anyone riding on 32" tires
Go Back   S-10 Forum > Suspension Tech > Liftin' It > 4wd IFS
Old 07-29-2009, 10:48 PM   #1
outlaw
outlaw skinny d's Avatar
if so what kinda lift do u have and how much fender trimming have u done?
Old 07-29-2009, 10:52 PM   #2
Deaths Shadow's Avatar
Re: anyone riding on 32" tires
i'm running 32's BFG ATs/ Cooper ATs
Old 07-29-2009, 11:21 PM   #3
BuzzerPB's Avatar
I was running 32's with a 3" body lift and some fender triming.
you can see how much you'd have to trim for these rears 2 fit..
Front after triming and some trail damage
Old 08-01-2009, 12:24 AM   #4
Lifted without a clue
Svenson14's Avatar
2nd gen w/ 6" lift and 32x11.5. 3.25" bs i think
A little trimming on the front and no trimming in the rear.
The rear rubs at full compression and the front rubs with compression while turning
Old 09-22-2009, 08:07 AM   #5
tommyramone55's Avatar
idk i have moogs 3 inch spindles and a 3inch bl and cleared 33s but obviously it was tight.
Old 09-22-2009, 08:08 AM   #6
on my 2wd 2gen sonoma lol
Old 09-22-2009, 11:36 PM   #7
Registered Asshole
crazy91s10's Avatar
thought you were getting a 5 or 6 inch kit... shouldnt have to trim at all for 32s
Old 09-22-2009, 11:51 PM   #8
forum idiot
orangesonoma's Avatar
no? mine would eat the shit out of the front fenders with a 5 inch and 32's i also have 2wd offset wheels
Old 09-23-2009, 02:54 AM   #9
Banned
back when i first got my zr2, it had a 2" body lift and 32" swamper radials... on a regular 4x4, youll have to do a 2" or 3" bodylift, and crank the torsion bars, and probly trim the fenders a little too... hell my zr2 scrubbed the factory 31" tires when i flexed hard
Old 09-23-2009, 10:03 PM   #10
DOHC-S10's Avatar
32 11.50 15 on 10" wheels with 4" bs. 3" BL small t-bar crank on a 96 x-cab. Never rubbed the rears. The front only rubs every time I turn. Well not every time but I am far from lock to lock turning. I need a trim!
Old 09-24-2009, 09:25 PM   #11
Registered Asshole
crazy91s10's Avatar
true... was thinking along the lines of stock wheels on 6" backspacing
Old 09-27-2009, 02:33 AM   #12
Blazn1's Avatar
I'm running 32x11.5x15 on stock rims. 2" BL, 2" shackles, t-bar levelers. I rubbed on the frame in front so i put on some 1.25 spacers. Still rubbed on frame but started rubbing on edge of inner fenders when at full compression while turning. I took off the spacers and now looking for some wider spacers maybe 2.5. Probably going to have to trim with new spacers.
Old 10-05-2009, 12:14 PM   #13
bad s-10's brewing
solenoid's Avatar
I have a TM 4" kit on mine with stock BS rims and it rubs frame no fenders,thinkin bout 33 x 10.50's.
Old 10-30-2009, 11:59 PM   #14
i have 31x11.5 on stock rims with 2"BL and stock t-bar cranked and i have little to no rubbing...
Old 11-03-2009, 07:30 PM   #15
Quikz28's Avatar
does anyone run 32 x 10.50?? if so who makes them??
im running 31 x 10.50 with no lift not even torsion bar crank, im looking to upgrade to 32 x 10.50s, i know im gonna need some fender trimming but does anyone have any rubbing issues with the frame
Old 11-03-2009, 11:40 PM   #16
dimedragger218's Avatar
i got 32 10.5 tsl radials... 01' blaze zr2 no lift. trimmed 1.75" at bottom of air dam to .5" at top off bumper... trimmed 1.25" out of fender and cab flanges under inner fender well, then hammerd the well back... took like 3/8" out off flares by pie cuts then heat guned and urithained it back to gther... havent touched the back yet... front dont rub and back only when bottomed out...
Page generated in 0.59082 seconds with 32 queries
[Output: 90.89 Kb. compressed to 84.22 Kb. by saving 6.67 Kb. (7.34%)]
