2wd tire size...what size effects the truck in what way?
okay...yeah, another 2wd post
i searched, but didn't find anything. i gotsome error most of the time. anyway, since i've got a 2.2L, i know it's not the most powerful motor in the world, and i was wondering what tire size would affect the truck in the aspect of power/speed how much slower would each tire make the truck? i guess going from 28-32" tires... if anybody can understand that post, it's kinda hazy. haha. |
bodydropped on 22s!
Re: 2wd tire size...what size effects the truck in what way?
well the bigger the tire the slower the truck is going to be
but i mean like... " 28" tire - not noticible 29" tire - barely noticible" ect ect..if anybody knows, because i sure as hell don't. it's also good material for future 2wd lifters ![]() |
bodydropped on 22s!
depends what gears you have..
Registered Asshole
Location: Moscow, PA / Mansfield, PA User is: OffLine |
no matter what... if you go with a bigger tire than stock you'll notice a difference.. esp with a 2.2
it all depends on what gears you have like jmew said... most likely if you go with a 30" tire or bigger you'll def need to regear if you want your gas mileage back. ask bobbys10man, jmew, or muddubber about using bigger tires and dif gears on a 2wd |
i hope one of them chime in |
Registered Dreamer
I do have 31" tires with 3.73 gears (stock) use your RPO codes in your glove box to see what gears you have. My truck will run just fine with the stock gears going down the interstate as long as your on flat road or going down hill and there is not a strong wind LOL... So what I am saying if your mostly in town and every once in a great while you drive on the interstate then you will be fine with stock gears, if you drive on the interstate a lot then you are going to notice it being pretty slow... I can drive 70 but as soon as I hit a head wind or any kind of hill I am doing good to keep it at 60... As far as gas milage, it is not great and not horrible either... I have a 16 gallon tank and I fill up as soon as the low fuel light comes on and I can get about 275-315 miles per tank...
Registered Asshole
and there ya have it...
Lifted Member
A 4wd truck should be just as conscious about gears and tire size as a 2wd. The main factor in this thread is his 2.2L.
If you want 30's or 31's, swap in a set of 4.56's. The tu-tu likes to rev and doesn't deal well with a load placed on it (lack of torque) so you'll need all the torque multiplication you can get at the tires. Running 4.56's with a 2.2L 4 cylinder is the same as running a Vortec 4.3 V6 with a 2.45 ring and pinion gear. Same amount of torque to the wheels. |
Registered Asshole
. remind me never to buy a 2.2 |
Slap my meat on your pita
25mpg in my 2.2 woo!
Lifted Member
KCSSERIES
shit the new corvette z06 hurd they get 22+ on the highway with that 427 7.0L motor they have
Lifted Member
our 06' C6 gets around 15MPG with the LS6, 6spd auto tranny *thumbs down* anyway, back on topic. i've got stock gears...as far as i know anyway, i'm sure nobody has messed with them. just how hard is it to change out a set of rear gears? |
Registered Asshole
if you go with a somewhat uncommon gearing then you'll have to purchase a gear set. if you end up purchasing a gear set then it'd probably be in your best interest to have a professional set them up for you. rink can elaborate on that but its a very tedious procedure that doesnt allow for error. it also involves some special tools to measure backlash etc.. |
so, swapping the entire axle would be a better bet. that sounds alot easier than opening that transfercase up, and sticking my hands inside. haha. 4.56's...what numbers would i be looking for in the glovebox? i'm sure it's in a thread somewhere around here, so i'll search in a second. ha. also, when i do purchase the entire axle, 1 what all would i need to get with the axle? any other parts from the truck, and would it be a bad idea to put the axle in with everything else still being stock? would i see any...bad things by putting the axle in there just like my truck is now? or any improvements? |
Registered Dreamer
errr...not transfercase.... yeah...didn't mean transfercase... uhhh... thanks ![]() |
Registered Asshole
and as to using 4.56 gears... its gunna be tough to find them in a junkyard s10. like i said before, i'm not even sure how common that gear ration is in a stock truck and i've never actually come across a 4.56 rear in any junkyard that i've been to. most common ratios that you will find in a junkyard will be 3.08, 3.42, 3.73, and 4.10. any lower (numerically higher) and you'll most likely end up having to purchase a new gearset and have them installed in your existing rear axle. and to answer your other question... it will not hurt anything by putting different gears in your truck. whether you swap out the entire axle or you have new gears installed there will be no adverse affects. only minor thing that may change is your speedo reeding will be off. depending on what gears you choose and what size tire you run, your speedo will either be reading too slow or two fast or may not be off at all. just depends on the tire/gear combo you use. if your truck is a second gen i believe a dealer can recalibrate your speedo if necessary. if its a firstgen then you'll just have to know how much the speedo is off and drive accordingly. Last edited by crazy91s10 : 10-01-2007 at 11:42 PM. |
Lifted Member
I mean this in the most respectful way possible, if anyone on here asks what all is involved with a gear change, they're better off taking it to the shop. I do the same thing with my welding. I can spot weld all day long but when it comes to strength and structural welds I know my limitations and have no problem taking my welding projects to a professional. Same goes with a gear change.
Call around your area looking for a driveline shop, or more specifically a clutch, U-joint, driveshaft type of shop, and ask them what it would cost for you to bring the entire rear axle assembly to them to have the gears changed. Order the ring and pinion set, along with the master intallation kit THROUGH THE SHOP, so labor will be cheaper. Nothing pisses a place off more than you bringing aftermarket gears and the install kit to the place just to have it done. If you're looking to save money, read up on how it's done, and do it yourself on a spare junkyard axle that you can practice with. No, it wont save you money the first go-around. But you'll have a great foundation of knowledge for doing gear changes later on. 1st time though, have a shop do it for you and watch the laborer while he works. Ask questions, be specific, write down everything. The first time I had my 3.42's swapped out for 4.10's, I paid right around $400 or so for the 7.625". Next time around after that axle took a shit, I did it myself again on a different "new" rear, swapping out the 3.08's for 3.73's, same truck. No common S-truck came out with 4.56's. There were a few in the olden days when the Isuzu Hombre came out with the diesel 2.2, but that was the 7.5" many years ago, only offered in Mexico. I think there is one more exception in 1st gens that I'm forgetting, but the gist of it is, the 4.56's are so rare your best bet is to go straight to the top with 4.56's and have a shop do it for you. If you're looking for a G80 Eaton Gov-Lok, send me a PM, I have one in decent condition with only 36k miles on the 7.625". You can find 4.10's pretty easily in extended cab 2.2L trucks, but you're still limited to a 31" tire, and even then you'll feel the drag. Like I said earlier, a 2.2L does not do well against a load like a V6 will. The tu-tu was made solely to impress the Greeny's looking for a fuel efficient daily driver truck. Last edited by Rinkrat456 : 10-01-2007 at 11:52 PM. |
i've taken a simple obx LSD apart for a 90-93 accord and reassembeled it using a writeup on honda-tech, but that's as far as i've been. and it performed very nicely afterwards ![]() i haven't searched much...because i'm not sure as to what i'd be searching for, but i'm still in the learning stage right now, i want to learn as much as i can before i do anything to this truck. you said you've got an G80 Eaton Gov-Lok, and you said it was on a 7.625" what is this 7.625? like i said, if theres a thread where this is covered please direct me towards it, i'm all for learning ![]() |
Registered Asshole
the 7.625" rears started showing up in the last few years of firstgen production and they continued to use them in the s10s till the production of the s10 was ended.
the earlier 7.5" rear showed up only in the firstgens and they stopped using them somewhere in the very late 80s or very early 90s. not exactly sure when they stopped using the 7.5" rears... all i know is that my 93 came with a 7.625 rear in it. so basically depends what year your truck is |
#24 |
Lifted Member
It's the rear end in your truck. The 7.625" measurement is the diameter of the ring gear. The strength of a rear end is not directly proportional to the diameter of the ring gear, but the larger it is, the stronger the rear will be.
#25 |
sweet
now onto wheels...i want that wide stance aswell. i read on another thread, that with a 4" backspacing, the tire will stick out roughly 1 inch. what was not covered in that thread, was the 2wd/4wd thing. is that on a 2wd, or a 4wd? basically what i'm looking at is a 2"BL thats coming in the near future, but i'm still unclear on what type of a tire i'll be able to fit under my 2wd sonoma. xxx/xx/xx back onto the wheels, i want something along the lines of this i'm assuming i should just keep it at 15" wheels, but what should they be? 15xwhat? |
#26 |
bump for an answer?
i searched, but i must of been searching with the wrong key words...nothings come up that has helped me very much |
#27 |
Lifted Member
On a 2wd Sonoma, a 2" body lift allows 30x9.50R15's all the way around with slight rubbing of the frame. Rims with 4" of backspacing on a 2wd, keep it stock. If possible, use your rims with 1.25-1.5" bolt on billet aluminum spacers. The cost of the spacers will be less than the cost of new rims by half, and will actually allow you to run up to a 31x10.50R15 with the same amount of rubbing as a 30x9.50 without spacers. Still given a 2" body lift.
2" body lift. Stock rims. 30x9.50 with slight rubbing of the frame 2" body lift Stock rims Bolt on 1.25-1.5" spacers 31x10.50R15 With a 2.2L, I'd stick to 4.10 gears and 30x9.50's if this is your daily, 4.56's if this is an off-road truck. |
#28 |
now...when you're talking about the rubbing, i'm assuming "full lock" is the correct terminology, (when i've turned my wheel all the way to the left/right, or my suspension has maxed itself out?) i'll rub my frame at full lock?
also, i highly doubt i'll be changing the gears any time soon, i just went and checked in my glovebox and i saw a GT4, which according to the information that i found when i searched, means i've got 3.73 gears. so, as of now, i think my plan is to go with 2"body lift stock rims 30x9.50 bolt on 1.25-1.5" spacers and all of that is on the stock 3.73 gears, on my DD. i know the 4.10's multiply torque more than the 3.73's do, but would it be a smart idea to run that setup on 3.73 gears? |
#29 |
Registered Dreamer
I run a 5" lift with 31x10.5's with no spacers with a 2.2 and 3.73 gears and its my daily... I have not had any problems really... Its a little slow on the interstate though
#30 |
and the 5" suspension lift puts more strain on the motor..am i correct?
if that's the case, then i'm guessing that the setup i've put together (With help from you guys, haha) will work with minimal problems (as far as MPH, and acceleration) Last edited by npor : 10-04-2007 at 05:57 PM. |
#31 |
Registered Dreamer
I'd say the tire size puts the strain on the motor more than the lift height...
#32 |
Tucking 37"s what?!?!
Location: Hamilton, Ontario (Canada) User is: OffLine |
wow theres someone else on the forum at 6 in the morning haha---anyways I am running tires 5" taller than stock with roughly 4 inches of lift with a v6
i also had the stock tires with just the lift and my city mpg was the same until i put the tires on---hwy mpg dropped maybe 1mpg. my tires however dropped me from about 18-19mpg down to 15. really not a huge difference but i'd bet that the 2.2 would struggle a lot more and thus have a bigger drop in mpg..... just slap them on and see what happens! (gas is expensive--you might as well use it haha) |
