10" of lift?
Go Back   S-10 Forum > Suspension Tech > Liftin' It > 4wd IFS
Old 10-28-2009, 09:04 AM   #1
VortecSonoma's Avatar
10" of lift?
im trying to figure out a good way to get the most lift possibly for my truck without going to SAS ( its my new daily driver so i cant have it out of commission for to long) so far what i found is:
Superlift 6" lift kit for ZR2/ Highrider (i notice this doesnt come with keys for torsion bars)
2" keys and shackles
2" body lift
now if i do this, will i be able to run 33x13.50 comfortably and still have a nice ride? and if i decide one day i want to run 35s will they fit with out rubbing? (i wont be doing any 4 wheeling, its just for show....)
Old 10-28-2009, 10:15 AM   #2
Re: 10" of lift?
You do NOT want aftermarket Tbar keys unless your Tbars are badly sagging. (In that case, buy new Tbars.) You don't want to lift the front of your truck more than about 1.5" (from stock) using the Tbars unless you want to replace front end parts on a regular basis.
You can get about 9.5" of lift with a stock Tbar crank (1.5" plus shackles or AAL for the rear), 2" body lift and SL6. With that lift, 33x10.50s should be easy (depending on the backspacing of your choice of wheels). 33x13.50s might be pushing it. 35s "should" fit unless you plan on flexing depending on the width. Keep in mind that the wider the tire, the more the truck has to work to turn it. The stock suspension/steering wasn't made for big tires. IMHO, a 33x10.50 or 33x12.50 is about max you should run without the added strength of a solid front axle.
For what you'll spend on the lift(s) and regearing, it would be cheaper to go SFA. I think the only thing you'll lose is ABS (but don't quote me on that).
Old 10-28-2009, 12:17 PM   #3
96superflow's Avatar
Re: 10" of lift?
ill just say one thing. 10" of lift out of the IFS is stupid. Hope i dont offend you by saying that.
Old 10-28-2009, 02:17 PM   #4
Re: 10" of lift?
no sir, point well taken, i just wanted to see what everyone could offer to me.
the kit is about 2k for the superlift. then another 100 bucks or so for the body lift. plus the cost of labor with will probably run 75-80/hr.
id like to do a SAS but i dont have any welding skills. i can fab, but just cant weld, i dont have a clue of how to do it or whats consider a good weld or what type of welder is needed for a SAS. and on top of that i wouldnt know which type of axles to get, what to look for and what other parts i would. i have done research on SAS in the past, but still i draw a blank... unless i had someone sit there and point out and say ah you need this and you need that and your going to need two of them, id be barking up the wrong tree....
and my other thing about a SAS if i did it, i think it would be a waste of time to just run 33s on that type of set up id say the smallest tire id run would be a 35...
Old 10-28-2009, 02:30 PM   #5
Re: 10" of lift?
i only have about 1000 in my truck right now and thats all the axles and everything. 2k is too much to lift it when it is still inferior. I wanted mine for articulation purposes, as well as strengthen it. i plan on running 35s, but i have 2 sets of 33s one mud, one allterrain, they were free. thats the other reason im going with them first.
Old 10-28-2009, 02:46 PM   #6
992drjimmy's Avatar
Re: 10" of lift?
2" body lift
If all you plan to do is street drive for looks, The superlift is supposed to be a good lift.
You dont need the keys, They will justtear up your suspension.
When you do the body lift, Go with a 3" for a first gen truck.
If you are going to do a sas, i wouldnt sacrafice a zr2. Start with a reg 4x4.
Old 10-28-2009, 03:03 PM   #7
Re: 10" of lift?
good points from both of you guys. ok, im setting down to 33x12.50x15, their cheaper.. :-D .... now for the lift..i think for now i will do the 6" lift with a 3" body lift and leave my tbars alone. but if i cant get the kit for less than 1500, then im going to go the SAS. i forgot i had a friend that built a fullsize blazer that currently sits on 44 boggers. im sure he'd be more than welling to help me out being as he's a truck nut from hell...
Old 10-28-2009, 04:05 PM   #8
SnoMan's Avatar
Re: 10" of lift?
I say go with the SFA. Stronger, cheaper and personally looks cooler cuz a 3 inch bl looks stupid IMO.
Old 10-28-2009, 04:10 PM   #9
Re: 10" of lift?
thats the friend to have. Hopefully his welding skills are up to par.
Old 10-28-2009, 05:03 PM   #10
992drjimmy's Avatar
Re: 10" of lift?
What exactly looks so stupid about the 3" bodylift. Heres mine.
Old 10-28-2009, 06:34 PM   #11
Re: 10" of lift?
holy shit! i love it....what kind of wheels do you have?
Old 10-28-2009, 06:45 PM   #12
Re: 10" of lift?
this is the monster my friend nick built, he does this shit for a living, works for a shop here in f'burg called showcase
Old 10-28-2009, 06:57 PM   #13
SnoMan's Avatar
Re: 10" of lift?
Its not that they are always stupid, like most people put nerf tubes on to cover the frame like i plan to do when i do my 2 inch bl. But for me personally a 3 inch bl just shows to much frame. Dont get me wrong your truck looks real nice, but its in proportion. from ur sig u have 5 in the suspension also. like trucks with just a 3 inch bl dont look to hot
Old 10-28-2009, 07:03 PM   #14
992drjimmy's Avatar
Re: 10" of lift?
LOL you are the one of the few that say they like the wheels. They are some old prime brand wheels from the 90's. They are 15x9. I got them real cheap for the size. Plus i could use stock lug nuts. I bought and lifted this truck on very tight budget. Looking for deals on parts. Got the body lift about 3-4 years ago at a garage sale complete for $10 bucks, figured for that price one day id use it. Got the wheels for 75. Truck for 900 plus 800 for rebuilt tranny including install and 2 year 24k warranty. I do need new tires. The ones i have only got about15-20%tread and bad wear pattern from previous owner running bad alignment.
Old 10-28-2009, 07:05 PM   #15
992drjimmy's Avatar
Re: 10" of lift?
That truck is AWESOME. Bet the MPG's suck. LOL. I had a 79 silverado about 6 years ago with 35's. If i babied it i got maybe 10mpg. Maybe....
Would love to sas my 2wd. I found a good parts blazer for tranny and xfer case with factory floor shift xfer case. Seems hard to find that in a second gen truck.
Old 10-28-2009, 07:33 PM   #16
Slap my meat on your pita
GeorgesBlazah's Avatar
Re: 10" of lift?
SFA is only cheaper if you can do the work yourself and if your not planning on going offroad, I dont see why you are wasting your money on it.
Everyone that says "GO SFA!!1 GO SFA!!111" knows that once you complete the SFA its still not done and needs to be tweaked some. Hlaf of the rides done in the SFA section werent perfect on the first try and things were tweaked. I am not saying that they are POS`s, just stating an observation.
With an IFS lift you are getting a working and driving like it should truck at the end. All of the engineering has been done already and you dont need to tweak anything.
6in SL + 2in body should net you plenty of clearence with 33x12.5 tires with the right BSed wheel. Specially if your staying on the street, you dont hafto worry about shit. Upgrading later to 35s? Better bring out the sawzall.
Old 10-28-2009, 08:50 PM   #17
Re: 10" of lift?
lol thanks Geroge.... but no Sawzall lol...i like my truck looking clean...and i dont have the straightest cut without a guide.
Old 10-28-2009, 08:53 PM   #18
Re: 10" of lift?
im old school man, i like them 80's-90's style wheels lol..for some odd reason...
now with the first gen 3" body lift, wont i need other things like a bumper adapter to lift it up the additional 3"s and something for the steering? im all about custom work but i like to know whats a head of me...
yeah my friend nicks's rig is pretty out there, he's got a ton of hours into it and is still tweaking it till this day.. a lot of "borrowed parts" i think he has like 26" or more of lift i cant remember what he said...
Old 10-28-2009, 09:53 PM   #19
Re: 10" of lift?
heres the wheels im looking at buying not a bad price not sure about the back spacing though.. http://www.summitracing.com/parts/AE...4/?image=large
and the tires.... http://www.discounttiredirect.com/di...sw=false&cs=33 or http://www.jcwhitney.com/jcwhitney/product.jcw?nval=1101016152&statenval=1101016152&p roductId=2011852&shopid=100001&pageid=13&skuId=359 238&id=3326199
Old 10-28-2009, 10:15 PM   #20
Re: 10" of lift?
That backspacing is gonna rub like a mofo, its 3.25
Old 10-28-2009, 11:09 PM   #21
Re: 10" of lift?
George makes a good point. If you dont mind having your truck down for an amount of time (excluding billaksblazer haha, doin it in a weekend doesnt count) and you can do the work yourself, its a helluva lot cheaper. And you will be tweaking it to get it right as with any custom suspension.
I weighted the options cause before i went solid axle, i was just going to add a ifs lift to mine, but the more i looked into it the more i figured out i needed something more dependable for what i do. I also cant justify spend just as much on a suspension lift as i did for the entire truck!!! (only paid 2450 for it about 3yrs ago)
Old 10-29-2009, 06:20 AM   #22
Re: 10" of lift?
ah ok ill see if i can find wheels with 6" back spacing then.
Old 10-29-2009, 10:37 AM   #23
992drjimmy's Avatar
Re: 10" of lift?
You will not have to modify the steering at all. You will need 4 extra blocks to lift the fron bumper, and 2 extra for the rear. Or other way to fab rear brackets. Im not a fabber and i figured it out easily.
Old 10-29-2009, 11:09 AM   #24
Re: 10" of lift?
Id look for something from 4.5 -5.5. 5in would be ideal IMO
Old 10-29-2009, 12:37 PM   #25
992drjimmy's Avatar
Re: 10" of lift?
yeah 4.5 woulld be perfect. Itll keep the bigger tires out of the frame and give a little wider stance.
Old 10-29-2009, 07:27 PM   #26
Re: 10" of lift?
thats what im looking for! hoping i can find the same design just different backspacing...
Old 10-29-2009, 07:28 PM   #27
Re: 10" of lift?
sorry to sound like a dip shit, but what do you mean by blocks and how to i put those in...
Old 10-29-2009, 08:04 PM   #28
Re: 10" of lift?
Find some 3"x3" mild steel (or aluminum) square tubing. Cut off sections about 4" long. Put those between the bumper and the frame (where the bumper mounts). You might need longer bolts.
Old 10-29-2009, 08:19 PM   #29
4x4 v6 blazer
neo71665's Avatar
Re: 10" of lift?
Use a cutoff wheel. I sectioned 2 inches out the front and pie cut 1.5 out of the rear. Then welded everything back up. I still need to finish with a skim coat of bondo and sand it smooth. I like my stuff to look factory.
Done a 3" on mine. The steering was fine. I had to extend the gas filler and didn't have to but extended the 4x4 shifter so it looked factory. The bumpers are custom ones I made but I did have to raise them. Well raised the rear, still working on the front so it was more of a redesign the mounting.
Old 10-29-2009, 09:34 PM   #30
992drjimmy's Avatar
Re: 10" of lift?
The front bumper actually sits on mounts kind like the body does. The lift block go on the frame mounts and the bumper sits on them.
Old 10-30-2009, 07:54 PM   #31
Re: 10" of lift?
ok gotcha thanks. im ordering the body lift kit right now!
Old 10-30-2009, 08:04 PM   #32
Re: 10" of lift?
i got two links here, first one is a kit for a 1994 s-series zr2 3" BL and the other one is a 3" BL kit for a 83-93...which would will work better...
http://www.shopatron.com/products/pr...1.32354.0.0.0?
or
Old 10-30-2009, 10:09 PM   #33
992drjimmy's Avatar
Re: 10" of lift?
Get the cheaper one. But... I believe you can get it cheaper from summit racing or of course ebay.
Old 10-30-2009, 10:14 PM   #34
992drjimmy's Avatar
Re: 10" of lift?
http://www.summitracing.com/parts/SUM-7853300/
Here ya go. You will need to get some extra blocks for the bumper, or get some square tubing like a hitch is made of and cut some 3 inch legths for the bumer and get a few more bolts from the hardware.
No big deal though.
Old 10-30-2009, 11:35 PM   #35
Re: 10" of lift?
Thanks 992drjimmy! i like the price savings! i actually made the blocks today and got some bolts!
Old 10-31-2009, 12:22 PM   #36
992drjimmy's Avatar
Re: 10" of lift?
Depending on how you do the rear, I used blocks on the rear bumper as well and cut the stock brackets in half. Ive got a pic if you need. I cant weld too good, so that was easiest for me to do. I didnt extend the filler hose. I just disconnected it from the body and it works ok like that.
Your neg battery cable will be real close, but mine worked ok, although theres not really any slack in it now. Just watch you brake lines through the wheel wells when you lift the body. If your steering feels like it has a slight bind. Take the steering shaft out and reinstall it. For some reason that takes care of it. Took me about 6 hours by myself. Also a good time to do electric fan. Or if you plan to down the road, take the lower shroud out. IF you are going to leave it, I just remembered you will need to get some nuts and bolts and some 3" sleeves for them so youcan space the shrouds apart. I have camaro e-fan. So id forgotten about that part.
Old 10-31-2009, 12:44 PM   #37
meadman's Avatar
Re: 10" of lift?
Wow that is a lot of info!!! lost my sign on and stuff a while back so i started a new one so i could get info and post. i want to start working on lifting my 2000 zr2 widestance.... looks like i need to re-think some of my options!!
Old 10-31-2009, 03:13 PM   #38
forum idiot
orangesonoma's Avatar
Re: 10" of lift?
zr2 have a wider fender opening then regular s-series so trimming may not be needed for 33's
i have seen plenty of zr2s on 33's with nothing more then a body lift and a t-bar crank..and shackles
Old 10-31-2009, 05:17 PM   #39
992drjimmy's Avatar
Re: 10" of lift?
Yes ive seen this once. Lifted S10 are RARE where i live. I mean R A R E!!!!!
Old 10-31-2009, 06:15 PM   #40
Fvck New Jersey
Tim99Zr2's Avatar
Re: 10" of lift?
werd, thats how i rolled, i cut the shit out of my front fenders thou
Old 10-31-2009, 07:07 PM   #41
Re: 10" of lift?
hmmm I didn't even notice you had a Z. I have seen plenty of Zs with a BL, tbar and trimming with 33x10.5sand it looks pretty damn good.
Old 11-01-2009, 06:05 AM   #42
Re: 10" of lift?
Thanks guys for all the info.
Old 11-02-2009, 02:17 AM   #43
Just a country boy.
Re: 10" of lift?
2" body lift
2nd the no go for the torsion keys.
On a Zr2 the 6'' superlift alone is fine with 33's.
The width of the tire will determine the BS you need but keep in mind IFS does NOT like little backspacing.
If you "decide one day you want to run 35s" add the 2'' body.
Old 11-03-2009, 12:08 PM   #44
BillaksBlazer's Avatar
Re: 10" of lift?
There is nothing wrong with doing a sfa in a weekend LOL haha
Old 11-03-2009, 06:40 PM   #45
Re: 10" of lift?
come do mine in a weekend ill pay for the cost of your trip... hahaha
Old 11-03-2009, 08:30 PM   #46
992drjimmy's Avatar
Re: 10" of lift?
Count me in on that as well.
Old 11-03-2009, 09:08 PM   #47
Re: 10" of lift?
lol. Nope there aint nothing wrong with it, but after working on mine, i would have been hitting the shit out off everything with a sledge hammer!!!
Old 11-04-2009, 05:11 PM   #48
Re: 10" of lift?
there was a BFH and a few holes in the wall when we were done. We worked quick but it was for the best.
Old 11-06-2009, 09:48 PM   #49
Re: 10" of lift?
yeah man, the main difference is that yours it your daily, mine is just a wheeler. Im just takin my time! ha. and that college budget kills it too.
Old 11-07-2009, 07:50 PM   #50
Re: 10" of lift?
i really didnt spend that much on mine. the only things that i did was gears and lockers. Im glad i did it though, everybody who wheels knows my blazer. For the guys who want me to do theirs pay for the labor the parts and the beer, and have all the tools there and im game.
