issues with plow
Go Back   S-10 Forum > Suspension Tech > Liftin' It > 4wd IFS
Old 11-02-2009, 07:21 PM   #1
issues with plow
if the torsion bar is cranked to much, will the added weight of a plow break something,
DOES ANYONE HAVE PICS OF THE TIRES SHOWING THE CAMBER AFTER A TORSION BAR CRANK!!!!!
Old 11-03-2009, 12:56 AM   #2
Re: issues with plow
Crank the Tbars no more than 1.5" (which is the recommended max) and you may not even need an alignment. (I'd get an alignment anyway just to be safe.) What I'm trying to say is that pics may not be necessary as the tires may stay in alignment.
Old 11-03-2009, 10:20 AM   #3
do you see any issues with the plow
Old 11-03-2009, 01:44 PM   #4
992drjimmy's Avatar
I suppose each truck would be different. But we cranked the bars on my brothers truck to level it with the plow in the air. Never had a problem.
Old 11-03-2009, 04:45 PM   #5
you must have cranked them a hell of alot to do that, mine sits like maybe 2" lower with the plow in the air, also what kind of plow does he have on the truck, a poly blade or steel??
http://www.ls1tech.com/forums/pictur...ictureid=29038
Old 11-03-2009, 08:08 PM   #6
Dain Bramaged
These trucks are weak for plowing. If it is just used for personal driveway use then it would survive I guess. I would not recommend using any S series truck for any type of commercial plowing use.
Old 11-03-2009, 08:19 PM   #7
Quikz28's Avatar
ive had a steel meyers plow on my truck for over a year without any issues, i think the truck plows great for being a small truck, you need to run a decent size tire, im on 31x10.50s and havent gotten stuck yet,
but it doesn't hurt to beef up the suspension
Page generated in 0.69348 seconds with 31 queries
[Output: 58.50 Kb. compressed to 55.15 Kb. by saving 3.35 Kb. (5.73%)]
