would injectors from a mustang work on a truck intake
Old 11-01-2009, 10:34 PM   #1
97ls1s10's Avatar
i can get a deal on some 42lb injectors off a mustang
Old 11-01-2009, 11:05 PM   #2
CODE4LS1's Avatar
Re: would injectors from a mustang work on a truck intake
You would have to modify the hold downs for the fuel rails as they Mustang ones are a but taller than the smaller OE truck injectors.
Old 11-02-2009, 10:27 AM   #3
97ls1s10's Avatar
thats easy i would just have to put spacers. what about the size of the top and bottom??? and plug?
Old 11-02-2009, 11:52 AM   #4
its just greg
AmericanMuscle's Avatar
if you want a set of 42s for your truck intake I think the 8.1L injectors are the right size. I know the 42's from ford fit on ls1/la6 style intakes since thats what i'm running on my build.
Old 11-02-2009, 03:57 PM   #5
97ls1s10's Avatar
ls1 injectors are longer or shorter???
Old 11-02-2009, 06:21 PM   #6
Iroc-10's Avatar
The connection is different as well as the height. You can get spacers and a connection to swap between the truck/LS2 style injector at the following, but if your needing more fuel, you probably need to swap intakes any way. Usually guys use these parts to use LS6 or Ford Injectors on an LS2 ported intake.
http://fuelinjectorconnection.com/shop/
You may want to research this on LS1tech.com
Old 11-03-2009, 03:22 PM   #7
its just greg
car injectors are taller.
Page generated in 0.55926 seconds with 31 queries
[Output: 59.50 Kb. compressed to 56.09 Kb. by saving 3.41 Kb. (5.73%)]
