trying to lift a stock s10
Old 10-18-2009, 05:17 AM   #1
I have a stock 97 s10 2wd and i want to get it lifted 6" just for appearance and some very very light trail riding. I was wondering if you guys know the best way to go about it and where to get the parts. I plan on doing a 2" body lift but thats later on down the road. Im on a limited budget so if i can do one thing at a time that would be hella cool. Id really like to do a v8 swap also because of the little 4 cyl.
why would chevrolet put a 4 cyl in a truck? it gets bad mpg anyways why not just go with 4.3's? anyways thanks in advance.
i was thinking just getting 3" spindles, larger springs, shocks, and dont know about the rear yet. any sugguestions on what to get first?
Old 10-18-2009, 10:21 AM   #2
'00 Dime
alarm_the_alarm's Avatar
Re: trying to lift a stock s10
if your going for 6 inches of lift the best for the back would be a axle flip
Old 10-18-2009, 03:54 PM   #3
ok will do. does anyone know what ill need in my situation and where a good place to look and get great prices? what should I do first spindles?
Old 10-18-2009, 09:28 PM   #4
Moderator
What?'s Avatar
You can buy Aim spindle from eBay for $237 shipped, then buy 2" lift coils. As for rear, you can do 3" lift shackle and you get your height you want.
Old 10-19-2009, 02:39 PM   #5
sapperb's Avatar
Search button
Old 10-23-2009, 07:11 PM   #6
992drjimmy's Avatar
Spinldes, 2 inch springs and rear do SOA. See my sig.
Old 10-30-2009, 03:22 AM   #7
wheres the best place to get these parts at a great price? and what does SOA mean? Im guessing to put the axles below the springs... thanks guys.
I plan on getting the spindles first, then springs and after that do something with the rear. Id really like to do a rear only air bag setup
ohh and a 2 inch body lift is on the list also.
Any reliable but affordable websites linked for all mentions parts would be greatly welcomed. also if theres anything else i would need mention it or forever hold your peace!!
Old 10-30-2009, 01:51 PM   #8
sapperb's Avatar
SOA - Spring Over Axle
Parts - Ebay and or Google. Both are beautiful things
ABTS - Axles Below The Springs
Old 10-30-2009, 05:58 PM   #9
992drjimmy's Avatar
If i were doing this again, Id do spindles, 3"body lift and shackles to level the rear. Do a nice looking trim and some 32's or try 33x10.50's.
Spring ride is bouncy and not nearly like stock.
Old 10-31-2009, 11:46 PM   #10
'00 Dime
yea i would recomend the same as 992drjimmy. The ride gets a little ruff with some heavy springs and with the 4.3 V6 u will only get from .5 to 1.5 inches of lift out of them. not worth it.
I should be doing a 2 inch BL in the spring so my truck will sit close to yours 992drjimmy. I wanna run some 32/11.5s
Old 11-01-2009, 11:43 AM   #11
Jakes_95Dime's Avatar
Dont mean to jack the thread but does any have or have a picture of a s10 with like a 5-6" suspension lift PLUS a 3" bodylift? So like 3"spindles, 2-2.5" coils with a 3" bodylift.
If so, picture? =D I'm curious as to what it looks like, especially how high it looks.
Old 11-01-2009, 09:07 PM   #12
Riding High 2wd
BillsDuster's Avatar
Take a look at 992drjimmys truck, his is exactly what you want to see.
Old 11-02-2009, 08:42 PM   #13
992drjimmy's Avatar
Look at the truck in my sig. Exactly what you asked for.
I actually did get 2" with the dick cepek springs im running. I was thinking about putting the stock springs back in. But too much work.
Old 11-03-2009, 07:52 PM   #14
Moderator
What?'s Avatar
Stock is easier to put it back in lol, I'd take your 2" springs off your hand though.
Old 11-03-2009, 09:38 PM   #15
992drjimmy's Avatar
Since i dont have a garage yet. Itll probably wait till spring before i put stock springs in and also probably wait till i get a 4.11 or 4.10 which ever it is rear end. Before going back to sua and a lift shackle.
Old 11-07-2009, 01:27 PM   #16
Moderator
What?'s Avatar
You can buy 4.10 rear end from 2.2, same rear end(7 5/8) as 4.3 but different gearing.
ALL 2.2 has 4.10 from ALL extended cab OR Automatic, so if you looking for parts to pull. Then slap on locker and you're good to go.
ZR2 is 4" wider per side BUT only 3.73 unfortunately(4.10 would been better choice factory).
Old 11-07-2009, 07:16 PM   #17
992drjimmy's Avatar
Let me be sure i understand correctly. All EXT cab 2.2's have 4.10. And any automatic 2.2 has 4.10. The 3 yards in my town never seem to have a second gen s10. One place has a burned s10 from front to end of cab. So can read codes on sticker.
Old 11-07-2009, 11:33 PM   #18
Moderator
What?'s Avatar
Correct. It came standard on every 2.2 auto or ext cab. Reason is that because 2.2L isn't as fast to get moving in ext or auto trans so 4.10 helps out. 2.2/5spd/reg cab has 3.73. I wouldn't recommend going 3.73 if you're thinking about it esp with 33s. 4.10 is good.
Even sticker is burnt, all you need to do is look in engine bay for 2.2, then if its auto or 5spd.
Also they all are open end, none ever came with G80.
Check craigslist, classified here and make a ad in classified if someone wants to trade/sell rear end.
Old 11-08-2009, 11:12 AM   #19
Man, what da hell?!
...Before going back to sua and a lift shackle.
This is the second time I've heard of someone going back to SUA. Why do you want to do this? It seems like it's an easy and "safe" way to get ~5" of lift, and I think it would look better than some insanely long shackles (to make up for the lost lift) hanging from under the truck.
Old 11-08-2009, 10:34 PM   #20
992drjimmy's Avatar
The only reason i may go back to sua is beacuse i may go back to stock coilson the front and the rear would be too high.
Old 11-09-2009, 01:13 PM   #21
Moderator
What?'s Avatar
As he answered, other reason would be wheel hop, it'll be more wheel hop than it is with SUA.
Old 11-10-2009, 08:25 PM   #22
Man, what da hell?!
Gotcha. I just wanted to make sure there wasn't a safety issue or something like that I was missing.
Old 11-11-2009, 07:28 PM   #23
Moderator
What?'s Avatar
No problem, although if you do ladder bar with leaf spring or 4 links then that will help eliminate the wheel hop with SOA which is pretty common.
Old 11-11-2009, 07:47 PM   #24
Man, what da hell?!
...4 links...
Don't tempt me! I'm already thinking about 'baggin the damned thing after I lift it! Go from 5" of lift to 15"+ of lift at the push of a button...
Old 11-12-2009, 07:18 PM   #25
Moderator
What?'s Avatar
Screw bagging it, lift and LINK IT!
Don't push the button, PUNCH THE BUTTON!
Page generated in 0.59149 seconds with 31 queries
[Output: 125.54 Kb. compressed to 115.71 Kb. by saving 9.83 Kb. (7.83%)]
