Look what Fed Ex brought me
Go Back   S-10 Forum > Suspension Tech > Liftin' It > 4wd IFS
Old 10-30-2007, 11:10 PM   #51
Fvck New Jersey
Tim99Zr2's Avatar
Re: Look what Fed Ex brought me
Quote: Originally Posted by 95S104x4
i had to trim mine to get the 35's to fit without rubbing.. the front tires will rub a lil bit if it get it in a bind..lol..when i trimmed mine i took "great stuff" expanding foam and filled in the hole, that trimming made...i then painted it black and ya cant even tell its been cut on..
thats a good idea, i think im going to make a filler plate thou. hrmm..
im whoring in his thread!
Old 10-30-2007, 11:11 PM   #52
ZR2
Jigg's Avatar
Quote: Originally Posted by Tim99Zr2
i went with 15x8 with 4" of BS with 33s, on a zr2 w/ 2" BL and it rubs pretty good.
Against my reccomendation
Old 10-30-2007, 11:11 PM   #53
no longer has a 95
95 S_Trucker's Avatar
i dont care. your helpin me too.
Old 10-30-2007, 11:16 PM   #54
no longer has a 95
Quote: Originally Posted by Jigg
Yes and no.
Yes, with your spacers, you're at the same backspacing as the rims i was suggesting. But with the rims, you have the option of using the spacers as well if you care to, or just sell them to recoup some of the cost of everything else.
No to the 15x8's with 4.5" being better. I can't tell exactly what tires you're running, but they're fairly tame... and look to be about 235's. If you want to run a somewhat aggressive 31" tire, you need to keep your tires more inside the wheel well to prevent them from rubbing. Just because you don't rub now, doesn't mean you won't with the 31's (in fact, i can almost guarantee it, espescially with the flares... even with the BL).
ok thanks
yes you were right, i have 235 75 r15 now.
I would like to go 31x 10.5 r15
so you think i should still go with the 15x7 with 4.5 bs?
Old 10-30-2007, 11:17 PM   #55
ZR2
Jigg's Avatar
Yeah, i do. Your tires will be quite a bit wider anyways, so it'll gain you a bit of a wider look that you're probably going for.
Old 10-30-2007, 11:40 PM   #56
Fvck New Jersey
Tim99Zr2's Avatar
see i didnt quite listen to jigg and look what happened to me. haha. he knows what he is talkin about.. jigg, since he dont mind me whoring. what would a 5-6" sus. lift for a 99 Z cost and a smittybilt 4ton winch run?
Old 10-30-2007, 11:47 PM   #57
ZR2
Jigg's Avatar
About $2225 + shipping for both of those
Old 10-30-2007, 11:48 PM   #58
Fvck New Jersey
Tim99Zr2's Avatar
hmm. thats not too bad.. how about just the winch?
Old 10-31-2007, 12:01 AM   #59
ZR2
Jigg's Avatar
$285.95 + shipping
Old 10-31-2007, 12:02 AM   #60
Fvck New Jersey
Tim99Zr2's Avatar
kk ty
Old 10-31-2007, 06:26 AM   #61
no longer has a 95
allright. sounds good. thanks for the help.
Youll probly get a pm form me sometime this winter
Old 10-31-2007, 06:42 AM   #62
ZR2 mini-truckin'
TokoDragon's Avatar
Yeah it looks pretty good, just like ZR2 flares, except not that spectra gray color (I want them black, so I'm jealous) the dealership told me how new the tires were, still had the fuzz etc, except they're the cheapest 31'' you can buy! only have 2k on them, but I want to change them anyway long before the 40k mark they're ment to last.
I want to go with the BDS 5'' suspension lift, but I was starting to think that'd be to tall of a truck for all the daily driving it'd be doing, and just weekend trails. I wish there was a 2-4'' suspension that was durable
Old 10-31-2007, 01:38 PM   #63
For tires look at Jeep Forums online. Guys are CONSTANTLY unloading 31s for cheap. If you shop around you can get used ATs for very reasonable. Also look in craigslist and other want ad stuff. Lots of guys get 31s then upgrade with barely breaking in the tires.
You can get steel wheels with any offset you like, look around online but there are tons of companies that provide them. You can easily get 4 15 x 8 steelies with custom offset for probably around $200. Or again, look for a used set.
Body lift you will have to pay retail probably. But for the other stuff, shop around and get one thing at a time as you find deals.
With a little less backspacing pushing the tires out hopefully you won't get alot of rub.
Old 10-31-2007, 07:57 PM   #64
no longer has a 95
so this would be a good choice on the wheels then?
15x7 with 4.5 bs
http://store.summitracing.com/partdetail.asp?autofilter=1∂=CRR%2D3425734P&N=700+ 4294923107+4294923106+4294923105+4294793325+429475 5960+4294795045+4294795102+115&autoview=sku
Old 10-31-2007, 08:00 PM   #65
ZR2
Jigg's Avatar
yes... those would work well.
Old 10-31-2007, 08:18 PM   #66
no longer has a 95
ok, thanks for all helpin man. it means a lot that your willing to help me
Old 10-31-2007, 10:38 PM   #67
Short Bus Anonymous
wagonproject's Avatar
I like the looks of the ones Jigg sells better.
Circle holes instead of the D shaped ones...
Old 10-31-2007, 11:04 PM   #68
ZR2
Jigg's Avatar
No problem at all!
Old 01-02-2008, 08:45 AM   #69
no longer has a 95
well, fed ex showed up again about 10 minutes ago and this showed up
its a 2", and i got it from synergyoffroad.com thanks to Jigg
hope to get it on before i go back to school on the 7th, but i dont know if thats gonna happen or not
Old 01-02-2008, 09:38 AM   #70
100% A-hole
BatwingZ's Avatar
Looking good Bro... Now as long as u dont stick a " ZR2 " Sticker on it.. i wont have to track you down and rip it off!...LOL... Looks good tho.. cant wait to it with some wheels and that 2" BL!...My first truck was an Xcab 94 like yours but mine had the CPI engine in it, 5" TM Lift, 3" BL, 33x12.50 Timberline MT's on 15x8 Proline Alloy 139 wheels..... I sadly sold it tho ... but yours is lookin good!
Old 01-02-2008, 12:52 PM   #71
no longer has a 95
yours was an auto, right?
because they didnt offer the cpi with a 5-speed. i wish they did.
which reminds me
i have a 5- speed and i dont wanna cut the console.
I haver this one now
but if i have to i can switch to this one only the one at the bottom, I dont have the armrest part anymore
So, i know the first console isnt going to work unless i cut it or if i make some kind of adapter that moves the shifter forward about an inch.
does anyone know the thread size and pitch of the shifter threads that come out of the trans, im assuming its metric.
Old 01-02-2008, 12:56 PM   #72
3 Leaf Fab
Donahue's Avatar
consoles? we dont need no stinking consoles!
Old 01-02-2008, 01:13 PM   #73
i love my chevy
19914x4blazer's Avatar
looks good 95 s trucker
Old 01-02-2008, 01:19 PM   #74
100% A-hole
BatwingZ's Avatar
Yea mine was an auto...
Old 01-02-2008, 02:05 PM   #75
Registered Asshole
crazy91s10's Avatar
nice... cant wait to see!
Old 01-02-2008, 03:41 PM   #76
no longer has a 95
haha, but i would like it to look halfway nice on the interior. but that does make it easier to fill up the tranny with fluid. easier than using a hand pump. lol
but im pretty sure the threads for the shifter are M14, but i dont have a thread pitch gage. i guess ill go buy one.
Old 01-02-2008, 04:10 PM   #77
3 Leaf Fab
Donahue's Avatar
psss...(dont tell anyone, but that isnt an s10 anyway...)
but my s10 will get a new trans tunnel from the heater to the back seats.
Old 01-02-2008, 04:53 PM   #78
Got s10?
drmrman's Avatar
Glad you worked everything out with jigg. I advise you listen to his statement about the BSing on the rims.
I have a 4x4 blazer with a 2" BL. 1.5" shackles and 1.5" torsion bar tweak and I rub on 31,10.50,15 Cragar Soft 8s with 4" of BSing... And Im on an AT not even a MT. I sudgest you go with 4.5 BSing because those beautiful fender flares will be junk the first time you hit a nasty bump and RIP them right off the truck.
How my truck sits.
Hope I could help!
Synergyoffroad.com FTW!
Old 01-02-2008, 06:05 PM   #79
no longer has a 95
How my truck sits.
Hope I could help!
how much do you rub?. a little or a lot?
can you get some close up shots of the fenders with your wheels turned at full lock?
and btw, your blazer is, but i have to say i liked your old truck better
Old 01-02-2008, 08:14 PM   #80
Got s10?
drmrman's Avatar
Thanks man! Im glad you like it! Lemme see what I can do with the pics this weekend! I wont be around my dads digital camera until sat. but my mom might have one burried somewhere here! I rub pretty bad! I did NO trimming but I DID hit the corners of the fenders with a sledge hammer and take the 2 bottom fender bolts out!
Like I said Ill try and take pics ASAP!
Old 01-03-2008, 08:32 PM   #81
no longer has a 95
Thanks.
i might have to add tbar tweak to the list. i dont wanna rub at all, but i dont know about that yet
Old 01-03-2008, 10:50 PM   #82
Fvck New Jersey
Tim99Zr2's Avatar
get that BL on.. i wanna see it!
Old 01-04-2008, 08:18 AM   #83
no longer has a 95
its going on tomorrow. im gonna do the bed in the morning(or try too). and i got a friend helping me in the afternoon with the cab.
I pre labeled all the bolts and hardware an put em in ziplock bags so i dont spend all my ime looking for bolts tomorrow, and i found out there was one bolt missing for the fan shroud.
I dont think its gonna be to bad tho. i mean im going to school to be a mechanic. it should be cake, but im worrying about breaking a brake line or something
and there will be pics of it being installed. someone got a camera for xmas, so no need to steal my brothers.
Old 01-04-2008, 10:18 AM   #84
100% A-hole
BatwingZ's Avatar
Body Lifts are cake work bro... a buddy of mine did one on his fullsize just the other day.. never did one before in his life... he did it in a full days time.. he coulda done it faster but he didnt listen to me.....ive put 6 of these Fockers on.. i know them inside and out...lol...so im sure youll have no problems at all... dont worry about ur brakes lines.. theyll stretch enough .. just make sure u yank ur steering shaft loose at the column and take ur radiator shroud apart and drop your filter block down ( oil filter that is )....dont forget to remove ur filler neck from the inside of the gas door....parking brake cable.. cant forget that... when u lift the cab up..its liable to pull the ebrake cable too...so dont forget about that...other than that... u shouldnt have any problems...let us know how it goes...another thing disconnect the battery completely.. those cables dont stretch very far at all...your 4x4 vaccum actuator should be fine.....but let us know how it goes!
Old 01-04-2008, 10:26 AM   #85
Slap my meat on your pita
GeorgesBlazah's Avatar
If you wanna minimize the rubbing I would go with 5in BS. I have that on my Blazer with a 2in BL and small t-bar tweak and I barely ever rubbed. I dont think the .5in difference between 4 and 4.5 is gonna do it.
Old 01-04-2008, 10:31 AM   #86
I Rather Be Wheelin'
ChrisInVT's Avatar
Body Lifts are cake work bro... he coulda done it faster but he didnt listen to me.....ive put 6 of these Fockers on.. i know them inside and out...lol...so im sure youll have no problems at all...
I have a plane ticket for you to come to VT and put my body lift on
Old 01-04-2008, 10:49 AM   #87
nox
rox
nox's Avatar
don't worry about it, I did mine when it was about 30* outside and all the lines bent out of the way just fine. Also I didn't put the lower shroud back on my truck.
Old 01-04-2008, 12:34 PM   #88
no longer has a 95
i knew all that, i read the directions about 20 times, lol. but i dont have to do anything with the steering though. the 95 and newer trucks have a slip joint and the 94 and earlier trucks didnt. thanks
Old 01-04-2008, 12:35 PM   #89
Fvck New Jersey
Tim99Zr2's Avatar
then... GET TO IT!!
shouldnt take no more than 4 hours. mine took 2.
hmm. your in PA as well
Old 01-04-2008, 12:35 PM   #90
no longer has a 95
wow, im doin it in my boss's shop, 25x50 one bay. and heat too.
Old 01-04-2008, 12:37 PM   #91
no longer has a 95
sounds good.
i i think im gonna start out with my stock wheel and get some 31s for them. then go from there
Old 01-04-2008, 12:41 PM   #92
no longer has a 95
then... GET TO IT!!
i will. i would be doin it now but im on my lunch break now.
Old 01-04-2008, 12:43 PM   #93
Fvck New Jersey
Tim99Zr2's Avatar
yea. i have to work today. first friday i worked in over a year i think
Old 01-04-2008, 01:07 PM   #94
100% A-hole
BatwingZ's Avatar
ChrisInVT .. .get me the ticket!..haha.. and the 94's do too have a slip joint.. mine does anyways...just not as cool as the 95-ups ...
Old 01-04-2008, 01:52 PM   #95
ChrisInVT's Avatar
You wouldn't be saying that if you saw my bodymounts!
Old 01-04-2008, 01:57 PM   #96
3 Leaf Fab
Donahue's Avatar
um, my 89 has the slip joint too...
Old 01-04-2008, 03:16 PM   #97
sounds good.
Yeah anytime you go with a wheel with less BS your going to have that problem; the closer to stock the least amount of rubbing you will have. A hammer will not fix the rubbin issues that comes with 4 or 4.5 BS.
Old 01-04-2008, 03:53 PM   #98
Baggey22's Avatar
Chris I'll help ya, just tell me when! I don't have classes again until January 22nd. Just shoot me some gas money maybe since its like a 45-60 minute drive to your garage.
Old 01-04-2008, 04:31 PM   #99
no longer has a 95
alright, i meant that you dont have to change anything with the steering on a 95 or newer
Old 01-04-2008, 04:43 PM   #100
ChrisInVT's Avatar
I have a metalworker (co-worker's husband) coming over Saturday to take a look at my mounts and give me whatever options he can think of to take 'em off. I'll shoot ya a PM sometime this weekend
