How To: 2" Shackle / Torsion Lift - S-10 Forum
post #1 of 221 Old 04-29-2010, 05:47 PM Thread Starter
It's a S-Series thing...
User is: BlaziNator is offline
What you will need:
-Lift shackles
-A jack that can jack on the rear differential
-2 jack stands
-Tire chocks
-Wrenches
-small sledge hammer (2.5 lb. works)
-1/4" punch
-Spray lubricant
-Tape measure
-Very level ground
Things you might need:
-a large (8" minimum i believe) C clamp
-Breaker bar
-lots of time
-patience
You will start by chocking the front tire(s)
Then jack up the rear of your truck. (jack under the differential works) You will need to get the tires a good way off the ground as the tires and axle will need to be lowered to allow for the longer shackles. (About 3-5 inches of space between them and the ground should work.) Then place your jack stands under your truck to hold it in place and allow the axle to drop.
Next, you will lower the jack under your rear differential and relieve the compression of the springs holding a bind on the 4 bolts that go through your shackles and leaf springs.
Disconnect your rear shock absorbers from the axle by removing the bolt that holds them in place. (1 per shock absorber) This will allow for the axle to drop sufficiently to install the longer shackles. Otherwise, the shock absorbers limit it's travel.
Loosen the nut on the 4 bolts running though your leaf springs and shackles. (2 on each side) You will need to back them with another wrench or ratchet.
Leave the nut on the bolt so that you can pound the bolt out without damaging the threads. Next is the moment of truth, remove your backing wrench and turn the bolt around inside the bushing, spraying your lubricant as you turn. If it eventually moves freely or easier, then you are in the clear. If it is stuck, I would (and have) reassemble everything and take it to a shop to get it done. (cost me $100) If it is stuck, this means that the bolt is siezed inside of the bushing and is a MAJOR pain to remove. One way I have tried with success is like so:
Pounding on the clamp as you tighten it. This took FOREVER on mine, but worked great. Also, be prepared to destroy the clamp. I bent 2 when I did mine.
After I got mine done by the shop, I examined the shackle and found that it was bent from the inside. I believe they used an air hammer on the shackle itself to pull the bolt through. This effectively destroyed the factory shackles so I would not attempt this on my own.
Once you have gotten the bolts moving, remove the nut and beat the bolt out of the shackle/leaf spring bushing being careful to not damage the threads. Once the bolt is flush with the bushing, you can use the punch to ram it the rest of the way out. You may need to raise or lower your axle via the jack in order to relieve the bind on the bolt and possibly your punch. I recommend doing one side at a time.
Once you have all 4 bolts out, remove the factory shackles. Here is what you should be looking at:
Next, lower your axle to allow room for the longer shackles.
Comparison:
Be careful not to put pressure on your brake line running to your rear axle when lowering it or you may tear the hose.
Line up the new shackles using the jack to raise / lower the rear axle. Run the bolts through the shackles and leaf spring bushings making sure that they face the same way they did before. Tighten the 4 bolts.
Lift the rear axle again until you can reinstall the 2 bolts that hold on the shock absorbers. Install and tighten.
Raise the rear of the truck with the jack under your differential and remove the jack stands. Then lower your truck to the ground.
Your truck should be higher in the rear. To correct this, you will need to lift the front via tightening your torsion bar adjusting bolts.
In order to do this you will want to be on very level ground. Lift the front of your truck (I did mine one side at a time) and tighten the torsion bar adjuster by one revolution:
Repeat on the other side.
Lower your truck and drive it in a "figure 8" then return to the same spot. Measure from the top lip of your rim to the center of your fender lip like so:
The front measurement should be 1/2" lower than the rear to be level. If it is not, repeat the torsion bar turning until you reach the target ride height. The number of turns varies for each vehicle, there is no perfect number of turns.
You are done, get an alignment and bigger tires =D
post #2 of 221 Old 04-29-2010, 08:34 PM
02crewcab's Avatar
User is: 02crewcab is offline
Re: How To: 2" Shackle / Torsion Lift
good write up. but a tbar crank n shackle lift isnt that hard to do
Yea, though I crawl through the valley of the Shadow of Death I will fear no trail, for thou art modified, thy rig and thy lockers they comfort me.
'02 CrewCab SFA, D30/7.6, 33's, lots of goodies
Build Thread - http://www.s10forum.com/forum/f221/0...b-swap-487536/
post #3 of 221 Old 04-29-2010, 08:58 PM Thread Starter
For some it is. This is for them.
post #4 of 221 Old 04-29-2010, 10:43 PM
Well, you're crazy.....
Spennyman's Avatar
Location: West Virginia, don't believe what you hear.....
User is: Spennyman is offline
Thanks, very informative.
post #5 of 221 Old 04-30-2010, 02:19 AM
Registered Abuser
Merritt's Avatar
User is: Merritt is offline
nice write up
-James
2006 Time Magazine Person of the Year
Merritt is offline
post #6 of 221 Old 04-30-2010, 02:25 AM
User is: bigdaddykane93 is offline
hi, if you measure in the center holes, centerline to centerline of the new shackles bolt holes, what is the exact length? thanks
1995 S10 4x4 Pick Up Truck Extended Cab 6' Bed with a Cap 4.3 Vortec CPI "W" Vin Engine and Automatic Transmission with a factory 3.73 Posi rear with Z85 increased capacity suspension...
post #7 of 221 Old 04-30-2010, 03:09 AM Thread Starter
6 1/2"
post #8 of 221 Old 04-30-2010, 08:59 PM
S10 BALLIN's Avatar
User is: S10 BALLIN is offline
by doing a shackle lift and torsioin bar teak lift the truck up a lil bit? and doesnt tightning your t-bars give the front a harsher ride plus make front end parts go bad kinda quick
post #9 of 221 Old 04-30-2010, 09:18 PM Thread Starter
Yes, it lifts the truck. I did not notice a difference in ride quality, and have not experienced any front end parts wearing out prematurely. If you lifted it more than this, I believe they would wear quicker though.
post #10 of 221 Old 05-01-2010, 01:30 AM
Huge Ideas, Tiny Wallet
sockjock's Avatar
User is: sockjock is offline
BlaziNator your ride looks very familiar...like I've seen something very similar somewhere...hmm
Chris
  • '95 Blazer 4dr 4WD 2" BL, 1.5" tbar tweak, homemade AAL, 1.5" lift shackles, 31x10.50/15s, 1.5"wheel spacers in rear, K&N FIPK, underdrive pulleys, FL60 efan, cat delete, O2sim, 2.5"dynomax catback ex., transgo shiftkit, corvette servo, 3.73gears and G80rear
  • '97 Blazer 4dr 4WD WRECKED: Needs BCM, drivers' side fender, valance & possibly a few other parts
sockjock is offline
post #11 of 221 Old 05-01-2010, 02:07 AM
6 1/2"
just curious, did you measure the ride height before and after the new shackle kit installation to see exactly how you lift you gained?
post #12 of 221 Old 05-01-2010, 02:26 AM Thread Starter
Haha, yeah, I looked at pictures of your truck and they made me decide to remove the valence. But does your do this yet?
post #13 of 221 Old 05-01-2010, 02:29 AM Thread Starter
Yes I did, and no I don't remember what the measurements were. I believe it was just shy of 2" of real lift.
post #14 of 221 Old 05-01-2010, 02:32 AM
sockjock's Avatar
If I remember correctly the factory shackles are 4" center to center and he said the lift shackles were 6.5" center to center. So he should have got 1.25" of lift from the longer shackles. For each additional inch of length you add to the shackles you get approximately .5" of lift.
Chris
sockjock is offline
post #15 of 221 Old 05-01-2010, 02:41 AM
sockjock's Avatar
Doh...He beat me to the answer.
Chris
sockjock is offline
post #16 of 221 Old 05-01-2010, 02:47 AM
sockjock's Avatar
yeah I really do need to add some lights...wheeling in the dark is a real adventure. I like the rock lights.
Chris
sockjock is offline
post #17 of 221 Old 05-01-2010, 03:15 AM Thread Starter
If I had it to do again I'd go with these:
http://www.oznium.com/prewired-superflux
post #18 of 221 Old 05-02-2010, 04:27 PM
Tweek218's Avatar
User is: Tweek218 is offline
Thank you for the write-up. I'll be using the info.
Tweek218 is offline
post #19 of 221 Old 05-05-2010, 06:16 PM
User is: Ajvdub is offline
Excellent write up! Was there a negative change in ride quality after the T Bar adjustment?
BTW, dig the lights man!
Ajvdub is offline
post #20 of 221 Old 05-05-2010, 07:40 PM Thread Starter
None that I noticed. Or my wife for that matter. (she has a matching one)
post #21 of 221 Old 05-06-2010, 12:46 PM
what lights are you using? you have inspired me to light up my 93 Noma!
Ajvdub is offline
post #22 of 221 Old 05-06-2010, 03:10 PM Thread Starter
Underneath I use $12 per set halogen utility lights from Northern Tool...cheap and effective.
If I had to do it again though, I would try these:
In front are $12 a piece utility lights also from Northern Tool:
Up top are $12 a piece utility / "off-road lights" from Northern Tool. They are more of spot lights whereas the other two types are a flood style beam. Here is a picture of them on my wife's truck in the daylight:
post #23 of 221 Old 05-06-2010, 06:25 PM
Will those be as bright and effective as the ones you have?
Ajvdub is offline
post #24 of 221 Old 05-06-2010, 06:48 PM Thread Starter
From what I have heard, they are really bright...for LED's. I have this feeling mine are brighter though. There is a picture of them in use on this thread here...on a Jeep...lame.
http://www.dfw-tx4wd.org/forums/Fina...me-m56710.aspx
post #25 of 221 Old 05-18-2010, 10:29 PM
User is: fatty6042 is offline
nice write up
post #26 of 221 Old 05-25-2010, 08:40 PM
finally runs!
Redsdime's Avatar
User is: Redsdime is offline
what tire size are you running on both of the blazers?
i just bought a 96 that i think has this lift done to it...
(i can get pics if needed)
-Kevin
98 S10 6.0 LSX T56 ford9
06 GMC LBZ Duramax stock so far
-- project thread--
http://www.s10forum.com/forum/f213/a...me-lol-513014/
Redsdime is offline
post #27 of 221 Old 05-25-2010, 09:12 PM Thread Starter
I am running 31x10.5's Which most everyone will tell you is impossible...Here's how you do it:
Cut the front valence at the fender for clearance, Like so:
With the stock rims this is the only place it rubbed on mine at ride height (apart from at full lock) I have my torsion bars turned to where the front fender is .5" lower than the rear (level) when measuring from the bottom edge of the center of the fender to the top lip of the rim on flat ground as stated earlier in the thread.
When stuffed (or when hitting a large bump) the outside edge of the front tires graze the inside lip of the fender. To compensate for this I beat that lip up and flush with the inside of the fender with a 2.5 lb hammer. It helps to take the tire off when doing this. USE JACK STANDS. (safety first) It should look like so:
That's it...the rear clears the fender entirely with no trimming. I think the front tires still MIGHT rub under a hard turn during EXTREME flex (I mean extreme...I have no bump stops lol) But it isn't enough for me to tell, or to hurt anything. I certainly do not rub under normal driving conditions.
My tires DO rub under full lock (turned as hard as possible) on the frame rail and the sway bar when it is connected. Mostly on the sway bar. I just dont turn as hard as I can. Saves the power steering anyway. :icon_wink: You will only lose about 1" of steering wheel turn. My wife doesn't seem to mind driving this way either. Even if you didn't compensate, it only makes noise.
If you get a 2" body lift I hear that you can clear without trimming. I personally hate body lifts though. Hope that helps =D
BTW...what does it take to get a sticky around here? XD
post #28 of 221 Old 05-25-2010, 09:20 PM
muddin97s10's Avatar
User is: muddin97s10 is offline
yeah i dont like body lifts either. they make the truck look bad
only good after theres like 8" of lift and u need a 3"body to fit those massive 37"s haha
post #29 of 221 Old 05-25-2010, 10:00 PM
finally runs!
Redsdime's Avatar
i think my shackles are some off brand that are a lil bigger i have 31s that are bald and it barely rubs at full lock. when i got the blazer last weekend the previous owner claimed that the susp was stock. but when i got there you can see that its not
link to pics
http://www.s10forum.com/forum/f3/try...is-one-441709/
-Kevin
-- project thread--
Redsdime is offline
post #30 of 221 Old 06-01-2010, 06:52 AM
96superflow's Avatar
User is: 96superflow is offline
Blazinator where did you get those lights? I have the same ones but can't find them anymore i need 3 more. (one i left laid back and it filled with water and popped the bulb) Are they the 10 dollar special's at Northern tool?
1996 4dr 4wd Blazer D30/8.8 combo w/ 4.10s, sky manu kit, rancho 44044 springs. 33" tsls, Dynomax muffler...Still Dead in the water
2001 Chevy Tahoe 5.3 Corsa Sport, Ranch Hand Legend, keys and spacers, Hummer H3's, 265/75/16 Cooper ATPs, Daily/tow Rig...
post #31 of 221 Old 06-02-2010, 03:36 AM Thread Starter
That's them. =D
post #32 of 221 Old 06-09-2010, 10:53 PM
User is: mikeS14 is offline
Send a message via Yahoo to mikeS14
im lookin at fixin up my s10 zr2. i just got rims and i wanna get a lift. i was wondering how high can the tortion bars be turned up?
mikeS14 is offline
post #33 of 221 Old 06-10-2010, 04:49 AM Thread Starter
They can go up a little ways...but anything over 1.5" - 2" will cause premature wear of your front end parts. I wouldn't recommend it.
post #34 of 221 Old 06-13-2010, 01:12 AM
sockjock's Avatar
Nothing a solid axle swap won't fix.
Chris
sockjock is offline
post #35 of 221 Old 08-27-2010, 03:25 PM Thread Starter
Who do I need to talk to about getting this stickied? I'm tired of searching for it to answer questions lol.
post #36 of 221 Old 08-27-2010, 08:55 PM
Not stuck yet
pj5454302's Avatar
User is: pj5454302 is offline
DAMN YOU blaziNator and your rock lights!! Just when I get my HID reverse lights you 1 up me with this.
Wayyy to many mods to list locked lifted and ready to hit the trails
Rock'n 167,000
2009 Yamaha xt250 enduro ( saves me money, and kicks ass on the trails)
post #37 of 221 Old 08-28-2010, 07:32 PM Thread Starter
Haha...had um for a while actually. XD Wish you lived closer man - our rigs could tear up the trails. Might even show up a few Jeeps. =o
post #38 of 221 Old 08-28-2010, 07:51 PM
Not stuck yet
pj5454302's Avatar
Leading the pack
And damn those 1,296 miles and various states making us wheeling together a pain in the ass!!
Rock'n 167,000
post #39 of 221 Old 08-28-2010, 10:25 PM Thread Starter
Haha XD
post #40 of 221 Old 08-29-2010, 10:05 AM
meet up half way!
post #41 of 221 Old 08-29-2010, 11:22 AM
Not stuck yet
pj5454302's Avatar
Rock'n 167,000
post #42 of 221 Old 08-29-2010, 11:21 PM Thread Starter
That would be an epic journey indeed...There is talk of a trip to Moab next summer. Just tossing that out there.
post #43 of 221 Old 08-30-2010, 08:21 AM
Not stuck yet
pj5454302's Avatar
Meh, my family used to drive to daytona beach florida every year, Im used to long drives.
Rock'n 167,000
post #44 of 221 Old 08-30-2010, 10:07 AM
I'll have to see how far moab is!
post #45 of 221 Old 08-31-2010, 04:01 PM
Not stuck yet
pj5454302's Avatar
Only a couple thousand miles
Rock'n 167,000
post #46 of 221 Old 08-31-2010, 08:29 PM
You aint kidding. My junk would have to be trailered!!!
post #47 of 221 Old 09-01-2010, 02:24 PM
Not stuck yet
pj5454302's Avatar
Bahhh, driver there. The drive is half the adventure!!
Rock'n 167,000
post #48 of 221 Old 09-01-2010, 07:04 PM
haha. yeah, drive to moab with no a/c and a slipping tranny. Sounds like a helluva an adventure!
post #49 of 221 Old 09-02-2010, 12:41 AM
V6 Mud Truck's Avatar
User is: V6 Mud Truck is offline
What size tires are you running in this picture?
post #50 of 221 Old 09-02-2010, 08:14 AM
Not stuck yet
pj5454302's Avatar
In that pic its stock size tires.
Rock'n 167,000
