moog spring rates
Old 03-22-2009, 03:26 AM   #1
89-S-Dime's Avatar
moog spring rates
had a few ask me if I had any info on moog springs, most 2wd S10's have either 5658's or 5660's
as you can see from the chart the increased spring rate of the 5662';s and 5664's, this should clear up any confusion whether Moog 5664's are a stock S10 spring (from this chart you see they are not)
Old 03-27-2009, 04:36 AM   #2
89-S-Dime's Avatar
Re: moog spring rates
TRW/Moog
5658
5660
5662
5664
The following coil springs have the same spring rates as the TRW/Moog brand but are often cheaper.
AutoZone
Duralast brand
FCS5658S
FCS5660S
FCS5662S
FCS5664S
McQuay-Norris
FCS5658S
FCS5660S
FCS5662S
FCS5664S
Husky spring
RC5658
RC5660
RC5662
RC5664
(I have not listed ACDelco brand because I have not been able to confirm the spring rates)
Old 03-27-2009, 07:58 PM   #3
one bad bow tie
nismo_2005's Avatar
does that mean that the FCS5664S will give me the same lift and same spring rate as the moog 5664 and i can pick it up at the autozone 2 blocks from my house?
Old 03-27-2009, 08:32 PM   #4
Riding High 2wd
BillsDuster's Avatar
nismo thats correct 5664 is the same coil between "brands"
Thanks for stickying that 89 s dime... Or whoever did
Old 03-27-2009, 08:58 PM   #5
one bad bow tie
nismo_2005's Avatar
ok thanks cause autozone can get them for 60 so i might just do that.
Old 03-29-2009, 05:37 PM   #6
Moderator
What?'s Avatar
5664 with part number are the same
Billduster, so you know, only Staff of the forum are able sticky threads
Old 03-30-2009, 10:18 PM   #7
89-S-Dime's Avatar
I wondering who did that, I figued it was you or Brian who made it a sticky
Old 05-02-2009, 12:23 AM   #8
Matt93's Avatar
http://www.autozone.com/autozone/cat...hText=fcs5664s
only $49.99 right now at autozone
Old 05-02-2009, 11:12 AM   #9
one bad bow tie
nismo_2005's Avatar
Quote: Originally Posted by Matt93
the price is area sensitive they are $59.99 here.
Old 05-06-2009, 03:19 PM   #10
01slonoma's Avatar
$69.99 at my Autozone in Oklahoma
Old 05-16-2009, 06:34 PM   #11
bigblock96's Avatar
is there anyway i can get stock gmc 1500 springs to fit on my blazer
Old 07-08-2009, 11:16 PM   #12
well i have the fabtech uca's and the fabtech springs seem like there designed for a semi truck....
So i just got home from checker i ordered the moog 5664's im realy hoping my truck will at least sit level, if not then higher in the front. and i hope they work well with my control arms.
In the process on the new new spring install im going to flip the bjs on my fabtech uca's.
I hope this sounds good to you guys???
If not, correct me please.........
Old 07-09-2009, 03:42 AM   #13
o well, to late...
the bjs are fliped and old sprigs are out.
just finished that...
the moog 5664's get dilivered tomorrow...
i hope what i read on here was right and everything works out...
Old 07-09-2009, 09:23 PM   #14
Wink Re: moog spring rates
Quote: Originally Posted by NickB024
o well, to late...
well the jobs done and it seems to ride pretty smooth, also the truck sits level, maybe a little higher in the front.
all i need now is shocks...
Page generated in 0.60728 seconds with 31 queries
[Output: 87.40 Kb. compressed to 81.42 Kb. by saving 5.98 Kb. (6.85%)]
