Lifted 94 2WD With 33/12.50/15 Tires!
LinkBack (3) Thread Tools
Old 02-10-2005, 01:50 AM   3 links from elsewhere to this Post. Click to view. #1
2wd Lift Expert
The Red Baron's Avatar
Thumbs up Lifted 94 2WD With 33/12.50/15 Tires!
After I lifted my truck I went through ball joints way to quick and I couldn’t get it within proper alignment specs so I decided to take my problem truck to Fabtechs headquarters and see what they have to say about this! The gray haired tech that inspected my truck would only tell me that my rims and tires are not what Fabtech recommends with their kit because they’re too wide and that is causing my problem. He is the one that got me going on the leverage and pivot concept. Since I wasn’t going to take the only "legally responsible" suggestion of putting on 15x8 rims with 31/10.50 tires (30 inches by 8 inch tread, yuck!) I figured out an experiment to try. That was to buy another set of ¾ inch Fabtech spacers and yes, double them up. I bought aircraft grade 9 bolts and tried it. WOW! I actually had a smooth ride but I lost 1.5 inches of ground clearance under my cross member! I went from 20 inches to 18.5 but, problem solved I thought. I’ll just have the assembly Mig welded and gusseted. Until, I brought it down to the alignment shop that day. Now before with 1 set of spacers I had no caster or camber adjustment (but camber was within spec) because the Fabtech upper A-arms were too short, now with 2 sets of spacers the arms are too long! Now I have custom ¼ inch spacers. The ball joints are breaking because they are not meant to take lateral force. The weakness and stiff ride of the short arm lift kit isn't the kit but the ball joints and the stock suspension geometry. Let me explain. Since the stock upper arms are so much shorter then the lowers when the suspension travels down (like when the truck is catching air) the upper arm swings dramatically more down and is in a
7 O'clock position while the lower arm is at 8 O’clock. Stock both are at 9 O'clock (level) On the landing the upper ball joint is in it's weakest position when it takes the maximum force. Poorly setup lift kits will be setup with the upper A-arms at an extreme downward angle during normal operation and will be taking weight off of the coil spring! When I had this setup the ride was so bad I could hardly light my cigarette while driving on pavement without burning my mustache. Stock style ball joints are just not made to take horizontal force like that against the stamped sheet metal cup. That is where my Uniball ball joints, aftermarket limit straps and ball joint spacers come in handy. The trick to the setup is you have to use the proper amount of ball joint spacers to get the stress off of the upper arm during normal on and off road travel and use limit straps or larger droop stops for the occasional wild off roading. For me due to the 15x10 rims and 33x12.50 tires the proper ball joint spacing is about an inch. That's because wider tires and rims have a much greater leverage to push top of the tire horizontally toward the frame using the lower ball joint as its pivot axis. If my upper A-arm is at too much downward angle there is enough force horizontally to push the upper ball joint closer to the frame increasing my lift height and tearing up my upper; ball joints, A-arms and mounts. The Fabtechs spacers are 3/4 inch and are still too short. By using a set of longer A-arms this problem of transferring weight to the upper arms is eliminated and puts it all back to the lower A-arm and coil spring where it belongs. However you are now putting much more weight to the coil spring because of the increased leverage the longer arms have and the weight taken off of the upper A-arms.
So I do NOT suggest any short arm spring and A-arm lift kit even though I use one. It’s just too hit or miss with nasty ball joint or frame cracking problems. I have braced the upper mounts by welding in gussets under the cross bar bolts and where the stock droop stop was cut off. After those started cracking from my ball joint test sessions I went with 1/4 inch thick plates that run down the outside of the upper A-arm mounts 1 to 1.5 inches and across the frame for 3 to 4 inches.
If you just want a few inches then go with the 3.5 inch $400 Fabtech spindle and $100 stainless steal break lines, it’s a good choice. Fabtech has the best design and is used by other quality lift kit companies like California Super Trucks (CST) with their 5.5 inch lift kits. You won't be disappointed in the quality. Fabtech is the only company to make a spindle with a solid reputation. The $280 3.0 inch lift spindle by AIM industries (sold under several names like Chassis Tech ect) is the only other company to cast a S-10 lift spindle and they have been known to break. So stay away from the 3.0 lift spindles. If you decide to find a Fabtech set used on Ebay be sure to get the right style due to the different break caliper design from 99 to 03. Longer stainless steel brake lines will also be needed. This type of brake line has a plus and minus. The plus is that they will not expand under pressure (while the break pedal is depressed) like the factory nylon corded rubber break lines do. The result is a much firmer break peddle and increased pressure to the pads. This means it takes less foot pressure to stop the truck. The minus is that because they are so rigid they tend to flex most at the ends. DOT approved braided steal break lines will have some type of support near the ends of the braded steal hose. If the break lines don’t have this added support the line will fray near the fittings and will fail prematurely. Only get DOT approved Stainless steal break lines.
Next step for just a little more tire clearance I'd suggest a $120 Performance Accessories 3 inch body lift kit. Some people say a body lift raises the center of gravity too much. I disagree. To achieve increased tire clearance you have to raise the fenders or cut them. Since there isn’t much to cut on the second gens we’re stuck. A body lift will increase your center of gravity some, but not near as much as a suspension lift that raises the motor, trans, frame ect. The reason a 3 inch lift kit only fits the 94 model year of the second gens is due to a difference in the lower steering column shaft. The 95 and up use a splined shaft. If you want a custom shaft made try Borgeson.com. If your heater line on your truck is like my 94 V6 you'll need a Gates 18751 from your local parts store. My heater hose makes a sharp 90 degree turn down from the firewall to the back of the intake manifold. Both ends are different sizes 5/8 top and 1/2 at the bottom. With the kit I just got a 5/8 hose to use on the power break booster and the heater line. NO WAY was that hose going to make the bend down without kinking. The gap guards were originally made in southern California by a guy in his garage out of big rig inner tubes. He made templates with cardboard first.
For those of you that haven’t bought a lift kit yet you may want to consider the AIM long arms $650) and my Uniball joints ($300 to $350) verses the CST long arm kit ($1800 to $2500 depending on options). I am thinking that because they both use long arms and Uniballs so most of the problems we have with the short arm lift kits will be minimized if not eliminated. The AIM kit with Uniballs just does it for half the cash. Either setup is capable of being broken with enough abuse. The CST kit’s strength is a well earned reputation for quality parts and they have welded on a larger one inch Uniball ball joint. The only problems I have heard about with their setup is that they don’t use a factory style tapered pin. Instead they use a 5/8 inch grade 8 bolt that can oval out the spindle over time on street driven trucks and they use a softer coil spring that doesn’t give as much lift. The AIM and my Uniball setup have a tapered pin but the ¾ inch size of the Uniball is limited to what will fit between the bolt holes but will eliminate the side breaking out issues you have with stock ball joints. AIM has a questionable reputation
that the company service and support sucks. People who have bought their long arm kits though are happy with the hardware and ride quality. I have no direct information other then what I have read and herd from the owners of each kit. For shocks, the so called front “3 inch S10 lift shocks” are actually shocks originally designed for the 91 through 99 Chevy C2500 (¾ ton) 2WD Suburban and are just relabeled. A quality self adjusting gas charged shock is highly recommended such as the Bilstein BE5-2422 and is what I use.
Lets talk about coil spring rates now. A mild 1.5 inch lift spring rate such as the Moog & TRW 5662's and 5664's are about 640 to 710 and can be used with stock upper A-arms. Some slightly longer (3/4 inch) springs that require tubular A-arms are the Fabtech 7268-2 for the 4 cylinder standard cab is 710. The Fabtech 7268-3 for the V-6 extended cab is 750. The Fabtech 7268-4 for their discontinued long arm setup is 800. Full size truck stock spring rates vary from 760 to 870 depending on the model and the ton capacity of the truck. If you plan on installing the lift kit yourself I have the trick to installing the coil springs. Only do this if you are an experienced mechanic and take all safety precautions. A compressed coil spring is vary dangerous. Follow the shop service manual instructions. This is merely an added technique I discovered to complete the job much faster. This at first took me all day. Now I can now start the job after work and be done in time for dinner. Place the coil spring on the lower A-arm and twist it to the groove so you know what half is facing the engine. Grease the threads on the inside coil spring compressor because your going to compress a 15 inch spring down to 10 inches. Insert the coil hooks from the compressor kit one coil in from each end. Now slide it off center towards the engine side of the spring until it stops but the hooks remain firmly in place. Now when you compress the spring it will bind it into a slight “C” shape. This will give you the added clearance to clear the lower section of the coil spring cup on the frame. Once in place as you release the pressure on the spring make sure it sets properly into the seat on the top too (as shown above). If you don’t seat it properly on top it will tear up your frame. After you bolt up the spindle and remove the spring compressor tool, double check the spring placement by looking up through the lower shock mounting hole.
Ok, now to the rear end. Since a spindle lift only lifts a little more then leveling out most trucks I will only look to the rear end as the last step. There are two ways to go. One is more dramatic then the other. The first way is to use hangers, shackles and shocks. Remember that if you put on a 2 inch lift shackle it will only give you 1 inch of lift. Think of it this way. If you have a 5 foot bar you raise one end 2 inches the net result for the middle of the bar is 1 inch. Now think of the spring as the bar with the axle in the middle. Since the axle is bolted to the middle of the spring the net result of the 2 inch shackle lift is 1 inch of lift. Next is the hanger, the leaf spring mount closest to the front of the truck. A CST 1.5 inch hanger will give a ¾ inch lift to the axle. For the shocks look for Suburban rear shocks for up to 1.5 inch of lift and go to the ZR2 rear shocks for a 2 to 3 inch lift. The second more dramatic lift is the flip kit. It puts the axle under the leaf spring instead of over it. It will be 4.5 to 5 inches of lift. You will have to weld it in or the flip kit will break off the stock spring perches. Mine broke the first day. The factory perches just aren't made to take pressure from the other side. From there you need to move the axle assembly forward 3/4 of an inch forward on the spring. This will help make up the distance in the driveshaft splines and e-brake cables. Lastly you have to keep the lower shock mounts under the spring to keep travel and ride quality. You keep your factory hydraulic break line but you will have to bend the bracket up that is bolted down to the pumpkin cover. Your pinion needs to point directly forward (level). Don't point it up towards the back of the trans. As the U-joints rotate on an angle the driveshaft speeds up and slows down with every revolution. One end equals out the other, unless they do not have the same angle. In that case they will speed up and slow down the pinion and you'll feel it vibrate the whole truck. With a flip kit your lower shock mounts will still be under the leaf springs. This means you got a 5 inch lift and you can use stock replacement S10 shocks. I use and recommend the $59 Bilstein B 46-1681 for the 82 through 99 S10.
If your going to get a whole new rear end to weld in the flip kit just make sure it's from a 2wd, the 4wd rear ends are wider. I got my 3.73 Posi at a pick your parts salvage yard for $65 axle to axle. Look in the glove box for the axle codes. The 2wd, 4wd S10 and full size trucks use the same codes. If it has a factory posi it will have a G80 code. The other G codes are GU2=2.73, GU4=3.08, GU6=3.42, GT4=3.73 and GT5=4.10. Happy hunting!
The specs of the ball joints are; 3/4 inch Teflon coated self lubricating Uniball. That’s the biggest Uniball that would fit between the bolt holes and still get a wrench on the heads. The cup is press fit and tig welded to two 3/16” steel mounting plates that are welded together and Zink plated for a total of 3/8 inch thick rust proof mounting plate. The plates are predrilled to use the same factory bolt holes as any other replacement S10 ball joint so you can still use your Fabtech ball joint spacers if you want to as shown in the pictures below. The pin is made of 85,000 PSI strength (side to side shearing resistance strength). What the racers want to know about ball joint pins. Almost all other bolts are tested on a pull apart strength and the Pounds per square Inch (PSI) it takes to pull it into two pieces. The pins are 150k PSI in that scale. They are made of stress proof spring steel that is black oxide coated and tapered to factory specs to fit the top of the Fabtech or stock spindle like a glove and to complete the direct bolt in replacement. I learned at the aircraft parts store the reason for the taper is to dissipate the shearing force over a larger area. So, if the shearing force is dissipated over half inch area (the contact length of the taper) verses an edge. If shearing were no longer an issue by design then it only makes sense to seek a non fatiguing type material such as what coil springs are made of. That is what the steal in the pins is made of, coil spring steal.
The Uniball ball joints will bolt right up to a 1983 to 2003 4wd too. The 4wd and 2wd ball joints use the same four bolt pattern and use the same tapered spindle pin. The only difference I could see was that the 4wd BJ had a different (higher) roll center axis, in other words the pivot point is closer to the A-arm then on the 2wd version by about a 1/4 inch. You can/should check for yourself by going to your local auto parts store and ask to see one of each. In the pic that I am holding the two ball joints side by side you'll notice two small spacers below the Uniball on the pin, one thicker (1/4 inch) silver one and a thinner (1/8 inch) gold one on the one that is bolted in. Those small spacers are to adjust the roll center (standard for all quality race car ball joints) and must be installed either above or below the Uniball. I would still recommend getting an alignment as you should after replacing any suspension components. Just to make myself perfectly clear, I am saying it will fit and you can adjust the roll center axis up to 3/8 of an inch, in increments of 1/8 inch. I wouldn't worry too much about the roll center unless you're trying to cut down your Daytona speedway track times. I move mine up and down by the inch. Up 3.5 inches with my lift spindles, down 1 inch with my ball joint spacers and down another 1/4 inch because I mounted my ball joints below the upper A-arm (very common practice) instead of through the top, and then up 3/8 inch with the spacers on the Uniball pins. Do ya see how for us in the truck world it's really no big deal?
I will be glad to answer questions about lifting my truck here
Yours Truely,
Steve
AKA The Red Baron
SGHTMH@Yahoo.com
Old 02-10-2005, 03:58 PM   #2
barryjames's Avatar
Re: Lifted 94 2WD With 33/12.50/15 Tires! Sticky Me?
Great Post!
Old 02-21-2005, 01:43 PM   #3
2wd Lift Expert
Thank You!
Old 02-25-2005, 05:49 PM   #4
Great post! Wish I would have read this sooner. I have a 97 4x4 sonoma that has a two inch body and two inch suspension. With a little triming i was able to fit 33 ich tires by 12.5 inches wide and was experiencing the same problem with replacing my ball joints. After doing a little research and talking to a chassis engeneer I found out about Chysler screw in ball joints. He told me I would break my control arm before I would break the ball joint. I order 4 and didn't know what i was getting into but after major mods I got them to fit and I never have to worry about changing a ball joint again because they are so bigg and the good part is they are screw-in so if one goes out it would take me one wrench and about 5 mins to change one on the trail.
Old 02-26-2005, 01:32 AM   #5
2wd Lift Expert
Buddy your so full of BS it's not even funny. Not only do I know it but so does anyone who has a 4wd S10 with any kind of a lift kit on it knows it too. Nice try kid.
Old 02-26-2005, 09:46 PM   #6
Ha Ha Ha if you don't believe a word I am saying then go to the member's project forum and go to wakekrzys sonoma project and look at the pics I have pics of the ball joints That I Put In and the tires that go on the truck. I wish I could show you even more how stupid I am but my truck is currently in parts geting a custom 5 inch lift I am fabricating for it so if you have any more wise cracks just let me know and I would be glad to repond.
Sincerely,
the kid
Old 02-26-2005, 10:53 PM   #7
Sorry mistake, the forum is called custom suspension lift that has my pics on it.
Old 02-27-2005, 12:40 AM   #8
ITS NOT EASY BEING EASY
MODERATOR
Dragginbody's Avatar
this is a good post red baron.
but we have a strict advertising policy here. you even stated you would be getting a discount on your setup.
you cannot sell parts this way.
Old 02-27-2005, 12:48 AM   #9
2wd Lift Expert
That's ok, The group buy is over and out. Do you want me to edit the group buy info out or what do you sugest?
Old 02-27-2005, 12:51 AM   #10
MODERATOR
ya edit it out the for sale stuff and the link. thanks
Old 02-27-2005, 12:58 AM   #11
2wd Lift Expert
Oops there is no [Edit Post] for me to click on. There must be a time limit. would you please do the honers.
Thanks!
Old 02-27-2005, 01:04 AM   #12
2wd Lift Expert
Sincerely,
the kid
In the pics posted YESTERDAY the tires have never even seen mile number 1. Come back and show us some pics when you get it together and can post pics of the so called minor trimming and a drivable truck with 4 inch lift and the 33/12.50 tires. Oops, by then you will have another 5 inches of lift or is it a 6 inch lift like what you posted on the 23rd? If I were building a custom lift I would remember what size I was building. Ah, but that’s just me. I wonder why you are lifting it more if it fit fine before with “minor trimming”?
Nice job adapting the ball joints but I wasn’t questioning that part of your post. I have heard of other people doing that with mixed results. What I questioned was the tire size and minor trimming with a 4 inch lift. I know of a blazer that had a 2 inch lift arms, 5 inch bracket lift and a 2 inch body lift and he still had rubbing with 33/12.50’s. It might be possible to do with a 4 inch lift with some major trimming but I haven’t seen it yet. Good luck with whatever your doing and please do post pics of your progress on the custom lift kit.
Below are your quotes from so you can’t do a little last minute editing:
http://www.s10forum.com/forum/f30/wakekrzys-sonomas-lift-project-166290/
I have a 97
sonoma with a bought 2 inch lift kit and 2inch body lift. I just finished puting in custom ball joints (chrysler screw-in-balljoints). It took me about a month to cut new holes for the new b-joints then had to drill out my existing holes in my spindles to accomidate for the larger ball joint shaft. I am now running 17 inch rims with cooper cobra's stt 33 inch tires. Now i am working on a rear flip kit and am doing a custom 6 inch suspension lift kit.
Here are two pics one is the suspension with the chrysler ball joints and the other is the tires I plan to put on. My truck sat outside for a week and that is why everything got so rusty. I love
michigan weather.
Feel free to respond.
Old 02-27-2005, 11:32 AM   #13
Al right you found a error on my 5 and 6 inch lift but I was mistaken because the 5 is for the 4 wheel drive and the 6 is for the 2wd do to the angle of the drive shaft that runs from the transfer case to the front differential. Too much angle means bye bye u-joints. Give me two days and I will get my old pics of my truck with only a four inch lift with 33 and a pics of my friends truck with only a two inch body lift with the same tires. And the tires you seen are 33 by 10.5 that are on 17 inch rims do to the excessively large ball joints. So you are true that they havn't seen a mile but my set of 33 by12.5 did fit and I will get the pics up soon to prove it that all is needed is a 2 inch body with minor triming to fit 33. And I just like any other off-roader am going bigger just because why stop with a four inch lift when you can go higher.
Old 02-27-2005, 01:35 PM   #14
2wd Lift Expert
Fair enough, you show me yours and I'll show you mine.
http://forums.s-series.org/viewtopic.php?t=34411
Quote: Originally Posted by oober
I have all 3 lifts on my car for a total of 9 inches.
I can have the 2 suspension lifts because the superlift is new upper control arms and shackles and the trailmaster is drop brackets for the front and an axle flip for the rear.
It still rubs but only when I hit a driveway fast or flex out. Im sure if i would have picked a different amount of backspacing and/or a skinnier tire it would not rub nearly as much, but i got a Really g00d deal on the wheels so oh well.
Please note how close the tire is to the cab with "minor trimming" seen in the pic and remember as the suspension compresses it travels back towords the cab more. Now imagine how much clearance he has when he turns the steering wheel. Mind you this is with 9 inches of lift not 4. Go ahead and imagine his tire clearance if it were 5 inches shorter. Later he did some major trimming and pounding with a BFH and now has good clearance.
There is a 6 inch lift avalible for the 4wd's so the question of U-joints might not be so bad. The fact remains you didn't have the same lift size posted at both threads within a week of each other and forses me to question your honesty. I'm sure you can understand.
Old 03-01-2005, 10:46 PM   #15
Riding on 33
RidingHiatMSU's Avatar
The red baron sounds like an ass to question him when he has never seen the truck. Ive seen the truck with a four inch lift it DID run 33X 12.5 For a long time and it kicked ass. You right the 33's on 17" rim's are new. If you put in bigger ball joints you will need bigger rims so the ball joints will clear. 15" rims wouldent clear so he had to buy new rims and tires. I got the old 33's I do rub when i turn hard and i trimed the fenders. Its like a baged truck with 20's i bet it rubs even after you trim out the fenders. But who cares
Old 03-02-2005, 01:04 AM   #16
2wd Lift Expert
The ass showed why he believes what he does and why Mr 5 post count… For me the proof is in the pic above. I have been around some forums that are infested with "kids" that post garbage BS to up their post count that when investigated or questioned they usually come back with... "dude i was just kidding! take a chill pill man." Now I get some 19 year old stranger with a post count of 13, posting something that is unlikely at BEST, and has counter dictions in his own posts. I have rested my case and am waiting for proof from him that 33/12.50 tires fit a 4 inch lifted S10 with MINOR TRIMMING. If I am proven wrong I can live with that. I have 33/12.50/15's on my truck that I drive daily and off road on weekends. I lifted the truck myself. I posted the faq above of what I learned in that process and am glad to give info or advice to anyone who would ask for it about 2wd S10's. I really don't care if 4wd S10's will fit 35 inch tires with a 2 inch body lift. That's not why I started this thread.
Yours Truly,
The Ass
Old 03-02-2005, 09:52 PM   #17
enigma2101's Avatar
how much did all of that cost you?
Old 03-03-2005, 01:35 AM   #18
2wd Lift Expert
I got the Fabtech Ultimate kit stuff used for 400.
2 more sets of lift coil springs for unknown cab and motor configuration used were 60 total from one guy.
Kragen Auto coil spring compressor 55.
Shocks were 55 and 59 each
Boots for front shocks were 10 each
Seats were used 75
3 inch body lift 109.
Rims are discontinued and gotten on Ebay for 454 shipped from Weld Racing.
Tires were on sale for 129 each before mounting and balancing.
Flip kit was free because it broke his axle spring perches too.
Weld on leaf spring perches to replace the flip kit 25.
ball joint spacers 30 on Ebay. Thanks again Barry.
Second set of spacers were full price 67.
3.73 Posi was 65 from Pick-A-Part local salvage yard.
Tow hooks 10 each 30 total.
New Smitty Built nurf bars (discontinued) were 110 from a local Ebay seller (no shipping fee).
Droop stops 15.
Straps to replace droop stops 35 each.
5 stock style ball joints 20 to 35 each.
Having custom built Uniball ball joints... Priceless!
I just received my brand new AIM long arm kit today 702 shipped.
I think that's about everything minus miscellaneous aircraft nuts, bolts and a few tools. Let me know if I left anything off.
Old 03-03-2005, 08:16 PM   #19
enigma2101's Avatar
thanks
Old 03-05-2005, 12:51 AM   #20
Hey its me again don't worry I havn't forgot about the pics I will get to them soon enough but have been busy working on my five inch lift kit and just to keep you a little updated on how it is going, What I did is cut all the brackets hold what I want to call the "sub Frame " off then placed 5 1/2 inch mmmmmeta pates in beween giving me inches and leaving welding room. Just got the bacis suport in and now am putting in the tranny to make sure the front drive shaft lines up well with the diff. I know I promised pics but you will have to just keep checking for them because have been busy but as long as we can be civil i would be glad to take time and show u pics and keep updates.
Old 03-05-2005, 01:49 AM   #21
2wd Lift Expert
Andrew (wakekrzy), I am interested in seeing a home made 4wd lift buildup but that topic should be in the thread "Wakekrzy's sonoma's lift project"you started on Feb 23rd. This thread was started to discus the two wheel drive issues and I would like to try to keep it in that subject matter or at least in parts that we share (2wd and 4wds). I have posted in your thread so now every time a post is made there I will get an email notice.
Old 03-09-2005, 05:13 AM   #22
2wd Lift Expert
I have been getting a lot of PM's asking about the AIM long arms I just installed. I don't mind it but I have been answering some of the same questions. Please, unless it's of a specific nature to your truck that you don't want any one else to know. Like I think I just cracked my frame... Please ask your questions here. I will do a write up on them later but here is some of my replies to the PM’s.
The ride is much smoother then the Fabtech junk I had on before. Feels like stock from what I remember. Mounting would have been easy if I hadn't welded on so much upper arm bracing for the Fabtech kit. The OD on the AIM A-arms is larger and thicker. So I had to grind off a lot of metal where the arms swing up and down for clearance. You shouldn't have any trouble though if you haven't beefed up anything yet. I have a V6 extended cab and didn't get as much height as I was expecting so I haven't done any wild off roading YET. It's just too much tire rubbing with the 33/12.50's once I get into the ruff stuff. Note that I never did trim my front fenders. After I change the springs I will do some blasting around and see if anything breaks. The arms look even beefier then the $1800 long arm CST kit and CST has a great reputation. I expect these to hold up better then my frame. The box with just the a-arms weighed 75 pounds from the UPS label to give you an idea of how much metal was used to make these things. These are by far the best bang for the buck. Remember AIM is mostly selling lowering junk, the lifting stuff is not their main cash cow like Fabtech or CST so don't expect an air bag sales guy to know much about lift kits.
if you have a V6 extended cab be prepared to be disappointed in the lift from the AIM 3" Extreme arms kit (yes, 2.5" actually). My 33/12.50’s are rubbing bad. The kit has obviously got great potential. The lift kit was barely able to get within spec using their springs though. I have seen it in a 4 cyl truck and he got good lift from it. The lift I got was more like what I have seen from the CST kit. Vary little angle on the lower arms. Nothing like the pic in my avatar, hit the link in my sig for a larger pic. I had 20” of ground clearance under my cross member the way I had that set up and 18.5” after I fixed the ball joint angle with more spacers. Firmer springs would give more height and easer to align. I am expecting to be able to get 20 inches or more from the AIM kit and have all factory alignment specs. Right now I have 17.75” and am bottoming out all of my alignment adjustments. I had to adjust my Uniball ball joints all the way down (3/8 inch) and still max out my camber adjustments. You can buy just the arms for $550. I wish I did. I am going to try some 800+ PSI springs from a full size Chevy next. I am trying to find out what the AIM springs are rated at with no luck so far (part number 11 03 750 635). If you know please let me know! I think they might be a weak variable rate 635/750 PSI or better yet just 750 PSI from the part number. That is what should be in the ballpark. I am calling the tech department again tomorrow. Today I caught them at lunch and had to go to get my truck aligned. I will do a full write up after I work the bugs out. One of them being my break calipers are hitting the arms. This is due to the Fabtech spindles with the AIM lower A-arms not being designed to play nice with each other, and yes I have the second design spindles that are supposed to eliminate that problem (with the stock arms at least).
AIM Spring data from Chamberlin Spring Co. Part Number 750635.
Wire .812
OD 5.274
Coil Count 7.5
Free Length 14.1
Spring Rate 800 PSI + or - 6%
Right Hand Wind
So now I am looking for something in the 850+ or maybe the low 900 range with a free length of 14 to 15 inches. Let me know if you know of a factory spring that fits that description. I called Deaver and they want $350 to custom make a set of coils. I believe there are stock Chevy springs that fit that description but I can't remember where I saw it at. Barry James gave me a part number that looks promising. It’s a TRW/Moog CC648. It’s specs are 870 PSI and a length of 15.25 inches. If I can’t find a good stock spring candidate I will probably just go with them.
Steve
Old 03-19-2005, 11:44 AM   #23
2wdsten
2wdsten's Avatar
Thumbs up Re: Lifted 94 2WD With 33/12.50/15 Tires! Sticky Me?
Red Barron just been reading over your previous threads and think you have a lot of knowledge on 2wd s-series suspension. Just the person I have been looking for to ask a few questions. I have a 2003 s-10 2wd reg cab, short box. I would like to get a set of 235/75/15 under it, without rubbing on the frame rub. I solve the height issue in the back by add 3 leafs (don't think i am crazy for adding 3 leafs for lift, i want to be able to haul a load too) to get 3 inches of lift. I have asked a lot of people tell me spring spacers or they tell me to get a 4x4 (Don't want one). I don't want anything drastic, just 2 inches, and I am just getting done w/collage so I am not a millionaire. Thanx for any response.
Old 03-19-2005, 12:56 PM   #24
2wd Lift Expert
I am moving right now so I am about to loose my internet connection. Please excuse the lack of follow up on this. For just a few inches of lift your best bet is the Fabtech 3.5 lift spindles and a set of SS break lines. Spacers for the coils are not an option. They won't fit/stay in place. Replacing coils, shocks and upper A-arms gets expensive and tricky if all you want is just a few inches of lift. With the lift spindles you retain factory smooth ride and it's easy to get alignments. This will fit the 235's with ease and push out the wheels over an inch on each side for frame clearance. Hands down no question what I would do if I were you. Reread the 3rd paragraph in the first post for details on what to get. I used my Fabtech spindles with my stock wheels for a week so don't believe anyone that tells you they won't work with the stockers. They are just trying to sell you some tires and wheels.
Old 03-19-2005, 01:12 PM   #25
2wdsten
2wdsten's Avatar
Thanks for info. It's nice to know that there are people in this world that care about the two wheel drive truck family. Good luck moving. thanx again.
Old 03-27-2005, 12:14 AM   #26
<Insert Title Here>
99ZR2's Avatar
Dude, that's a great looking lifted 2wd!! :thumbup:
Old 03-28-2005, 01:47 PM   #27
Red Baron were do u wheel at?
Old 05-07-2005, 12:17 PM   #28
2wd Lift Expert
Almost all of the pics above were taken at Azusa canyon in southern California. I also play out in the desert off the 395 and the 15.
Old 05-08-2005, 04:08 PM   #29
farfromhome63's Avatar
hey red baron have you had any problems with aim or their products, imreally thinkin about getting that 3.5 extreem kit but i dont want muchlift i want some more usable travel, i cant figure out what spring touse i need a moderately stiff setup to balance out the rear i have thezq8 option with the 4.3 5 spd std cab and locker im gonna run 30x9.50 15tires and rims with aims backspacing specs, im prolly gonna get thecheapest shocks just till i can save for some bilsteins, any ways anytips or input would be great id appreciate it thanks -steve
Old 05-08-2005, 04:19 PM   #30
2wd Lift Expert
No problems at all on my daily driven Sonoma. I recommend thoroughly greasing Fabtech upper bushings to use with the AIM kit. They are almost twice the width as the AIM bushings and fit perfect. For springs I bought some variable rate 3/4 ton Chevy truck springs from Auto Zone for $65 for a set of 2 (Perfect Circle/Dana part # FCS648C) but haven't installed them yet. 3 inch S10 lift shocks are from a 2wd Suburban. I recommend Bilsteins and nothing else. Don't forget to get new break lines too.
Old 05-08-2005, 09:02 PM   #31
Registered dumbass
NC4x4's Avatar
not to get off subject, but i am interested in seeing the 33's that dont rub with 4" of lift. i have the trailmaster 5" lift with a 2" body lift on my 97 4x4 s10 and I had to trim and beat to get 33s not to rub. I think offroad i can still get the tires to rub in the front fender wells if i flex enough. so this 4" + 33's is awfully suspicious...
Old 05-09-2005, 12:52 AM   #32
2wd Lift Expert
While I agree 100%, that is still vary off subject. It is also called thread high jacking and is just plain rude. Please just drop the subject right now. I have said it once and I will say it again. I really don't care if you can fit 33's on a 4wd with a 4 inch lift. That is not why I started this thread. It is to help the 2wd guys with the unique issues that face them!
Thanks for understanding I just want to keep this thread full of solid info and not polluted with arguments.
Old 05-09-2005, 02:39 PM   #33
does anyone know how diffrent the aim arms are from the fabtech arms vs the cst arms and can you use a combo of them say cst uppers and aim lowers?
Old 05-09-2005, 03:47 PM   #34
2wd Lift Expert
AIM and CST both have short A-arm kits and a 2.5 inch longer arm kit. Fabtech used to sell a long arm kit but discontinued it years ago and has recently discontinued their short arm kit. That said I assume you are trying to mate AIM lower long arms and CST upper long arms for the Uniball ball joints? While both are 2.5 inches longer then stock I haven't seen it done before. The AIM short A-arms seem to be a knock off of the CST kit so it should work.
Old 05-10-2005, 11:14 PM   #35
well i was told that you could request the uniballs and the custom lenghts from aim for a 100 dollars extra i dont know if thats true ive yat to call them ill let yal know when i do.
Old 05-10-2005, 11:17 PM   #36
MaveRankus's Avatar
I don't really care about the post but the truck is hot!
Old 05-11-2005, 01:37 AM   #37
2wd Lift Expert
farfromhome63, I have herd horrer stories about phone orders from AIM. It's my understanding they know about lowering parts but allmost allways screw up lift orders (wrong coil springs, parts missing, ect) or try to charge extra for parts that come with the kit if ordered over the net. Be warry, you have been warned...
98pewterdime, thank you!
Old 05-11-2005, 01:40 AM   #38
barryjames's Avatar
I think his truck SUCKS, but is a good way.
Yea his truck is sweet
Old 05-11-2005, 04:33 AM   #39
ok thanks red baron do you know any suppliers that i can order from indirectly cause id like it to be about 4 in wider perside, the other question i have is why cant i run my stock rims i like them i think that they look good the guys at aim said i need more backspacing if so what size wheel spacer can i get t make it fit?
Old 05-11-2005, 07:23 AM   #40
2wd Lift Expert
Any lowering shop that handles AIM products will be able to do it. That is what AIM mostly sells is lowering parts. I have only heard of one in Sam Demas but don't remember the name.
Old 05-11-2005, 09:57 PM   #41
Question Re: Lifted 94 2WD With 33/12.50/15 Tires! Sticky Me?
Hey Baron, I have a 98 2wd Blazer and ever since I got the truck I have always wanted to lift it, but feared that it wouldn't be worth the money because it wasn't 4x4. Was it worth it to lift your truck and if so what lifts would you suggest. (I want to go UP to if you know what I mean, as far as I know the biggest suspension lift that they sale for my truck is the Fabtech 5.5 ultimate lift kit. But it seems like you really know what your doing with your sonoma, so get back with me about your thoughts)
Old 05-12-2005, 12:52 AM   #42
2wd Lift Expert
A few things to consider if wanting to lift a virgin 98 2wd blazer.
1 what type of off roading do you want to do? Desert trails, shallow mud and fire road exploring is easily handled by 2wd's. Rock crawling, hill climbing and muddy swamp crossing is best left for the 4wd's.
2 Does your Blazer have factory posi (G80 code)? Posi's make drifting and sliding much more fun and help get you out of trouble spots.
3 Can you do the work yourself. If so you can save a ton of cash picking up parts used, if you know how and what to inspect. If leaving all parts decisions to people trying to make a buck off of you, well that can get expensive. What will you do when (not if) you break something out on the trail?
4 Are you willing to convert your front breaks to the truck style? It is a downgrade.
I enjoy the thrill of the trails with my S10 but the guys I go out with have 4wd's. I admit I have an obsessive compulsive and competitive personality. That said, I bought this jeep to play on the harder trails...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4538344528&rd=1&sspage name=STRK%3AMEWA%3AIT
As far as lift suggestions read the first post in this thread.
Old 05-12-2005, 02:13 PM   #43
barryjames's Avatar
Not true, that kit will not work on 98 or newer Blazers because of the hubs on the newer Blazers.
You can always have something custom made but you are talking alot of money.
The only thing you can do is install a body lift and/or lifted coil springs
Old 05-12-2005, 02:21 PM   #44
2wd Lift Expert
If the arms are the same why can't he just convert to the truck style front breaks?
Old 05-17-2005, 01:46 PM   #45
I drive a bike-cycle
fastbagged2001's Avatar
Baron,
If I get these Uniballs...will I need to get a spacer? and will I need to flip the uniball? How about some pics of your set up now!
Your a big help.
Old 05-18-2005, 11:58 PM   #46
noma truck's Avatar
sick truck i hope mine turns out that good
Old 05-19-2005, 01:22 PM   #47
2wd Lift Expert
Quote: Originally Posted by fastbagged2001
Baron,
If I get these Uniballs...will I need to get a spacer? and will I need to flip the Uniball? How about some pics of your set up now!
Your a big help.
That's a question that cannot be answered. There are just too many variables, lift kit manufacturer, type (length) of arms, total lift kit height, rim and tire width, cab type, motor size ect. Even then it's still a 50/50 chance. The ball joint spacers are an alignment aid for the lift kit no matter what ball joint is used. The nice thing is that you do have that option should you need it. You don't have that option with a welded on setup like the CST kit.
These Uniball ball joints do mount under the upper A-arm so yes they mount "flipped".
My desktop isn't setup nor will it be any time soon. My "home office" is being used as one of the storage rooms. I bought a card reader for my laptop but it didn't work. I will pick up another when I get around to it and post up some pics then. I should have the bigger springs on it by then too.
noma truck, Thank you! About your email...
"Hi I saw your truck on this web site and you did a great job on it.I was wondering on how big of a lift i will need to clear some 31inch boggers on my 96 2wd sonoma or what tires would you think would work the best on a 2wd Thanks"
You'll need a total of 5.5 inches of lift to fit 31 inch tires. Tires are a personal preference. That said, I like the all terrain type tires for a 2wd. Like the BFG's I have now and the Mickey Thompson Baja Claw Radial in a 33x15.50x15 will be my next set of tires. Boggers have a staggered width and a 31x10.50x15 tire is too narrow already for my tastes. Remember a tires rated width is its sidewall width not tread. My 33x12.50x15 BFG's have a tread width of 10 inches, a 31x10.50x15 tire has a tread width of only 8 inches.
Old 05-19-2005, 04:39 PM   #48
Master Shake
85S10Eric's Avatar
That is gonna be a MEAN looking truck with them on it.
I wanna do something like that, put some huge bastard tires on my truck, like 35x12.50-15s. That's gonna need a good bit of clearance, so, it won't be for a while.
Old 05-23-2005, 11:42 PM   #49
noma truck's Avatar
Alright thanks alot for the help do you think it would be ok to get a 3 inch bodylift and like a 2 inch suspension lift or would that not work i am new to this stuff so I dont really know much.
Thanks
Old 05-24-2005, 01:43 AM   #50
2wd Lift Expert
85S10Eric, Thank you!
noma truck, I know for a fact that setup works well. Just ask Barry James, he has been useing that setup for some time now. He removed his CST short upper A-arms and coils to gain ride quality back. It is a good alternitive to a more extreme (and expensive) long arm lift kit.
As for your email question... I asked you not send me email questions nice, please don't send another. It won't be answered...
"thank s for your help with the lift and tire stuff . I was just wondering if you get stuck alot wheel ing in a 2wd or do you do ok .In your pic you are crossing a river and your truck is all muddy so you must do ok in some stuff i was just wonderin how well a 2wd can do. I am being told that it is a waste of money to lift a 2wd because it cant go anywhere.
Thanks"
As shown in my signature I now have a 3.73 Posi that gets me out of the sticky stuff (usually). I have been pulled uphill, up the last 50 feet of a muddy ravine and pulled the same lifted 4wd Dakota that saved me out of a 3 foot deep ditch that he managed to drop both front wheels into up to the frame. I had to have 4 adults sit on my tailgate but we are now even. I have gotten stuck one other time in 1 foot thick mud that had a dry crust over the top. Had I seen I was about to drive into a mud bog I would have picked up speed and let my momentum carry me through. I was alone with a single passenger. I lowered the air pressure to 10 PSI and had him get on the tailgate and I rocked the truck back and forth from forward to reverse. 40 minutes later we back on our way down the trail very happy to be able to drive away. I can go any ware a stock 4wd can go with street tires and do go through a lot of places most folks would never take their stock 4wd’s. Keep in mind most 4wd's are really only 1 wheel drive up front and 1 wheel drive in the rear. Even then the motor only gives drive power to the wheel with the least amount of traction.
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f219/lifted-94-2wd-with-33-12-50-15-tires-162873/
Posted By For Type Date
AIM Kit This thread Refback 01-20-2008 11:54 AM
S-Series.Org :: View topic - THINKING OF LIFTING YOU 2WD S10?? Look here first! This thread Refback 01-13-2008 01:46 PM
S-Series.Org :: Viewing profile This thread Refback 01-04-2008 11:44 AM
