaft? what years of s10/blazers should I look in?
Old 10-11-2009, 02:29 AM   #5
Slightly Over Built
DieselS10's Avatar
My stock 207 was originally mounted to a 4 speed manual, then a TH350, then a 4L60E. I'm fairly sure that they use the same spline count on all of them in the S10's.
Old 10-15-2009, 06:35 PM   #6
JimmyKnux's Avatar
perfect thanks for the help I found alot of junk yards very close to me that all have the same year as mine they just have the manual instead of push button I was very suprised at the amount of trucks I found. What all will I need to snag off the parts truck?
Old 10-20-2009, 02:21 PM   #7
rollin' on 33's
t01blaze's Avatar
chevy has 5 t-case bolts
Old 10-28-2009, 08:46 PM   #8
JimmyKnux's Avatar
thanks for all the help this will be coming over the winter currently working on an 85 chevy scottsdale running 39s pics will be up soon of thats truck paint this week and safety than im road legal!
Page generated in 0.57648 seconds with 31 queries
[Output: 63.82 Kb. compressed to 60.04 Kb. by saving 3.77 Kb. (5.91%)]
