Pics!! 2wd lifted blazer
Old 10-01-2009, 04:46 AM   #1
Goin Up
Fortunat72's Avatar
post the pics of your 2wd lifted blazer. once i get mine back from the shop ill post pics.
Old 10-01-2009, 08:16 AM   #2
rocpede4x4's Avatar
Re: Pics!! 2wd lifted blazer
here are some pics of 2wd blazers, and they are not mine. the gold blazer belongs to a member on this site, and it is no longer lifted. and the blue jimmy belongs to a member on dezertdimes.com
specs on the gold blazer is 3" suspension and 2" body lift w/ 32" tires
specs on the blue jimmy is 2" body lift w/ 32" tires
and he add 3" lift spindle and brakes from a pickup w/2" shackle and 2"bl w/ 32" tires
and the last pic is 3" spindle and 3"coil w/2" shackle and 32" tire
Old 10-01-2009, 08:23 AM   #3
rocpede4x4's Avatar
here is the link to the build on the blue jimmy
http://dezertdimes.com/forum/index.p...ic,2160.0.html
Old 10-01-2009, 11:25 AM   #4
Going up ^
01S10's Avatar
Woah that first pic of the blue jimmy is with only a 2" bodylift and it fit 32's?
Are jimmys different stock height cuz 2" should not fit 32's from my understanding with the trucks.
Both look awesome btw
Old 10-01-2009, 11:48 AM   #5
rocpede4x4's Avatar
98+ jimmys and blazers sit about an 1" taller then a S10 pickup
Old 10-01-2009, 01:02 PM   #6
89-S-Dime's Avatar
yea it's a good thing too, because lift spindles won't work on a 98-+ Blazers unless you change all these parts, thanks to brake upgrade
Old 10-01-2009, 01:18 PM   #7
992drjimmy's Avatar
First pic of blue blazer looks great. IMO looks funny with the front end up in the air.
Old 10-01-2009, 06:15 PM   #8
Moderator
What?'s Avatar
Remember, weight in rear is higher than s10 for Blazer, which make the front lift more higher. They are exactly same coils.
Looks great nonetheless!
Old 01-29-2010, 02:12 PM   #9
'00 Dime
alarm_the_alarm's Avatar
im diggin that gold blazer alot. looks sooooo clean im jelous.
Old 01-29-2010, 03:22 PM   #10
rocpede4x4's Avatar
the gold blazer is the one that got me, wanting to lift mine. i did alot of research about lifting 2wd blazers.
Old 01-30-2010, 08:23 PM   #11
Zeeke98's Avatar
How bad does a lifted 2wd 2 door handle? Mine is pretty flighty at stock height. I keep debating if i want to lift it but if it handles horribly I'll stick to my plans to lower it.
Old 01-31-2010, 03:44 PM   #12
'00 Dime
it will be fine man. with the lift spindles it makes your axle width about 5 inches wider so that adds alot of stability then get 1.5 inch spacers for the rear and you'll have alot wider stance to make up for the tippyness.
Old 01-31-2010, 09:02 PM   #13
Zeeke98's Avatar
They don't make 98+ Blazer lift spindles. You have to convert your brakes and junk to the crap single piston S10 stuff to make it work. Max suspension lift on a 2wd Blazer would be 3" lift springs.
Old 02-01-2010, 03:35 PM   #14
'00 Dime
you can switch everything over as you can see above a few people have done it.
Old 02-01-2010, 08:49 PM   #15
Zeeke98's Avatar
I know you CAN but why would I spend all that money for decreased brake performance? With a lift and bigger tires I'd want at least what I have now.
Old 02-01-2010, 08:55 PM   #16
'00 Dime
its all for apearance thats why.
Old 02-01-2010, 09:03 PM   #17
Zeeke98's Avatar
It's gotta perform, not just look. Roads I drive to work are really curvy and I'd rather have handling anyways. I need a posi if I were even to think about taking the two tracks through state land I used to go through with my 4x4.
Old 02-06-2010, 04:38 PM   #18
speterson1011's Avatar
I've been trying to find someone else that did the lift spindle conversion from a pickup like I did. Here's some pics. I did the 3.5" Fabtech lift spindle and 3'' fabtech lift coils. All new fabtech shocks,longer sway bar links, and fabtech axle flip kit and steel braided brake lines. Ended up getting 6.5" of lift and then I added a 2'' PA body lift. The side frame height is at 23 inches! I have 33X12.5X15 ProComp m/t tires with 2'' 15X8 backspaced Bart wheels. Looking into getting 35'' tires.
Old 02-06-2010, 05:14 PM   #19
'00 Dime
that things damn nice man. looks like you have the room for 35s do it up
Old 02-06-2010, 05:53 PM   #20
rocpede4x4's Avatar
welcome to the forum and that does look awsome with 33", but it will look sick with 35"
Old 02-06-2010, 06:16 PM   #21
Yah I measured it out for room I have and it is plenty for 35''s. I'm going to have to put some 410 gears in though. I noticed people were talking about the brakes and how its downgrading them. I see how the single piston isnt as good but I could honestly not notice a thing. With the 35''s I plan on upgrading the brakes because it will deffinitely need it then with them big tires haha. Thanks for the comments and new to the site welcome
Old 02-06-2010, 08:39 PM   #22
Zeeke98's Avatar
SSBC has dual piston upgrades for the S10. Gas mileage would kill me with that much of a lift and big tires. It's bad enough stock!
Old 02-07-2010, 12:28 AM   #23
Sweet i'll check it out. You know I thought the same at first about the mpg. I'm actually getting 15 around town and about 18-19 on the interstate. I was expecting like 12mpg but I was wrong. I've calculated the mpg about 4 times and its accurate
Old 02-07-2010, 10:03 AM   #24
Riding High 2wd
BillsDuster's Avatar
Man that blazer looks awesome! I'd keep 33's on it myself, they are plenty big enough to look good and have some clearance from the body. 35's look kinda funny on these trucks unless they are really lifted and straight axled.
Old 02-07-2010, 10:42 AM   #25
Yah i see what you mean. There is a guy in my town that has a zr2 on 35''s with 1'' backspacing I believe and it looks rediculous. But thats the look im going for haha
