Lifting my Blaz.
OK os I'm starting this early but only so that I remember.
Project is my '94 Blazer Plans are 31x10.50 15's(going procomp A/T's) replacing the rear springs since whoever owned it before me removed one leaf from the 4-leaf pack so now I only have 3 there. putting in rear shackles(getting the ones from Oreilly's for temp so I know how much I will need) Cranking the T-bars in the front. replacing the rouch contry shocks with monroe reflex in front and the sensatrac overloads in the rear. I will post up pics and also the height differences as this moves along. Should be done sometime in Sept from my budget. ![]() |
Re: Lifting my Blaz.
Just an update, got my new leaf springs the other day, just got a call from my tire dist and those are in now too. Still have to make it to get the lift shackles and shocks yet. Actually started rethinking my shock selection.
Blazers only had 3 leafs...
.(rusted out and can see inside them. LOL) |
So got my lift temp lift shackles today and have some questions. they are the generic ones from Oreilly's the superior automotive 13-4000.
they are 10" in total length they have 3 adjustable options @ 5.5", 7" and 8.5" what is the length of the factory ones and how mych lift will I get based on these #'s??? |
Well for every 2" added to the bolt hole to bolt hole measerment it will lift 1"
Banned
yeah, if you want to lift with shackles, say you want 2" of lift... youll have to make the shackle 4" longer from bolt hole to bolt hole, becuase your only lifting one side of the spring.
Well here's an update
before: the way I got it with 235/75 lt15's ![]() ![]() After: New 4 leaf springs, a tbar crank(guess I need new t-bars) and my new 31X10.50 LT 15 Procomp A/T's ![]() ![]() ![]() ![]() ![]() I'll have my measurements up later. Last edited by montec : 09-13-2009 at 11:32 AM. |
So. I didnt add lift shackles. and here is my measurements for those out there.
before with 235 FL FR 32.5 33.5 RL RR 31.5 32 1/8 with just the 31's added FL FR 33.5 34.25 RL RR 32 3/4 33 1/8 And finally with the new leaf in the back and adjusting the t-bars a bit FL FR 34.5 34.5 RL RR 35 35 I dont mind the rake and actually prefer it as with a trailer it sits level. I do know I need new t-bars as the one that looked the best and had some paint left on it was week as hell and I have no adjustment left on that. I do need new shocks yet too and still deciding on them yet. Will be getting an alignment as soon as I get the shock put on and will have them confirm the ride height then too. So all in all with this I got 2" in the front and about 3.5 in the back. based on these measurements Last edited by montec : 09-13-2009 at 10:23 PM. |
I hope this helps out those that are looking to do the same thing.
I had a photobucket error here is a repost of pics
Registered Abuser
Looks good Montec!
Just an update.
Just ordered a set of PP Ball joints for the front. And will be running monroe sensatrac shocks. Rears are going to be the overload set with the spring. |
Off Vanning. bbl
You can always check out hopewells (not sure on the spelling) in kindred he had a couple zr2's sitting out there. The truck looks good, I am looking at lifting my 92 4dr soon.
Well here's and update just got the new Ball Joints installed and new shock thing rides much smoother and the back end gets a bit brick like when less then 1/2 tank of gas. Have to get it aligned yet and will get some new measurements up since the rought contry shocks I was able to compress one handed on all 4 corners easily and they didn't rebound @ all.
And 95, check out husky spring. The new 4leaf made a good 1" lift in the back, no lift shackles for me. |
