Winter mods Stage II
Old 02-07-2009, 10:32 PM   #1
So, while chasing phantom exhaust leaks, today I discovered my manifolds were cracked at just about every weld, putting a straight edge on them showed that they were warped as well... Didnt make sence to just build new manifold and keep everything the same, so here is whats being done:
New stainless manifolds/crossover
stainless 4" downpipe
Garret GT42R with 82mm/1.15 a/r
-8AN fuel feed line from tank to intake
Edelbrock Victor Jr intake
Edelbrock 90deg Elbow
Edelbrock 90mm TB
Edelbrock Fuel Rals
Aeromotive Boost referenced fp regulator
Driveshaft safety loop
AlkyControl meth kit
low profile CalTracs
should get more interesting now..
Also found out my old turbo was Precision 72GTS with .96 A/R ..
Old 02-07-2009, 11:20 PM   #2
Re: Winter mods Stage II
no pics
Old 02-09-2009, 10:33 PM   #3
soon
Old 02-15-2009, 08:14 PM   #4
Heres some in-progress pics...
Old 02-16-2009, 02:09 AM   #5
its just greg
AmericanMuscle's Avatar
looks good, should be good for a few ponies, or a new name...
if you got some time would you take a good pic of your coil brackets. I need to make a set of those.
Old 05-07-2009, 12:49 PM   #6
I know I havent updated this thread in a while, ran into some problems with the motor. 20+ PSI boost and couldnt make any power on the dyno, turns out compression was 120 on all cylinders. All internals were fine, turns out it was just the way engine builder put the motor together. Had to get another block for a core, and have a different builder put it all back together. At the same time, changed the cam as per new builders recommendations, and swapped the heads for some TrickFlow 225s. Got it on the dyno yesterday, at 18PSI of boost im now having different problems, see the vid
http://videos.streetfire.net/video/S...yno_680840.htm
Old 05-07-2009, 01:05 PM   #7
Here are updated pics as well
Old 05-07-2009, 01:17 PM   #8
On da bottle
zx9rgreen's Avatar
So you have basically rebuilt everything on the truck that was done on the swap basically? Very nice man, what are you looking for as far as power goes......800+ im assuming?
Old 05-07-2009, 02:02 PM   #9
Yep, thats pretty much what happened. I could have been happy with 11.2x @ 122 that the truck was doing, but then you know how one thing leads to another... The only thing thats still left from how I bought the truck, is the motor mounts
I now have all the hotside parts to build another S10, manifolds/crossover/downpipe/turbo, gonna post it up for sale soon
Old 05-07-2009, 02:28 PM   #10
Jonce007's Avatar
Very nice rebuild man! That thing is going to haul. Here I thought I was going to be happy with my stock 5.3L, then I login and see this!
Goal - high 9's???
Old 05-07-2009, 03:00 PM   #11
takes 2 balls in our game
s10-den's Avatar
Why do you suppose the manifolds cracked at the welds?Shitty welds or from the heat and cool down on them? If thats the case,then I damn sure aint going to waste my time on using the stock manifolds....
Old 05-07-2009, 03:30 PM   #12
I didnt have stock manifolds on the truck, i had some custom made stainless ones. The reason i believe it cracked was too much stress, there was no flex pipe or anything on the crossover, lots of stress everywhere.
Old 05-07-2009, 04:19 PM   #13
On da bottle
zx9rgreen's Avatar
What shop built that truck if you dont mind me asking?
Old 05-07-2009, 04:39 PM   #14
http://www.tunetimeperformance.com/
They did the new hotside, the motor, and tuning. dont know #s yet, going to borrow some slicks tonight from a monte and bring them over there in the mourning
Old 05-07-2009, 06:24 PM   #15
Not so Avg
tiresmokinV8's Avatar
This truck has come a long way. Its gonna haul for sure!
Old 05-07-2009, 06:30 PM   #16
JJ's Automotive
SoLowXtreme's Avatar
bad ass !
Old 05-07-2009, 06:40 PM   #17
On da bottle
zx9rgreen's Avatar
PM me when you get a parts list and prices.....
Old 05-07-2009, 07:05 PM   #18
its just greg
traction is for bitches....
looks killer
