Which Clutch Master cylender should i Use
Old 04-26-2008, 10:03 AM   #1
I have a ls6 t56 sonoma. i am having issues out of my clutch system. i think it is in the hydralics. Which clutch master and slave cylender should i use.
Old 04-26-2008, 12:37 PM   #2
On da bottle
zx9rgreen's Avatar
Re: Which Clutch Master cylender should i Use
are you loosing your clutch when you drive aggressive? But then it comes right back. (boiling fluid)
Old 04-26-2008, 02:33 PM   #3
No I am just losing fluid randomly and when i sit in traffic the clutch has real issues with losing fluid. But I just destroyed my pressure plate so now i have no feel at all lol.
Old 04-27-2008, 05:55 AM   #4
jinusow's Avatar
loosing fluid or pressure? Heat stock slave, master, worn clutch, pp, pilot bearings, throwout. I'm just listing a lot of things that go bad once the pedal gets stuck to the floor. I think the master and slave are the same as in the new s10 as the camaro. if you are loosing fluid the slave is leaking. I changed my master a while ago I really think the gm master cylinder is just doesn't have the meat to take the heat over time. I run valvoline dot 4 cause that;s the only dot 4 I can find. I read a gm release someone posted at ls1tech.com that says everytime you open the cap you're adding air into the system weaking the ability of the brake fluid to hold pressure and stay away from boiling. the article basically wanted you to only open the resivor when you plan to completely flush the system with new fluid and close the cap.
I'm rebuilding my trans and replacing my clutch and flywheel with the ls2/ls7. I was having the lose of pressure going from 2-3-4 at the track. Made some fun when you have no way to get out of 4th so you got to putt away after getting your timeslip.
Old 04-27-2008, 08:25 AM   #5
takes 2 balls in our game
s10-den's Avatar
lol....like he said, Are you losing actuall fluid or just pressure?----Jinusow, where you been man?
Old 04-27-2008, 01:13 PM   #6
jinusow's Avatar
I've disappeared for awhile just to take a break get, some ideas, try some other things (halo 3) . I came back to see what has changed in the modding and see if anything was interesting.
Old 04-27-2008, 01:19 PM   #7
I was losing pressure do to loss of fluid. Until yesterday when my pressure plate let lose racing a guy when i went to grab 6th. So now i am pulling the trans back out and going to re replace the slave and master cylender along with the pressure plate.
Old 04-29-2008, 08:56 PM   #8
s10-den's Avatar
well, you will pretty much will fix it when replacing those things,so lets us know what happens?.....
Old 04-30-2008, 11:22 AM   #9
i replaced both previously. and i think i was leaking fluid through my speed bleeder. Oh well looks like i am calling FREDBEANS because no one has better prices.
Page generated in 0.57154 seconds with 31 queries
[Output: 67.38 Kb. compressed to 63.27 Kb. by saving 4.11 Kb. (6.09%)]
