lowering 2wd
Old 08-25-2009, 02:47 AM   #1
lowering 2wd
right now i have mood 5602 springs heres what i found about them.
56024.090.67111168034715.88One Square End and 1 Tangential End
and the truck sits like factory, just wanted to know if i cut off one full coil about 3 inches would that lower the truck 3 inches?
these are not my springs just a pic.
Old 08-25-2009, 03:04 AM   #2
Re: lowering 2wd
what end would i want to cut the square end or the tangential end?
heres the info on them again sorry the first post all the munbers got pushed to gether.
Spring #Inside Dia/Bar Dia/Install Height/Load rate (lbs)/Spring Rate (Lbs/in.)/Free Height/End Type
5602 4.090/ .671/ 11/ 1680/ 347/ 15.88/ One Square End and 1 Tangential End
Old 08-25-2009, 09:47 AM   #3
Size Matters
Blackie's Avatar
Re: lowering 2wd
This is the "liftin it" section.
.....you might try posting your question in the "lowering it" section.
Old 08-25-2009, 10:20 AM   #4
xmb63's Avatar
Re: lowering 2wd
i believe the s10 is a 2: 1lift ratio if you cut 3" off the coil it will be a 6" drop. From what i heard with stock springs every 1/2 coil is an inch of drop.
Old 08-26-2009, 03:48 AM   #5
Re: lowering 2wd
i put the thread here because i was told they were moog springs used to lift the truck. so yoiu guys with lifted trucks would know more about the springs than i guy with a lowered truck.
what end would i cut? the square end or the tangential end?
Old 08-26-2009, 04:16 AM   #6
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
Wait...So it's a 2wd, you have lift coils, and you want to lower your 2wd. Am I correct?
1. post in the drop it section.
2. buy drop coils.
Old 08-26-2009, 10:38 AM   #7
Size Matters
Blackie's Avatar
Re: lowering 2wd
You don't CUT coils to lift a truck
.....when people buy the Moog springs.....they intall them as they are.
Old 08-26-2009, 10:46 AM   #8
992drjimmy's Avatar
Re: lowering 2wd
Yeah as cheap as springs are i would say dont risk it by cutting them.
Old 08-26-2009, 12:50 PM   #9
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
Nah I think he's wanting to cut lift coils to lower his truck
Old 08-27-2009, 12:12 AM   #10
Re: lowering 2wd
i posted it here because the lifted guys would know more about moog lift coils, and i was just going to cut them down to lower the car, i thought it would be ok because the spring rate is so high on them i dont think it will bottom out at all.
Old 08-27-2009, 01:50 AM   #11
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
Chances are more people in the drop it section will know more about cutting the coils and dropping a truck than the guys in the lift it section.(no offense guys)
Cutting the coils will make it ride like shit. Drop coils are cheap and they won't bottom out, in fact I've never heard of a coil bottoming out.
So...
2. sell the lift coils
3. buy drop coils
4. do it right
Old 08-27-2009, 03:48 AM   #12
Re: lowering 2wd
so what end should i cut, and how much should i cut to get a 3 inch drop?
Old 08-28-2009, 05:24 AM   #13
Re: lowering 2wd
the springs has two different ends one is called a square end and the other is called a tangential, does it matter what end you cut or should you cut both ends some?
Old 08-28-2009, 06:06 AM   #14
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
Cut both ends with tin snips. Seriously...I mean really... GD.
Old 08-28-2009, 07:32 AM   #15
Re: lowering 2wd
where can i get tin snips? do you think they will work? how do you know that i should cut both ends?
anyone else have any ideas on what end i should cut?
Old 08-28-2009, 02:37 PM   #16
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
n/m don't worry about it. I've told you what you need to do, you don't want to listen, then fine. Have fun cutting up your lift coils to lower your truck.
Old 08-28-2009, 04:12 PM   #17
'00 Dime
alarm_the_alarm's Avatar
Re: lowering 2wd
buy lowering coils. there like 60 bucks.
Its cheap
Will ride wayyyy better
and you can sell your lift coils to make it cost you close to nothing
do it RIGHT not CHEAP youll regret it
Old 08-28-2009, 06:34 PM   #18
S10_QC's Avatar
Re: lowering 2wd
since you don't understand im gonna tell you the truth. if you cut the coils the truck is gonna fall completely appart and it is going to crash into a big fat woman. so DONT DO IT. buy dropped coils. you wouldnt cut your stomach if you wanted to lose weight so dont cut the coils.
Old 08-28-2009, 07:36 PM   #19
all one color again!
S10dude's Avatar
Re: lowering 2wd
this thread is hilairious and stupid
Old 08-28-2009, 08:50 PM   #20
Jerd_Hambone
flatblack91's Avatar
Re: lowering 2wd
Is this a joke, or is this serious?
I don't think I've laughed harder at a serious thread in a good while
Old 08-29-2009, 01:10 AM   #21
BelowMe
Render78's Avatar
Re: lowering 2wd
Some people do cut their stomach to lose weight though.. whats it called like.. stomach stapling or w/e... haha.. anyways... its your truck so I don't really care what you do.
Old 08-29-2009, 02:20 AM   #22
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
its your truck so I don't really care what you do. [IMG]file:///C:/Users/Wayne/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
I'm glad you don't. Thanks for adding this to the thread
Old 08-29-2009, 02:35 PM   #23
'00 Dime
Re: lowering 2wd
lol. yea and the tin snips will cut right through the coils hahaha
Old 08-29-2009, 02:43 PM   #24
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
You do realize they work better than the jaws of life right?
Old 09-01-2009, 04:22 PM   #25
Moderator
What?'s Avatar
Re: lowering 2wd
http://www.s10forum.com/forum/f219/m...-rates-394589/
This coil, If I were you, I'd sell it or return it for $.
If you're gonna cut, it's easier and better to use chop saw. But can't say how much but seeing it's 15" at free height while coil we use are at 12"-13", this is going to be trial and error for you to get height you want which will be bit hassle unless you're experienced with doing coil swaps.
Old 09-01-2009, 08:14 PM   #26
'00 Dime
Re: lowering 2wd
i dont think hes experienced...
Old 09-01-2009, 10:11 PM   #27
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
I love chop saws.
Old 09-02-2009, 09:35 PM   #28
Re: lowering 2wd
sorry i havnt been on in quite some time the tin snips did not want to cut the coils but i got it to work, thanks for the help.
Old 09-03-2009, 12:48 AM   #29
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
Ok now we know you are full of BS...
Old 09-04-2009, 06:20 PM   #30
rolling work in progress
Mr.woodscrewsNbondo's Avatar
Re: lowering 2wd
i believe him and heard of people doing this, not the best way but if you did do it make sure the new end of the spring is in the same spot as it originally was so it will at least seat properly.
Old 09-04-2009, 09:51 PM   #31
Moderator
What?'s Avatar
Re: lowering 2wd
Pics and what's your current height?
Old 09-04-2009, 11:35 PM   #32
Re: lowering 2wd
wait he actually tried the tin snips
Old 09-05-2009, 04:51 AM   #33
ZQ8 Blazer
ZQ8 Blazer's Avatar
Re: lowering 2wd
Naw he claimed to have. He said they worked so there's your answer
