S10 Xtreme Going High?? Good or Bad...
I have know idea where to start. I purchased my 2002 S10 Xtreme when I was 20 and it sat for 2 years when I was deployed.I Love it, don't wanna get rid of it. Now five years later I wanna jack it up to a nice height of a zr2 or higher to fit some 32's or 30's. I don't even know if it is worth the time. Gotta take off the body kit, sell the 18's. Then find a kit to get a nice lift.
Also im going from the lower xtreme suspension so i would have to go even higher on the lift to fit those tire sizes... Not sure Sounds crazy to me.. I just want a bigger stance and a bad ass look.. black truck on sum black wheels sittin high would be so sweet... Some Pics of my truck now http://www.cardomain.com/ride/2523808 Maybe I can trade.... What I would like it to look like. Not sure how high of a lift to get to achieve that stance.. http://www.zr2usa.com/members.php?id=263 I will not hit any hardcore off road terrain. Maybe trail if that. l live in NY just a little somethin for the snow. It's my only vehicle, my Honda was stolen last year, good thing it was a beater... Any Ideas would be ssssooooo great.... Thanks |
Re: S10 Xtreme Going High?? Good or Bad...
Read about this kit on a budget???
If i have too, Super Lift?? |
forum idiot
leave the kit on and lift it
i know what your goin through. my truck in the picture used to be an xtreme. body kit and all. i took that ugly shit off and lifted it. only thing i had to do was buy stock s10 or blazer leaf springs. then i bought moog springs and lift spindles in front. that gave me about 4.5in of lift in the front. then i bought a 2in lift shackle and AAL for the rear. my truck now sits level. and i put it on 31's on 15in rims. i absoultely love it. its so much more fun. i hated hitting bumps and curbs. im also installing the 2in body lift very soon. goin higher!
OH NO!! not a 2" BL |
i know man. i know. after all the help and pics you sent me on how to do the 3in BL. only reason im goin with the 2in is because i honestly dont have anyone to fab those brackets. well see. ill probly regret the 2in ![]() |
If it were me. I'd sell it and go in a different direction. You could buy a zr2 4x4 or pick up another regular 2wd s10 to lift etc. Let some one else enjoy the truck and do something new to you.
Yeah so much agree too. Its easy to get upside down in loans on these trucks. Especially if you got it new.
Anyways. Ah man a ZR2 would be sweet. Ive always wanted one. Before laid off and i was looking for one. All i could find was over priced or junk. My dealer ship had a 99 with rusted through rockers and rusty cab corners and wanted 10k for it. Thats what i was finding. |
ya same with me i was looking to get rid of my truck about a year ago and look for a zr2. only thing was they were so damn expensive! nothing under 10k was in good shape. each and every one had over 60,000 miles on it. most that 30,000 or less were over 12k
id say do what youd like to do. When my truck was 2wd i had an 8'' lift on it and it sat bigger than zr2's when it was on 31's also
yep after i install BL my truck will sit taller than zr2. as of now with springs and spindles i sit about an inch or 2 higher. but with BL ill be much taller
I like boobies
Sell the Xtreme. There's a lot of street guys out there that would buy it.
Take the money and find a 4wd or ZR2. I got lucky on my ZR2. More like I ripped off the dealership because I knew they didn't know what they had. ![]() As far as the ZR2, you can have a 4x4 and achieve the ZR2 stance or taller for less than the price difference between a decent ZR2 and a good 4x4. |
I like boobies
I can the ZR2 going the way of the Syclone and Typhoon...rare and expensive.
i would lift it if it were me i like my 2wd better then a stock zr2 just looks better by far. now if you can get a already lifted zr2 that would be the a good bet too. i would take the body kit off as well selling it will help pay for a lift kit. those ricers will be all over it and those 17" rims will go quick i think on the market
Ok, going from "xtreme" low Rider level. I plan on buying 3" spindle, 3" coil, upper control arm, rear flip kit I believe gives 4" to sit level from what I have been reading, And replacement shocks. Will that do the job for the 31x10.5 that's the question?? Body lift in near future. Can't screw this up Im paying a shop to put this together for me. Expensive $$
On a stock 2wd i got 5.5 " from SOA.
Riding High 2wd
Notice the upper arms are identical... ![]() All you need to clear 31's is the lift spindle and the moog coils, or skip the coil springs all together and use lift spindles and a body lift. Your stock control arms will be fine with up to a 2" lift spring. |
So i can get away with 3" spindle the 2"moog coils. Now the rear just get the flip kit which Is called "SOA" let me guess Spring Over Axle"? and these parts will level it out? I was thinking about a 2" body lift to go with this set up? Hope this narrows it down... |
Moderator
Correct, you can also buy Aim 2.5" coil, they are pretty good and not neck breaking like Rough Country.
HOWEVER, if you're able to sell/trade Xtreme for ZR2, I'd say do it, I wouldn't buy 4wd UNLESS it's ZR2 and/or SAS in the works. In meantime, as said above. 3" spindle, fcs5664s (part number), 2" body lift. Then as for rear, 3" shackle from www.bajacustoms.com OR www.gmachineracing.com, otherwise SOA(Yes, you're correct, it's Spring Over Axle). You just need perch to weld on and move mount hole toward engine for driveshaft/e brake cable not to be stretched out much. But with this, it'll give you bad wheel hop until you build ladder bar. You can go with 3.5" Aim coil IF you're able to afford www.bajacustoms.com UCA kit which is best uca choice out of any SA available. |
I got 3" spindles and Moog 5664 coils with a set of 3" lift shackles..
Got the Kumho road venture MT KL71 31x10.5 with a set of black rock wheels 15X8 3.75 BS I should be good to go, all I have left is extended brake lines and new hardware bolts for the leaf springs, gotta install stock leafs because i have the Xtreme drop.. And i have a 2" body lift on the way... 98-04 Chevy S10 GMC S15 Sonoma 2in Body Lift Kit #192 Hope I'm not leaving anything out... I see that Sonoma springs are thicker then the Moog coils?? Going from Xtreme series coils to moog or these sonoma thicker coils?? Higher spring rate? Wish me luck.... Install date October 20th |
dang i was gonna tell you to go solid axle. haha. Good luck man!!!! im sure its going to turn out nice!
#24 |
Goin Up
Im doing the same right now with my blazer xtreme. As of now i have the moog 5664 coils in and im working on getting stock spindles to replace the drop ones i have then for the rear monday im swapping for stock blazer leafs and installing lift shackles. Then when i feel like sinking my teeth into it ill be installing my 2in body lift
#25 |
Another question I had was I ordered a 3" lift shackle set from GMR. What would be a good shock replacement for this modification????
#26 |
let me try again.....
3"front spindle 2" Moog coil 3" shackle Whats is the best shocks on the market to meet these lift specs?? |
#27 |
Goin Up
Do 3spindles, moog coils, 2shackles and add-a-leaf imo
#28 |
#29 |
Zr2 rear shocks. Ok, I'm replacing the zq8 drop leafs with stock s10 leafs with a 3" lift shackle. Think it will be good?? Worried about down travel and proper fit.??
#30 |
Update, i have all the parts for my lift.
Moog coil 3" spindle 2"shackle stock s10 leafs AAL from pro comp Sky Jacker nitro zr2 shocks 2"body lift Baja Customs brake lines 31" x 10.5 Road Veture MT-KL71 on black rock 15x8 3.75bs 2" wheel spacers to get a wider stance. Center Force II Clutch kit Extras.. 10,000 HID kit Billet grill 5" touch in dash unit Polk audio speakers for doors. I have the clutch install next week after that the lift around mid November, cant wait Chevy ridin high boy..... |
#31 |
#32 |
OK cool i only got them for the rear.. Should have specified.. Ill have some pics up in November.. Anyone recommend a good locker so I can haul some ass through snow, mud, ect... |
#33 |
'00 Dime
ooo man you bought the tires i wanted real bad cant wait to see it.
they were a little spendy so i didnt get them i couldnt belive how much more they were compared to even toyos |
#34 |
Riding High 2wd
#35 |
Anyone have any reviews? http://www.powerperformancemotorspor...&categoryId=17
Or waste of money? i have 58K on the truck, ball joints still good?? Also too, got a set of stock leafs, installed the aal and was thinking to replace the bushings before install? Wouldn't hurt, or a waste of cash as well? |
#36 |
#37 |
Moderator
I would go with Bilstien shocks instead of skyjacker.
Go with Poly on uca, but no need to get poly on lca, stock is good. New balljoint are IDEAL!, you need to use balljoint press on LCA and drill, grind or air hammer rivet on uca. As long you get Extreme duty from Napa/McQuay Norris, PP, you are good to go. |
