liftin a jimmy
Old 11-02-2009, 02:46 PM   #1
austin9372's Avatar
Question liftin a jimmy
I've got a 97 GMC Jimmy 2wd 2 door that i'd like to lift 3 to 4 inches so I can fit a bigger tire. It's bone stock now. I'd like the ride to be somewhat like it is now and for it not to destroy my mpgs. Any reccomendations would be appreciated cause I'm a complete noob to most of this.
Old 11-02-2009, 03:18 PM   #2
'00 Dime
alarm_the_alarm's Avatar
Re: liftin a jimmy
3 inch lift spindles up front and 2 inch lift shackles out back will get you sitting quite a bit higher and have the same ride as stock.
you can get spindles off ebay. AIM spindles for around $240 and shackles off ebay for around $50.
Hope this helps
Old 11-02-2009, 03:39 PM   #3
austin9372's Avatar
Re: liftin a jimmy
alright, thanks man. About how difficult would this be?
Old 11-02-2009, 07:40 PM   #4
992drjimmy's Avatar
Re: liftin a jimmy
Spindles are fairly easy.
I find the shackles being the PITA. i always have a hard time getting the bolts out.
DO NOT DO A LIFT SPRING if you want it to ride good. Do the spindles and a 31x10.50 or adda 3" BL to that and a light trim for some 33x10.50's.
Old 11-02-2009, 07:40 PM   #5
Deaths Shadow's Avatar
Re: liftin a jimmy
its not difficult, for the spindles you just take off the nuts that hold the ball joints in to the spindle, take off the tie rod that is connected to the spindle and the spindle comes out, then put the new one in. For the shackles there is a bolt that goes through the frame that connects the shackle to the frame, with this bolt be sure to use a lots of PB Blast, and just pound the bolt out. Then unbolt the bolt going through the leaf spring, and put the new shackle in its place.
Old 11-03-2009, 07:55 PM   #6
Moderator
What?'s Avatar
Re: liftin a jimmy
Ditto, lift spindle(you're lucky it's a pre 97 because s10 lift spindle fits on pre-97). Shackle in rear, lift the front then measure the rear how you want it to lift, prerunner, level or rake. Whatever you measure the difference is the lift you need but UP to 3"
Old 11-03-2009, 11:02 PM   #7
'00 Dime
Re: liftin a jimmy
true. shackles can be a PITA. when i did mine i needed a air hammer and a cut off wheel to get um out. try not to wreak the bolts i had to buy 4 new bolts and they were 28 bucks for the bolt with overnight shipping that was from a local fastnal to.
as for the spindles all you realy need is a ball joint seperator(u can rent from any auto part store)
*READ* MAKE SURE YOU CUT YOUR CALIPER STOPS OFF WHEN DOING THE LIFT SPINDLES THERES A HOW TO FOR AS A STICK IN THE 2WD SECTION
Old 11-04-2009, 12:01 PM   #8
twistedsmily's Avatar
Re: liftin a jimmy
Im goin to be doing my 95 2dr 2wd after the first of the year.
Dont forget extended front break lines!,
Old 11-04-2009, 09:19 PM   #9
austin9372's Avatar
Re: liftin a jimmy
alright thanks guys. I'm guessin its fairly easy for someone who know what the f**k they're doin. I'm broke as hell now so it'll be a while before I can do anything anyways. I'll try to get my dad in on this one lol
Old 11-06-2009, 08:37 PM   #10
Moderator
What?'s Avatar
Re: liftin a jimmy
You don't have to use balljoint seperator, it's too much hassle.
This is what I do all the time. You loosen the balljoint nut couple threads then take jack off(make suretruck is on jackstand) then you pound the spindle(down and up) then with coil force will push it out to nut where its couple threads up. Jack it up to where force isn't onto the nut then you can remove it and pull it out and swap. This IS quickiest, less headache. You need to use 4lb sledghammer and DON'T be a pussy, it takes me 1, sometime 2 whacks and its loose.
Brake line mount to be removed to help free up brake line length along with removing caliper stop. Its ideal to have longer brake line but also good time to upgrade to stainless steel lines.
Page generated in 0.56496 seconds with 31 queries
[Output: 71.09 Kb. compressed to 66.57 Kb. by saving 4.52 Kb. (6.36%)]
