235/75r15??
will these tires fit on a stock 2wd s10, its a 2003 if it matters. The tires I have now are 205/70r15. Sorry for such a silly question. I didn't see it in the sticky thread. My tires are about bald, and i found a deal on these. Also whats the largest tire i can add without having any fitment/clearance issues. Thanks!!
'86 S-10 Ext cab 4x4
Re: 235/75r15??
Yeah they'll fit. the only thing that might happen is that they might rub frame when your at full turn. but that's about it.
Re: 235/75r15??
as of right now i am running that exact size. they will rub your frame front and back. also if you hit a big enough bump to make your front end bounce there is a good chance it will rub the tub of the wheel well. it will also rub the wheel well bhind the tires when making sharp turns. i ended up taking a 7 pound sledge hammer to it and only rubs on full lock now
Moderator
Re: 235/75r15??
You'll rub a bit but just use hammer and hit out inner fender or trim it.
Re: 235/75r15??
i have that size tire on mine w/ rubbing on the frame and that is it.
