Broke a cab mount bolt
Go Back   S-10 Forum > Suspension Tech > Liftin' It > 4wd IFS
Old 10-27-2009, 04:51 PM   #1
Kmaroman's Avatar
I bought a 2000 s10 awhile back, and just rescently got a 2in body lfit for it. Well i followed the crappy instructions best i could, i had to take the whole front end off.
I finally get far enough to start putting the blocks on and the front bolts came out easy well the bolt wright before the passenger side tires decides it wants to be an asshole, split in half leaving the top part still in. I was so pissed smoked about 5 cigarettes, and put everything back together till inlaw can help me.
Is there any easy way to get the top half of the broken bolt out, with out hacking in slashing? Here's the kicker if you guys wanna laugh, I realized after going to town I may have been tightening it It is 4wd btw
Old 10-27-2009, 05:15 PM   #2
96superflow's Avatar
Re: Broke a cab mount bolt
damn that sucks. It happens to all of us man. the only way i see that you is that you jack up the cab and get a tourch and vise grips on the bolt, then loosen it.
Old 10-27-2009, 05:29 PM   #3
4x4 v6 blazer
neo71665's Avatar
Try the heat and visegrips trick, it normally works. If not you might have to pull the carpet up and cut a flap over the captured nut so you can get some oil directly on the top so it soaks in. Its a PITA but once you put the carpet back only you will ever know it was done.
Old 10-27-2009, 05:41 PM   #4
Kmaroman's Avatar
thanks a ton for the help guys, any other ideas are welcome I'm going to keep driving like this for a month or so glad it has 4 mounts on each side. Till my in law has time
Old 10-27-2009, 10:38 PM   #5
just keep an eye out on all the other bolts! make sure they stay torqued to spec!
Old 10-29-2009, 02:44 PM   #6
I Rather Be Wheelin'
ChrisInVT's Avatar
I had similar issues with my truck since it was all rotted out when I purchased it. If you have a welder (or a friend that does) get a LARGE nut, we're talking like 2" or bigger. Weld the nut onto the shaft of the bolt. Let it cool down and then remove the bolt. The heat from the welding along with the extra torque of the larger nut will ease in the removal of the sunovabitch.
Old 11-02-2009, 01:03 AM   #7
ARE YOU F*CKING HIGH?
CouJoe56's Avatar
i dont wanna sound stupid but you torque these to spec? i have a 2wd but when i put in poly mounts i just made the TAF
what are these "torque specs"
Old 11-02-2009, 08:10 AM   #8
i dont remember actually, im pretty sure it said in the instructions for the PA body lift i put in. I would say nothing less than about 80 ft lbs, maybe more like 95-100 ft lbs
Page generated in 0.56497 seconds with 31 queries
[Output: 64.36 Kb. compressed to 60.59 Kb. by saving 3.77 Kb. (5.86%)]
