4Wd tow hooks on my 2wd.. - S-10 Forum
post #1 of 17 Old 09-30-2007, 11:38 PM Thread Starter
FUCK YOU
Wicked Mayhem's Avatar
Ok im lookin to get some 4wd tow hooks for my truck, im gonna be gettin the 4wd valance as well. but will these things go on right with a 2" bodylift? and will they bolt up to my 2wd blazer frame???
Wicked Mayhem is offline
post #2 of 17 Old 09-30-2007, 11:41 PM
User is: oh_look_its_tim is offline
Re: 4Wd tow hooks on my 2wd..
dunno if the holes are there, if not, just drill 2 holes and ur set
post #3 of 17 Old 09-30-2007, 11:48 PM
forum idiot
orangesonoma's Avatar
i would not use the stock hooks...they are weak and if you are really stuck they will not help you..they will bend and break...and i think the will sit lower then he valence with a body lift..
Brian
orangesonoma is offline
post #4 of 17 Old 09-30-2007, 11:49 PM Thread Starter
FUCK YOU
what do you reccomend then?? im wantin something just incase i do get stuck somewhere..
post #5 of 17 Old 09-30-2007, 11:51 PM
Honest Abe's Fab Shoppe
BlackEsDime's Avatar
User is: BlackEsDime is offline
Send a message via AIM to BlackEsDime Send a message via MSN to BlackEsDime Send a message via Yahoo to BlackEsDime
a front differential?
-Ryan
I build aluminum fuel cells. Maybe...
www.honestabesfabshoppe.com
post #6 of 17 Old 09-30-2007, 11:56 PM Thread Starter
FUCK YOU
i think ill weld one to my engine crossmember
post #7 of 17 Old 10-01-2007, 12:00 AM
that should work!
-Ryan
post #8 of 17 Old 10-01-2007, 12:01 AM
forum idiot
lol...
not sure if they fit a 2wd frame...but theses...
http://shop.synergyoffroad.com/produ...1&productId=13
then you slide these bad boys in...
http://shop.synergyoffroad.com/produ...1&productId=81
Brian
post #9 of 17 Old 10-01-2007, 12:04 AM
Registered Asshole
crazy91s10's Avatar
User is: crazy91s10 is offline
Send a message via AIM to crazy91s10
yeah def... i'd suggest using firstgen towhooks before using ones from a second gen..
i've never had any problems with my firstgen towhooks as far as yanking me out.. i have, however, broken one of my towhooks by bashing it off a big rock.
if i were you.. i'd look into using beefier tow hooks than stock s10 tow hooks. check out how redbarron mounted tow hooks to his 2wd in the front... see post # 210.. first pic in that post shows his tow hook in the front...
http://www.s10forum.com/forum/f134/l...73/index5.html
its right by his sway bar
post #10 of 17 Old 10-01-2007, 12:06 AM Thread Starter
FUCK YOU
ehhh. im gonna have to make something i guess. im not wanting to cut up the valance. i plan on gettin a new ones and dont want it cut up..
post #11 of 17 Old 10-01-2007, 12:19 AM
Registered Asshole
crazy91s10's Avatar
its probably worth modding somethin up instead of using the stock secondgen hooks. just my 2cents. and if ya were to mod somethin up i'd def use a beefiier tow hook than any stock s10 hook
post #12 of 17 Old 10-01-2007, 04:09 AM
Professional Insultant
TokoDragon's Avatar
User is: TokoDragon is offline
Send a message via MSN to TokoDragon
synergyoffroad also sells the reciever tube hook things that go where the stock 4wd hooks go, I want to get those.
post #13 of 17 Old 10-01-2007, 04:21 AM
It's a Blue thing...
♠ lυε ♠'s Avatar
User is: ♠ lυε ♠ is offline
I gotta say, thats one bad ass setup.
-Jay
♠♣NEW CALIFORNIA S10 FORUM♣♠
www.WaylayedInc.com
♠|♦ '97 Noma Bagged DD ♣|♦ '98 S-10 4.3l Static 5/5 ♦|♣
WANTED: '55-'57 CHEVY BIG WINDOW PICKUP
♠ lυε ♠ is offline
post #14 of 17 Old 10-01-2007, 10:20 AM
forum idiot
lol...
i have them...they are pretty sweet...
Brian
post #15 of 17 Old 10-01-2007, 02:23 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
i used the 4wd tow hook, stuck couple times, gotten me out and no damage or bend or anything.... so far, i just drilled and bolt up to frame
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #16 of 17 Old 10-01-2007, 04:43 PM
ive never had that hooks snap, and ill pull backwards on it and get snapped outta tough holes on it never even bent....
post #17 of 17 Old 10-01-2007, 05:19 PM
Registered 12 year old
AmosM823's Avatar
User is: AmosM823 is offline
You are gonna probably have to put a 2" spacer in there if you wanna use the stock tow hooks.
2001 Chevy Blazer 4x4
31" Fireston Destination AT's
2" BL, T-Bar Tweak, Shackles
SOLD...you will be missed
AmosM823 is offline
