Which truck to start with.
Old 08-22-2008, 02:19 PM   #1
PontiacChris is on a distinguished road
I am looking to get a newer style S10 to put a 5.3 into. Would the swap be easier it the truck has a 4 cylinder or a V6 to start with? Just need I find a truck before I start g trying to figure out to much other stuff. Thanks, Chris.
Old 08-22-2008, 02:30 PM   #2
DragThaFuka's Avatar
DragThaFuka is infamous around these parts
Re: Which truck to start with.
v6, cuz i believe you may be able to use the trans and rear end
Old 08-22-2008, 02:35 PM   #3
denali_on_26's is on a distinguished road
i have found you can get the 4cyl trucks way way cheaper and easier!!!
Old 08-22-2008, 02:39 PM   #4
Thanks for the quick replies. Yeah the rearend will be replaced, so that is not a huge problem. Did the 4L60 come with the 4.3 and the 2.2? Will the factory gauges be able to work with either? I'm going to try and keep as stock looking as possible.
Old 08-22-2008, 05:04 PM   #5
91s10green's Avatar
91s10green is an unknown quantity at this point
motor mounts in the v6 trucks are stronger then the 4cylnders i believe if you are putting in a 5.3.
Old 08-22-2008, 05:04 PM   #6
More Go then Show
THEKING's Avatar
THEKING is on a distinguished road
Just find one with a blown engine. You can get those real cheap if you find one.
Old 08-22-2008, 05:05 PM   #7
91s10green's Avatar
i think there are 2 transmisions 4L60 and 4L60E.
Old 08-22-2008, 05:16 PM   #8
91s10green's Avatar
i believe the 5.3's transmission is a 4L80E i think? could be wrong.
Old 08-22-2008, 05:24 PM   #9
joutlaw is on a distinguished road
Negative... 5.3's have the 4L60E... 6.0s and others use the 4L80E
Old 08-22-2008, 05:38 PM   #10
91s10green's Avatar
I believe that if you go with the 4L60E that it would fit and would work with the 5.3L. but the 4L80E is twice as tough as the 4L60E. is the truck you going to get going to be a 2wd or a 4wd?
Old 08-22-2008, 05:40 PM   #11
91s10green's Avatar
you could probably do a swap more expensive. but yeah the transmission you need is a 4L60E
Old 08-22-2008, 05:43 PM   #12
91s10green's Avatar
i have a question what is the difference size wise between a 4L60E and a 4L80E?
Old 08-22-2008, 08:29 PM   #13
slow and low
ssDimer's Avatar
ssDimer is on a distinguished road
the motor mounts dont matter between a v6 and a 4 cyl cause you have to use conversion mounts anyways. In my opinion you should start with a 4 cyl cause you can buy them cheaper. Now depending on if you want to go auto or manual is up to you. The 4l60 will work for a stock 5.3. I started out with a 99 s10 with a 4cly 5speed and i swaped in a 5.3 w/ a t56 6speed out of a camaro and i was able to use the stock clutch lines and slave cylinder. Real easy swap. If you want to use the stock gauges then give current performance a ring. They sponser this forum and if you look at the sticky above it will give you alot of info. search search search.
Page generated in 0.12029 seconds with 12 queries
