Vette gauge cluster
Old 08-18-2009, 11:14 PM   #1
Vette gauge cluster
Has anyone ever used the factory corvette gauge cluster in their s-10? I'm going to be putting an ls1/2 in an s-10 and I was thinking of using the vette gauge cluster. Any ideas opinions or links would be helpful! Thanks!
Old 08-19-2009, 07:06 AM   #2
On da bottle
zx9rgreen's Avatar
Re: Vette gauge cluster
There is a turbo blazer around here that has the vette cluster, he probably has a thread some 4~10 pages back.
Old 08-19-2009, 06:41 PM   #3
thanks a lot, I'll do some searching for it!
Old 08-19-2009, 10:57 PM   #4
Build them right....Mod
philntx's Avatar
Do an advanced search on 12sec ss
He's the one who has the truck with the vette cluster.
http://ss.lencolab.com/s10/pics/DSC00424.JPG
Old 08-20-2009, 11:52 AM   #5
art
art's Avatar
The idea is there but could have done a better job executing it, jmo
Old 08-20-2009, 12:38 PM   #6
thanks!! I was more concerned of the wiring and what has to be retrofitted or if any when using a ls1/2 vette motor.
Old 08-20-2009, 04:16 PM   #7
philntx's Avatar
The current owner of the blazer did not do the gauge conversion (in his defense), however, I do agree that it could have been integrated into the dash with a little more flair.
Old 08-20-2009, 06:15 PM   #8
Whats this for?
mr spree's Avatar
yea it could look pretty good. anyone think it would work in a 1st gen?
Old 08-20-2009, 09:10 PM   #9
Local Tech
ls1s10onair's Avatar
Probably wouldn't look right on its own in a first gen... I'd love to have a 200 mph speedo tho lol
Old 08-21-2009, 09:54 AM   #10
I like that a lot, but it could have been done more neatly. I'm going to have to start looking into wiring diagrams.
Old 08-21-2009, 12:19 PM   #11
Killing Time
Petro's Avatar
Even though Phil's thread kinda faded off I still wanted to try this when I get the money:
http://www.s10forum.com/forum/f213/7...speedo-375982/
Old 08-21-2009, 11:11 PM   #12
Need LSx swap.....
Kampz69's Avatar
i wonder if phil ever got that working?
Old 08-24-2009, 12:14 AM   #13
Im going to do some research on it and see if I can find wiring schematics. There maybe a way to just put it in using the vette motors. Im sure there is just a voltage difference and it can be done.
Old 08-26-2009, 10:34 AM   #14
philntx's Avatar
Could not get it to work.
The tach and speedo are moderated by the circuit boards in the I/P.
In order to install a 7K tach in a 120 MPH cluster, it would require the removal of the circuits for the tach and re-installation of the new circuits.
After about 50 hours, I retired from that idea.
I'm going with the Bravada cluster now.
Old 08-26-2009, 12:20 PM   #15
Need LSx swap.....
Kampz69's Avatar
thanks for the update phil, too bad it didnt work out...
Old 08-26-2009, 01:02 PM   #16
Illusions's Avatar
what will be needed to install the bravada cluster? will it be accurate or as accurate as it would be in a bravada?
Old 08-26-2009, 01:21 PM   #17
philntx's Avatar
Nothing is required. Keep it the same year and it's a direct replacement.
The Tach will read correct and the speedometer will work correctly.
If I remember, Jared has done this to one of his also.
However, I see that you have an LT1. I would call Jared on this before you purchased one.
Old 08-26-2009, 01:54 PM   #18
Illusions's Avatar
Thanks, I'll check into it.
