2wd wheels on a 4wd s10 - S-10 Forum
post #1 of 8 Old 10-27-2009, 07:04 PM Thread Starter
s10Newbie88's Avatar
User is: s10Newbie88 is offline
Exclamation 2wd wheels on a 4wd s10
Im thinking of getting a set of cragar soft 8s for my 96 s10 4.3 4x4 but as we all know the backspacing between a chevy 4wd wheel is very different from a 2wd. i was just wondering if i would have any clearance issues while turning in the front if i only have the torsion bars cranked. i want that wide look but i dont have the money to lift the truck yet. if i have to lift it would just a 2 inch lift be enough? and what width rim would be fine to go with? i think stock is 15x7 or 8 in 4wd? thanks again oh and i have 30x9.5 tires right now
post #2 of 8 Old 10-27-2009, 07:33 PM
keepin it freshhh
Slowlowandbangin's Avatar
User is: Slowlowandbangin is offline
Re: 2wd wheels on a 4wd s10
if you get 15x7 it will have a 4" backspace
so it will stick out 2 inches more than stock 4x4 6" bs wheels
stocks should be 15x7 as well
Slightly static dropped: SLAB
Totaled
1st Time Around
Follow me on Instagram! @slowlowandbangin
Originally Posted by IhaveNoPantsOn View Post
You shut your whore mouth!
Originally Posted by BlazerZR5 View Post
all straight fact based on observations of your continued retardation.
post #3 of 8 Old 10-28-2009, 10:03 AM Thread Starter
so with that backspacing it shouldnt rub the wheel wells?
post #4 of 8 Old 10-28-2009, 10:27 AM
nox
rox
nox's Avatar
User is: nox is offline
Send a message via AIM to nox
it might rub when you turn because the tires are out further now.
nox is offline
post #5 of 8 Old 10-28-2009, 11:15 AM
Slap my meat on your pita
GeorgesBlazah's Avatar
User is: GeorgesBlazah is offline
It will rub. Get a sawzall.
I had a 2in body, tbar and 31s on 15x8s with 3.75bs and it rubbed like a mofo. Rim width all depends on how wide of a tire you are going. If you just planning on stickin with 9.5in wide tires your fine. 7 is good up to 10.5in, so if you stepped up to 31x10.5 youd be alright with those wheels. Any wider and its reccomended that you go for a 8in wheel.
George
98 Blazah 6in SL - 2in BL - 4.56s - Detroit ITS AN ANIMAL 4x4 BUMPER. IT IS NOT MADE ANYMORE, BUT YOU CAN BUY MINE FOR $6000
BLAZER PICS AND INFO CLICK ME
Founder/Godfather of the Anti-Bag Coalition
"Bags are for groceries"
post #6 of 8 Old 10-28-2009, 08:12 PM Thread Starter
if anyone has any pictures of what they did with their s10 or blazer post them so i can see. so if i do a 2in suspension lift with the 30's i should be alright with the turning clearance with 15x7 2wd wheels right?
post #7 of 8 Old 11-09-2009, 12:30 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
Moved.
I put BFG A/T 32x11.50x15 on stock swirls, it fit on the rim BUT cannot put weight beads onto rim BUT it fits lol.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #8 of 8 Old 11-09-2009, 01:36 PM
I Rather Be Wheelin'
ChrisInVT's Avatar
User is: ChrisInVT is offline
I only have a 2" BL on my truck with 2wd wheels and 33x12.50's. It requires some fender trimming to stop from rubbing.
Originally Posted by 96superflow View Post
Who needs independent suspensions when you have independent engines?
1987 4.3L 2D GMC S-15 4WD X-Cab Anti-Bro Truck (4.3 & 700R4 Swap, Custom bumpers, too many other mods. )
You may post new threads
You may post replies
