End-all answer to S10 axle widths? - S-10 Forum
post #1 of 34 Old 01-05-2010, 10:49 PM Thread Starter
Sold :'(
s10xtremist's Avatar
User is: s10xtremist is offline
I've searched many forums over the past couple hours and have found nothing definitive. I'm trying to find accurate measurements of S10 axles, not "I think it's about xx inches wide". I need to know 2WD, 4WD and ZR2 widths from WMS to WMS. A guy has an 8.5 (or 8.625) with G80 from his ZR2 for sale for $150. I figured it's a decent deal if I could use it on my 2WD. I planned on using a 4WD rear for more track width, and using spacer adapters in the front to widen it the same amount over stock. I need to know the definite widths of these axles so I can determine if the ZR2 axle would be excessive, and if I should stick to the regular 4x4 axle.
post #2 of 34 Old 01-06-2010, 12:05 AM
Forum Dictator
What?'s Avatar
User is: What? is offline
Re: End-all answer to S10 axle widths?
I forgot stock EXACT measurement but I know where to find it,
But basically.
4wd, 2" wider per side than 2wd
ZR2 4wd, 4" wider per side than 2wd.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #3 of 34 Old 01-06-2010, 12:32 AM
Forum Dictator
What?'s Avatar
Here you go.
2wd 54.5"
4wd 59"
ZR2 63"
What? is offline
post #4 of 34 Old 01-06-2010, 03:30 PM Thread Starter
Sold :'(
Originally Posted by What? View Post
Here you go.
2wd 54.5"
4wd 59"
ZR2 63"
THANK YOU!!!
post #5 of 34 Old 01-06-2010, 03:32 PM
**** New Jersey
Tim99Zr2's Avatar
User is: Tim99Zr2 is offline
yea, i knew the 4x4 and the zr2 rears. didnt know the 2wd.
99' Noma Highrider, 2" PA Body Lift, SAS'd approx. 8", D44, 9", 5.13s, locked, 35" Yokohama Geolander M/Ts on Steelies, Custom Bumpers, 5 Speed Swap, True Duals - SOLD
02' Kawa. ZX-6R Yosh Slip On, Flush Mounts, Custom Sliders, Satin Black With Smoked Chrome Wheels - SOLD
98' Cadillac Catera, Stock, Daily Driver
09' Yamaha R6, Black / Gold, GYTR Slip On, Maybe More Later
Tim99Zr2 is offline
post #6 of 34 Old 01-06-2010, 09:04 PM Thread Starter
Sold :'(
The wheels I'm using are 17x8 with 0 offset (4" BS). I'm thinking that I'll like the width of these wheels on a ZR2 axle, but the front will require an LT kit and a spacer. I need to see a pic of low-offset wheels on a ZR2, and I figure there's more of a chance of finding a ZR2 with ZQ8 wheels for reference. So, would anyone know where I could find a pic of ZQ8 or Xtreme wheels on a ZR2? Or maybe a forum with someone on there that has such a setup and I could hound them for pics? What would be the widest spacer one would consider "safe"?
post #7 of 34 Old 01-07-2010, 02:08 PM
Forum Dictator
What?'s Avatar
NP, send the 750mL whiskey to me lol.
You can buy LT from any fabbers on dezertdimes.com, getting it 3.5"-6.5" are doable with coil-coilovers and with that rim and backspacing, you may not need spacer.
Once you get LT taken care of then you'll be able check if you'll need spacer or not.
What? is offline
post #8 of 34 Old 01-07-2010, 02:09 PM
Forum Dictator
What?'s Avatar
3.5" - 6.5" wider per side*
What? is offline
post #9 of 34 Old 01-07-2010, 11:06 PM Thread Starter
Sold :'(
I want to keep everything in factory proportions, just wider. So, if I use that ZR2 axle, my rear wheels will stick out 4.25" further than where they're at now. I'll need 3.25" longer arms if I use AIM spindles and 2.25" if I use Fabtech spindles. I don't think I'd mind a 2.25" spacer, so I could save the money I'd spend on an LT kit and put it towards the more expensive Fabtech spindles. I just don't think I'd wanna use a 3.25" spacer, that just kinda scares me.
post #10 of 34 Old 02-04-2010, 04:34 PM
tommyramone55's Avatar
User is: tommyramone55 is offline
dumb question.....
but can you do that to widen your stance up front? Just make like 2 inch wider arms?
currently mid sas
A recent study shows that 92% of all teenagers converted to emo/punk etc. Put this in your sig if you're one of the 8% who stayed gangsta as shit
post #11 of 34 Old 02-04-2010, 05:48 PM
Zr2.2
BillsDuster's Avatar
User is: BillsDuster is offline
Originally Posted by tommyramone55 View Post
dumb question.....
Yeah that's all the long travel suspensions do, longer control arms equal longer range of travel. Your lookin at big bucks though just for a wider stance.
Cheap and easy is a set of wheel adapter/spacers. Not the best solution if your hard on it, but it's the cheapest and easiest way to widen the stance.
FOR SALE: 1998 S10 Ex-cab 2.2, 5 speed, locked 4.56 rear, 4 wheel disc brake swap, Fabtech spindles, Fabtech long travel, SOA rear, 31/10.5 BFG's
Daily: 1995 Blazer LT, 4.3, 4l60e, ORD SAS HPd30, xploder 8.8, 35's
Full Resto Someday: 1974 Ramcharger SE, 360, auto, 4x4, rust free from AZ. Keeping it stock...maybe
BUY ME: $250 shipped, Powertrax No-Slip GM7.5" 28 spline axle. PM if interested
post #12 of 34 Old 02-04-2010, 09:58 PM Thread Starter
Sold :'(
Well, I ended up with a set of Fabtech spindles because I got a package deal on them. And, I have the ZR2 axle. AND, the wheels I'm using are 8" wide with 0 offset (4" backspace). So, my rear wheels will be moved outward a grand total of 4.58" per side from where they're at now (I have stock Xtreme wheels on it now). So, accounting for the 1.5" the spindle will give me and the .33" the wheels will give me, I'll need 2.75" more width in the front to keep my factory proportions. If the AIM LT kit is 2.5" per side, then I think that'll be close enough. If I find that I'm missing that .25", I'll get longer studs and a .25" spacer.
What do you mean by "hard on it"? Would you say that I should be fine with ~2" spacers on stock CAs if my truck is on paved highway 98% of it's life? BTW, my tires are 255-75-R17, so a tick under 32".
post #13 of 34 Old 02-04-2010, 10:27 PM
Zr2.2
I'm thinkin hard on it as in offroading hard. The spacers would put added stress on the wheel bearings because of the tire being further out and adding leverage. As for road driving it, I'd see no problems, at least no problems for quite some time(still could wear on the bearing in time).
The lowered guys use spacers all the time to fit vette or front wheel drive wheels, and I havent read much dislikes from them. I'd just get some new wheel bearings just for the heck of it, they are cheap enough. I know 992drjimmy ran 2" spacers in the front with no issues while he had his lifted truck, a couple other guys have also. I'm going to get some spacers when I get my tax returns back, most likely just 1.5" just to even the rear up more with the front. I'm gonna put them in the front and see how it looks for sure.
post #14 of 34 Old 02-05-2010, 01:00 PM
well bill, you wanna get me a set too haha
currently mid sas
post #15 of 34 Old 02-05-2010, 01:10 PM
Zr2.2
Yeah no problem bro, you want to pay double? lol
post #16 of 34 Old 02-05-2010, 07:30 PM Thread Starter
Sold :'(
Well, I feel better about the spacers. Maybe I'll try 'em out for a while until I can save the cash for the LT kit. I just got new bearings and races when I did my front brakes about two months ago, so I should be okay. I'm also gonna get a full set of Power Performance BJs. I guess I should order them now so I'll have a better chance of getting them by summer!
BTW, Fabtech's instructions for the spindles says:
WHEEL SPACERS MUST NOT BE INSTALLED WITH THESE 3" LIFT SPINDLES!
Is that to prevent excessive wear to the bearings and/or BJs, or is it because the spindles could break (spindle separate from the knuckle, etc)?
post #17 of 34 Old 02-05-2010, 10:16 PM
DarkKnite2009's Avatar
User is: DarkKnite2009 is offline
all three.... I have std S10 2wd can i put a 4x4 rear end in my truck without modification? wut years had the widest?
post #18 of 34 Old 02-05-2010, 11:15 PM Thread Starter
Sold :'(
The year of truck really had nothing to do with the width of the rear end, except for the years that ZR2s were made. And, yes, a 4x4 rear end will be a direct swap for your truck. What? listed the different widths in the third post of this thread.
post #19 of 34 Old 02-05-2010, 11:51 PM
Zr2.2
Covering their backsides. They also say don't use wheels with different offsets. Basicly you can't sue if you break your truck or kill yourself using the part "improperly". If guys can jump trucks with these spindles, I don't see how putting a spacer on it and driving around town is going to hurt anything. Heck I have watch stock trucks launch 4-5 feet off the ground at the sand dunes over and over with no parts breakage. The spindles are way heavier built then stock for sure.
Check these..
http://cgi.ebay.com/ebaymotors/5x4-7...Q5fAccessories
post #20 of 34 Old 02-06-2010, 12:01 PM Thread Starter
Sold :'(
I figured as much, but wanted to hear someone's experienced input.
I was wondering if anyone made hub-centric spacers. Thanks for the link. I can slip a $70 purchase by the wife much easier than an $800 one!
post #21 of 34 Old 02-06-2010, 12:10 PM
sweet thanks. i didnt cath that post before
post #22 of 34 Old 02-06-2010, 10:23 PM Thread Starter
Sold :'(
Curiosity kept gnawing at me, so I called AIM. The sales rep told me that their LT kit was 3" per side. Everything I've been reading said it was 2.5" per side. So, are the arms actually 3" longer than the stock arms, but accounting for the arch they swing in and with the truck on the ground, you would net +2.5" per side? I'm not really that concerned about a half inch, I'm just curious about some details of what I've been reading.
BTW, if anyone's interested to know, AIM's LT kit on their website comes with a 3" coil and it's $895. It's $825 if you want the kit, but not their coils.
post #23 of 34 Old 02-07-2010, 03:38 PM
sapperb's Avatar
User is: sapperb is offline
Ya i am getting metul munky's zr2 axle for my BB possibly next week, because to the addition to my front suspension it is now 4.5" wider on each side so the Z rear end will compliment it truely
High Dezert Fabrications, call me if you need some Fab'n (573) 528-9428.
sapperb is offline
post #24 of 34 Old 09-27-2011, 09:01 PM
User is: user151 is offline
I hate to bring up an old thread but I want to nail this down because I have read that the 1990 and earlier differ from the 1991 and later S10 rear axles in width (as well as 4X4 and 2X2) giving 4 different widths...
If xtremist's post (and post 3) is correct, then there are NOT 4 widths, but just the three mentioned. .... Right?
(FWIW I am using a 1992 2X2 axle in my rod and it is indeed 54.5 WMS - WMS)
user151 is offline
post #25 of 34 Old 10-04-2014, 11:55 AM
User is: wecycle is offline
Cool Re: End-all answer to S10 axle widths?
Anyone have a "left over" narrow 54.5" WMF to WMF axle assembly, complete with 3.42 gears for sale? Drum or disc, open or Posi? Do you think the axle and drum/dick could be redrilled for 5 on 100mm wheel bolt pattern? this will be going on a 1969 Opel GT if the dimensions work out.
Preferably in the pacific NW, ie TriCities area of Washington state.
Dennis in West Richland, WA
wecycle is offline
post #26 of 34 Old 10-16-2014, 01:59 PM
89-S-Dime's Avatar
User is: 89-S-Dime is offline
Here you go.
2wd 54.5"
4wd 59"
ZR2 63
I can confirm this
post #27 of 34 Old 11-28-2015, 05:33 PM
OnyxSS
trevor98's Avatar
User is: trevor98 is offline
I have read this forum and just want to ask...I have a 4wd rear end out of a blazer (not a zr2 4wd) that I just got out of the junk yard. its going on my 2wd s10 pick up. are the wheels gonna stick out past my fenders like a hot rod? it is a sport side if that makes a dif. prob wont make a difference though. thanks
trevor98 is offline
post #28 of 34 Old 11-28-2015, 09:09 PM Thread Starter
Sold :'(
Look where they are now and picture them about 2" further out. I'm pretty sure they'll be about flush with the outside of the fenders, as in, the fenders will get bent if you hit a hard bump or carry weight in the bed. You could run Camaro/Corvette wheels and get spacers for the front.
Getting better with every failure
Project threads:
Punching bag
Unicorn XJ
post #29 of 34 Old 11-29-2015, 03:06 PM
OnyxSS
trevor98's Avatar
Here's the deal. I was told to get spaces for the rear because they set to far in as it is. That's why I was wondering will this just get rid of the need for spacers? The main thing I want from all this is the disc breaks. My SS already has 3.42 posi. Just not the disc breaks. And the rear wheels need to be pushed out some. I didn't think 2" would be any more than what the spacers would have did. Is this thinking wrong? It's not a zr2 4wd rear. It's just regular 4wd rear and it has 3.42 posi.
trevor98 is offline
post #30 of 34 Old 11-29-2015, 04:19 PM
B4U Task Force
Rhotpursuit's Avatar
You can swap the disc components with the exception of the rotors. You'll need the spacers from s10 warehouse to space the axel brackets out. Easy swap...afternoon will do it if you're prepared and have all of the parts. That way you'll still have the hop shock.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #31 of 34 Old 12-01-2015, 09:31 AM Thread Starter
Sold :'(
I agree with the wheels looking all tucked in. I just bolted on some 1" spacers and let it be. I probably could have fit 1.25", but I didn't want the tire that close to the fender. I had wider tires at the time and they tucked a bit with the amount of drop. On hard turns, the sidewalls would still rub the fenders because of the rear end shifting and sidewalls rolling. A 4WD rear would be too wide if all you want is to push the wheels out some. A ZR2 rear is outta the question as it's about 4" wider than a regular 4WD rear. Swap the disc brakes from that Blazer rear you have onto your axle and add some spacers to bring the wheels out to where you want them. You can easily roll the fender lips for another 1/2" or so of clearance.
Project threads:
Punching bag
Unicorn XJ
post #32 of 34 Old 12-07-2015, 10:32 AM
ChevyLsII's Avatar
User is: ChevyLsII is offline
What's the length of the axle shafts of an 8.5" 2wd 54.5" wms-wms axle?
post #33 of 34 Old 12-10-2015, 09:13 AM
OnyxSS
trevor98's Avatar
I have decide to swap the disc over to the 2wd and the posi unit as well. Mine is shot. Just one wheels turns even in burn out. Question is will rotors from a canary work with my discs from the blazer rear end? Some people are say they won't work and I have seen after market kits for my truck and the cent of the rotors are deep! The centers of the after market and the factory camaros are much much shorter. By like 3". will camaro rotors work if I swap disc assembly over to my 2wd? Or do I need to buy after market rotors from little shop of horrors who sells the whole kit?
trevor98 is offline
post #34 of 34 Old 12-10-2015, 11:47 AM
B4U Task Force
2wd Blazer others will work fine.
Apple Red 96 SS
