any way to test 4x4 during a test drive?
Go Back   S-10 Forum > Suspension Tech > Liftin' It > 4wd IFS
Old 09-13-2009, 01:12 PM   #1
Is there any way to test to see if the 4x4 is working during a test drive other than jacking it up and setting it on jack stands?
Old 09-13-2009, 01:17 PM   #2
Registered Asshole
crazy91s10's Avatar
Re: any way to test 4x4 during a test drive?
find some thick mud...
seriously though... quickest way to find out is put it in 4wd and make a slow left or right turn at full lock.. should feel a little bit of binding while making the turn.
Old 09-13-2009, 01:18 PM   #3
Find a gravel parking lot. Roll down the drivers side window. Put the truck in 4Hi and crank the wheel all the way (either way is fine, but I turn to the left). Drive in a SLOW circle. If the front tires scrub, the 4wd works. Stop and shift to 4Lo. Do the same thing.
Old 09-14-2009, 02:39 AM   #4
Registered Abuser
Merritt's Avatar
When I first got my truck the 4x4 vacuum actuator was bad, I found some gravel and put it in 4x4 and gave it some gas. The rear tires spun and the truck didn't move, so I knew the 4x4 wasn't working. Pretty straight forward.
Old 09-14-2009, 05:09 PM   #5
I agree with the gravel method..give it some gas, and if you spin, it doesnt work. you shouldnt be able to spin the front wheel in gravel unless you floor it, so any wheel spin should show a problem..
Old 09-14-2009, 11:21 PM   #6
forum idiot
orangesonoma's Avatar
put it in 4wd and try to power brake it..if the rear wheels spin=no 4wd..if it lunges forward=4wd..
thats how i test it
Old 09-15-2009, 12:35 PM   #7
I like boobies
AlabamaNoma's Avatar
4 jack stands in my garage.
Old 09-17-2009, 11:40 AM   #8
Too much workon a test drive.
Old 09-17-2009, 11:48 AM   #9
where's my chippy?
lee-mill's Avatar
thats how i test it
x2 the guy i bought my jeep from got all pissy when i did that
Old 09-17-2009, 12:03 PM   #10
Broken Handed Superman
MeltingPlastic's Avatar
i like the curb method or parking block... pull the truck up to a curb or parking block and let off the gas, in 2wd itll just stop... in 4wd itll want to lurch over the block
