Nitto1320 M O D
Valvetrain Upgrade
I was wondering if this would be a good route to go for the valvetrain in my now stock 5.3
Cam http://store.summitracing.com/partde...=CCA-54-414-11 Other http://store.summitracing.com/partde...0&autoview=sku I will be running a LS1 intake and LS1 TB 2002 5.3 Will the stock valvetrain hold up or should I definately strengthen it? |
Re: Valvetrain Upgrade
I might not get the lifters, but the cam is a great choice and the pushrods and springs are also very good.
Nitto1320 M O D
So use stock lifters?
Nitto1320 M O D
and another question... for the front drive accessories, I have nothing. Is it really like $800 for a whole new assembly?
ls1 junkie
I would suggest using the LS7 lifters. they are like $125 through a GM dealership. I used them in my motor. are a nice upgrade for cheap. I have heard some bad things about the comp lifters.
Location: prince albert, sk, CANADA! User is: OffLine |
To change the lifters you have to take off the heads which has the extra cost of head gaskets. The stock lifters work fine as long as they are in good shape. |
Uni-Joint Snapper
Sweets10v8 - what lifters would you recommend with an lq4 and l92 heads? I plan on running factory valves for the time being.
ls1 junkie
Im sure the lifters are a nice piece, just have heard too many negatives about them. thats why i went with a GM part. Used comp pushrods though, they are a very nice piece. |
you have a part # for ls7 lifters?
Uni-Joint Snapper
i was just about to ask that, i cant find it online.
ls1 junkie
GM p/n 12499225. I think i paid $125 for the set at my dealership. Scoggin Dickey has them listed for $108+shipping.
Sdimess84
Thats a good cam. I am running that same came
9.38@153.6
I ran that cam and the Comp Cams 54050 Rev kit. Worked excellent in my 5.3L also running it in My 2004 Sierra.
Nitto1320 M O D
I already took the heads off because honestly it looked like the engine had more than 40k (grease, build-up, etc) and when I pulled the intake it looked like oil absorbent pellets under there... but when I pulled the heads the cylinders still had nice hones and there was no ridge... clean valves, good oiling, etc. In the end it would have been okay but I would rather not risk it.
I already have a set of nice head gaskets that I bought back when I had my 6.0 so no extra cost really... But if the stock lifters will work fine I dont really wanna shell out another $100 on top of the thousands it will be in the end. Another question, how do you remove the lifter galley/knock sensor pan... I removed the bolts but feels like something is holding it and I don't want to pry or anything without knowing? |
9.38@153.6
Keep your stock rockers, and your probably going to need to have custom length pushrods, I wouldnt buy pushrods unless I checked the length first, on anything. That camshaft is OK it all depends on what your doing. |
Nitto1320 M O D
Yeah I pulled the knock sensors... I'll give it a little prying assistance if I ever get a day off.
More Go then Show
