Why does my ac compressor clutch keep burning up? - S-10 Forum
post #1 of 6 Old 06-19-2010, 09:58 AM Thread Starter
Two tones of terror
KJF95S-10's Avatar
User is: KJF95S-10 is offline
My truck uses a factor denso compressor for an 05 yukon and ever since I got the ac system hooked up and charged it worked great for about 2 days then the compressor clutch stared slipping and smelling bad and blowing dust everywhere. So I took it off and found that it was fucked up pretty bad so I bought a whole brand new clutch with the coil and everything and it worked perfectly for about 2 days also and now its doing the same thing and slipping bad almost to the point where it wont spin. What could cause this to happen on 2 different clutches? Could the system be over charged with freon? Thanks
95' S10 ext cab:5/5 drop, 5.3-LS6/4L65E, Turbonetics TC78 rear mount
"Bags, low only when it's convenient"
Overkill is consistently more fun
post #2 of 6 Old 06-19-2010, 10:19 AM
Registered Hoosier
Hoosier Rick's Avatar
Re: Why does my ac compressor clutch keep burning up?
Did you check/add oil to the system? Sounds like your compressor is seizing up.
post #3 of 6 Old 06-19-2010, 11:09 AM
CODE4LS1's Avatar
User is: CODE4LS1 is offline
Could be the compressor seizing up or the head pressure is too high inside the pump. My money is on the compressor like Hoosier said.
CODE4LS1 is offline
post #4 of 6 Old 06-19-2010, 02:22 PM Thread Starter
Two tones of terror
KJF95S-10's Avatar
Idk it turns easily and freely and cools excellent as long as the clutch is working right. If it was low on oil wouldnt something inside the compressor fail before it burns up 2 clutches or am I wrong? What would make the pressure too high?
post #5 of 6 Old 06-19-2010, 03:50 PM
Anybody got 20's?
Bdydrp02s10's Avatar
User is: Bdydrp02s10 is offline
Send a message via AIM to Bdydrp02s10
When you turn it are you grabbing the actual pulley or the clutch? Was the system properly vacuumed down and charged? Did you add oil to it when installing it? Also check the voltage going to the clutch. You could not have enough voltage and it might not be engaging all the way.
Sold to my younger brother. 2002 ext. cab S-dime Getting rebagged with 20s. http://www.cardomain.com/ride/769386/1
2006 ext. cab GMC Sierra VortecMax. Stock. Fully Loaded. http://www.cardomain.com/ride/2932266
post #6 of 6 Old 06-19-2010, 06:30 PM
User is: flawlessfab is offline
could very well be no or low on pag oil.......plus like above poster said check voltage.....if you need a price on a oem new compressor hit me up ....work at a dealership and get awesome discounts.....
